I was attempting to build a Soarer's converter with Teensy++2.0, for my G80-1813HFX.
However, the only result that I could pull out was ending up seeing R04, R05 or/and R06 codes spammed on my hid listener and never worked at all.
These are the steps that I have passed through, so you might take a look and give me some advices, which in case I would be very grateful!
1. https://geekhack.org/index.php?topic=46 ... msg1035707 Based on this post on GH, I have learned that the cables on the board connected to the phone jack is the following:
B-Ground/G-Vcc/W-Data/R-Clock
2. I connected those cables connected to the phone jack with Teensy++2.0 like the following:
B w/GND, G w/Vcc, W w/PD0, and R w/PD1
3. Then I have used the windows version of the teensy loader downloaded from PJRC, and selected Soarer_at2usb_v1.12_at90usb1286.hex then pressed the program button
4. Used hid_listen.exe provided by Soarer for informations, however every single time I have tried, also with other versions of the firmware, this was the result more or less:
Waiting for new device:...
Listening:
R06 wEE
remaining: FFF8
Keyboard ID: 0000
Code Set: 1
Mode: PC/XTR04
R04
R05 R04 R04
R04 R04
R04 R04
R04 R05 R04 R05 R04 R04 R05 R04 R04 R04 R04 R04 R04 R05 R04 R04 R04
R06 R06 R06
R05
R04
R04 R05 R05 R04 R04
R04 R05
R04 R04
R05
R05 R04 R04
R05 R05
R04
Device disconnected.
It has been 3 hours just on trying to make this converter to work and now it is almost a torture
I would happily answer any ideas, questions, suggestions, or/and advices on this!
Thank you for your time
I fried it.
