Cherry MX and diodes
skruffi
24 Sep 2012, 11:36
Hey,
I haven't found anything on it yet, so I'll post my question.
I hope those of you with advanced knowledge on Cherry MX switches with diodes can help me out.
The question is, whether it is possible to add diodes to the housing of switches that don't have them. I don't think they have different housings for the switches, do they? And if it was possible, does anyone, by any chance, know the kind of diodes that cherry uses? On another board I read something about using 1N4148 diodes with the switches, though I couldn't figure out if it referred to diodes mounted on the pcb or inside the housing of a switch.
Thanks in advance!
Cya!
.skruffi
Icarium
24 Sep 2012, 12:24
Yes, those will work and adding them is easy but you have to open the switch to do it.
The_Ed
Asperger's... SQUIRREL!
24 Sep 2012, 12:28
Unless the matrix of the keyboard supports it, you can't just add diodes... Diodes will fit in all but MX Lock I believe.
skruffi
24 Sep 2012, 12:40
Thank you very much, both of you. And I'm aware of that, The_Ed, but since I'm building the keyboard myself from scratch, it is no problem. ;)
Cya!
.skruffi
Icarium
24 Sep 2012, 13:12
Alright, now let's hear more about that project of yours!
Input Nirvana
16 Oct 2012, 05:08
Don't ya hate...
Getting wind of someone building a keyboard...and then they keep it to themselves!
