Post your deskthority header images here
- 7bit
- Favorite switch: MX Lock
- DT Pro Member: 0001
What I mean: You included the test-image, not the final result to the header-image list!
------ Wrong ------
^^^^ Good ^^^^
2nd attempt:
edit:
OK., you have my clearance for upload!
- Madhias
- BS TORPE
- Main keyboard: HHKB
- Main mouse: Wacom tablet
- Favorite switch: Topre and Buckelings
- DT Pro Member: 0064
Not straight, seems to be bent! That barrel distortion
- seebart
- Offtopicthority Instigator
- Main keyboard: Rotation
- DT Pro Member: 0061
- idollar
- i$
- Main keyboard: IBM F or M
- Favorite switch: BS
This thread is the most demanding exam that I have ever taken
I do not know any better lens for a 35mm than the nikor 1.4 ! Perhaps the zeiss otux but I need crowdfunding to get one of these.
- image.jpg (361.84 KiB) Viewed 6111 times
- 7bit
What is a Nikkor 1.4?
If is comes to which lens to use:
15mm f/5.6
28mm f/2.8 Ai-S
105mm f/2.8 Ai-S
Ah, yes I used a wavy 20mm f/2.8 AF, focused at it's closest range, for this:
- idollar
- i$
It is my favourite lens appart from the 135mm 2.0 DC that one day I will own7bit wrote:http://www.kenrockwell.com/nikon/35mm-f14-afs.htm
Distortion performance top
The Nikon 35 1.4 G has the same barrel distortion as Nikon's original 1960 35mm f/1.4. I am not impressed. Nikon has made NO progress in 40 years, and this lens' distortion is slightly complex and more difficult to correct than the distortion from Nikon's better-made original 35/1.4.
This can be corrected for critical use by plugging these figures into Photoshop's lens distortion filter. These aren't facts or specifications, they are the results of my research that requires hours of photography and calculations on the resulting data.
- 7bit
Sorry, but I thought you mean 35mm photography, opposed to 6x6 or so.
Ken rightfully writes "The Nikon 35 1.4 G has the same barrel distortion as Nikon's original 1960 35mm f/1.4. I am not impressed."*
If you want an ultra-low distorting wide lens, that is sharp and whatnot, take the 28mm f/2.8 Ai-S!
As with any wide lens, avoid close ranges.
- idollar
- i$
I do have the 28mm f/2.8 Ai-S! ... but I was never impressed by it.
I will take it out for a walk to check it after so many years
Yes, I know that the 35mm 1.4 is not the perfect in distortion, but all in all, the other features compensate.
I posted an image with some rules to show the distortion level. It is not that much. I guess that the problem with the image is that the space bar was not 100% horizontal.
Anyhow, I failed the exam ... again
- seebart
Hmm is this turning into a optical thread now? All my pictures were shot with this:
That must be why they turn out so good!
This is not an exam idollar!! Take it easy.
- seebart
Very true, the camera itself will not get you those nice pictures. Did you mean my 28mm lens 7bit? I still need it.7bit wrote:Technical perfection is not everything!
BTW: If you don't use your 28mm, I'd be interested.
- 7bit
- idollar
- i$
I agree with the last sentence. The eye makes the pictures. The camera and lens capture the light
7bit ... this is the 28 that I mentioned, in a FM2.
Let me test it with the digital gear again. I have not used it since years.
I moved from the FM2 to the range finders and from there to the digital. It took some years.
- idollar
- i$
I placed the 28mm objective looking the way arround with the following results:
D800
1600 ISO
Aperture priority with +0.7 to compensate the wrong metering.
f5.6
And a crop from it
And now focus at 20cm !
Sharp ! The texture of the keycaps is visible, indeed.
D800
1600 ISO
f5.6
And a crop from it
I prefer naturalistic looking shots like that. But don't let my different time zone mislead you about whether you're passing the grade or not. I like to tell people why they fail, when they do. I'm just on vacation!
- seebart
That's a good lens, probably even better than my ASAHI. Nice test.
- seebart
I like it, but it's got the logo problem again. Take the shot so that the area behind the logo is darker.
- seebart
Yes much better. Of course Mu chooses the headers as you know.
- Khers
- Main keyboard: LZ CLSh
- DT Pro Member: 0087
Those are SHARP! I like the texture of that PBT.
I wish I could take shots like that! My photos never turn out that sharp. But then again, I should probably get myself a tripod to remove my shaky hands from the equation before I start complaining that my shots are a bit soft...
