kfmfe04 wrote:btw, has anyone figured out the sets needed for a Kinesis layout?
on gh
http://geekhack.org/index.php?topic=23446.390, I see a posting of a breakdown (towards the end of that page, there is a chart), but I'm afraid to get this to match out with
Round 5 would take a computer program to figure out...
Or a sufficiently helpful-feeling human who has some familiarity with the kits...
The range of keys in
Round 5 allows quite a lot of this to be done as shown. All the 1.25 mods are available as are the row 4 cursor keys. However the 1.25 punctuation and the other unusual row 4 keys aren't available, and 2 unit keys aren't available in row 4, only in the steep row 1 or the symmetric row 3. The blank availability though is enough to make up the layout.
To cover the pictured layout, I would go for something like this:
HONEY/ALPHA 1 - Covers the two 5x3 alpha blocks, change for language as applicable
HONEY/NUMROW/WHITE 1 - For the row 1 numbers, also includes row 2 [ and ] keys that can mounted upside down to be the row 4 [ and ]
HONEY/MODEXTRA125 1 - For the 1.25 Tab and Caps Lock
HONEY/SHIFT125 2 - Self explanatory
HONEY/CURSOR/R4 1 - All the row 4 cursor keys!
HONEY/MOD100 1 - For the single unit Ctrls
HONEY/MODEXTRA100 1 - For the single unit Alts
HONEY/CURSORBASE 1 - Home, End, Page Up and Page Down in their standard rows
Additional required blanks:
BLANK/R3U125/GREY 4 - This includes 2 for row 1 - row 1 1.25 blanks aren't available
BLANK/R2U100/GREY 4 - Equal to and used as row 4 keys (deduct 2 if using the row 2 [ and ] keys from NUMROW/WHITE or option 2)
BLANK/R3U200/GREY 4 - (deduct 1 if using option 1b)
Options:
1a
HONEY/NUMNUM/WHITE 1 - Gets you the row 2 "8" key, but no "3" is available (you could have an upside down "3" by using the "3" key in this kit)
1b
HONEY/NUMPAD 1 - Same as above but also gets you a row 3 2u Enter
2
HONEY/7BIT 1 - This has two grey row 2 curly bracket keys, which could be used an alternative to the [ and ] in NUMROW/WHITE
