Dra
- Main keyboard: custom cardboard contraption
- Main mouse: Zowie FK1
- Favorite switch: Just let me die already
05 Apr 2016, 23:50
Looks like Foam and Foil?
Seebart owns an old Keytronic and everything points towards it, screws on the PCB, switch housings don't appear to be seperated and, well, the fact that it's a keytronic
keyboards-f2/key-tronic-corp-serial-no- ... 11875.html
Those Manurhin boards do look interesting though, seem to be some early cherry switches?
Compgeke
- Main keyboard: IBM Model M 1391401
- Main mouse: Coolermaster Recon
- DT Pro Member: 0040
Britney Spears
- Main keyboard: Happy Hacking Keyboard
- Main mouse: CST2545W
- Favorite switch: Topre
06 Apr 2016, 08:46
Since some people like the old Peacock case, a
Peacock for 3€ might not be a bad deal. The keycaps might be interesting too.
gogusrl
- Main keyboard: Cherry G80-1851
- Main mouse: Logitech G9x
- Favorite switch: linear stuff
06 Apr 2016, 10:02
looks like a G83 to me.
Nuum
- Main keyboard: KBD8X Mk I (60g Clears), Phantom (Nixdorf Blacks)
- Main mouse: Corsair M65 PRO RGB
- Favorite switch: 60g MX Clears/Brown Alps/Buckling spring
- DT Pro Member: 0084
06 Apr 2016, 11:18
Jup, it's a G83, look at the bars on F&J.
ohaimark
- Kingpin
- Main keyboard: Siemens G80 Lookalike
- Main mouse: Logitech G502
- Favorite switch: Blue Alps
- DT Pro Member: 1337
Dra
06 Apr 2016, 19:42
Huh, what are those switches? I'm really curious about this one
ohaimark
- Kingpin
06 Apr 2016, 20:04
Dra wrote:
Huh, what ware those switches? I'm really curious about this one
I'm sure you recognize the SKCL Greens. The black switches are a mystery to me. I think they're dome + membrane, but I could be wrong. I think I see an Alps logo on the PCB? The photos are awful.
- Capture.PNG (114.65 KiB) Viewed 6391 times
- Offtopicthority Instigator
- Main keyboard: Rotation
- DT Pro Member: 0061
Contact:
06 Apr 2016, 20:09
Yes there is something round on the PCB in that area, could be the Alps logo but impossible to tell.
I did some image manipulation on it but the image quality is too lously to tell:
- s-l1600.jpg (277.72 KiB) Viewed 6366 times
Blaise170
- ALPS キーボード
- DT Pro Member: 0129
Contact:
06 Apr 2016, 20:18
Those black ones are a relatively common Alps slider over rubber dome switch. I've seen them used in a ton of keyboards, from Qtronix to MacAlly boards.
Contact:
06 Apr 2016, 20:20
Blaise170 wrote: Those black ones are a relatively common Alps slider over rubber dome switch. I've seen them used in a ton of keyboards, from Qtronix to MacAlly boards.
I don't see those in our wiki?!?
This looks different:
wiki/Alps_dome_with_slider
jerue
- Main keyboard: OTD 360c / G80-5000 / 55g HHKB BT Type-S
06 Apr 2016, 20:46
This exact keyboard was listed at an earlier date for a much more reasonable price. I was able to snag it, however the seller cancelled my sale said "I don't have the item on hand, but I will let you know when I get it". One of two things is happening:
1. most likely: seller is evil and a huge jerk for listing an item that wasn't on hand (who even knows if it is this time?)
2. somewhat likely and going about this the wrong way: a fake auction and maybe I'll get the keyboard for the original price I "won" for.
Either way I don't recommend dealing with this seller.
edit: I contacted the seller and now he says it's not the same keyboard...despite using the exact same product images....
http://www.ebay.com/itm/VINTAGE-KEYBOAR ... 2152904154
ohaimark
- Kingpin
06 Apr 2016, 21:41
The $10 price written on the box amuses me.
ohaimark
- Kingpin
06 Apr 2016, 21:51
I did some image manipulation on it but the image quality is too lously to tell . . .
It's definitely Alps. Look at dat PCB number, brah. Below is an example of a different Alps PCB from the wiki.
06 Apr 2016, 22:12
Oooh, SKN switches, wonder what those could be...
Blaise170
- ALPS キーボード
Contact:
06 Apr 2016, 23:26
seebart wrote: Blaise170 wrote: Those black ones are a relatively common Alps slider over rubber dome switch. I've seen them used in a ton of keyboards, from Qtronix to MacAlly boards.
Also note "other types are likely to exist, and may be documented in the future." If this were anything other than rubber dome I would've already bought it.
Edit: Here is a white version of it.
07 Apr 2016, 00:04
That's Matsushita dome with slider. Very vile.
Contact:
07 Apr 2016, 00:07
Aha...so not Alps then, if that is the same switch that is.
ohaimark
- Kingpin
07 Apr 2016, 00:55
It definitely isn't Matushita dome + slider, Chyros.
If you examine the picture the switch housings appear to be:
A) Discrete, not in a single plastic sheet
B) Mounted on a metal plate
C) Wider than the switch B170 pointed out
07 Apr 2016, 01:28
ohaimark wrote: It definitely isn't Matushita dome + slider, Chyros.
Really? Looks like a single plastic plate to me Oo . But of course I could be wrong.
Norman_
- Main keyboard: RedScarf II+ (RS78)
- Main mouse: Zowie FK2
- Favorite switch: Anything Alps
07 Apr 2016, 01:42
Gonna have to agree with Chryos on this one, it's definitely a single plastic sheet. Also i'm not sure i see any metal, let alone a metal plate
07 Apr 2016, 01:49
The keycap stems are off-centre on these btw, so although they're Alps-mount, they're not actually Alps-compatible.
Khronokrator
- Main keyboard: Omnikey Ultra T
- Main mouse: Logitech Proteus
07 Apr 2016, 03:22
Looks like the Acer auction fell through? The seller seems to have relisted it with a BIN price of $315.
http://www.ebay.com/itm/Acer-6011-Blue- ... 1960419627
Still a bit too rich for my tastes.
Edit: Panbabis' Datatech from a few weeks ago is also relisted now, with a BIN price of over $500.
No offense to these sellers; I'm sure they're pissed off by the Blue Alps bidding trolls, but those asking prices are frankly ridiculous unless the keyboards are lined with solid gold. Which they aren't.
kokokoy
- Main keyboard: FC660C
- Main mouse: CST L'trac
- Favorite switch: Topre, Green Alps, Vintage Black
- DT Pro Member: 0145
07 Apr 2016, 03:51
Guess the seller realized the demand for the Dolch PAC. His remaining listing doubled the price.
ohaimark
- Kingpin
07 Apr 2016, 05:44
Norman_ wrote: ohaimark wrote: It definitely isn't Matushita dome + slider, Chyros.
I maintain my argument. I'll also make a lowball offer on it after requesting better photos.
Photo 1 shows a pattern that looks very much like rust where a stabilizer insertion scraped off paint.
Photo 2 shows tabs that are entirely unnecessary for a solid sheet construction method.
- s-l1600-2.jpg (25.11 KiB) Viewed 6051 times
- s-l1600.jpg (27.75 KiB) Viewed 6051 times
chiptea
- Main keyboard: AT101
- Main mouse: g402
- Favorite switch: Topre/Alps Rainbow
