Alps Appreciation
arkanoid
29 Jan 2017, 14:01
seebart wrote:
E3E wrote: Not much diversity there. :P
Agreed, I'd never buy that many of one switch unless indeed it was a very temping offer. In your case arkanoid, I'm curious if you encountered any differences in all those Alps SKCM blue switches of yours, and if so which?
It was a result of several good deals. Regarding the difference, they mostly feel the same, but one board (the one with the black switch plate) had notably enhanced spring echo sound.
29 Jan 2017, 14:10
OK thanks for the info.
ohaimark
Kingpin
29 Jan 2017, 19:11
I'd like to build a cheap Alps TKL. I'm fine with form factors all the way down to 40%. Any recommendations?
elecplus
29 Jan 2017, 19:26
M0110?
29 Jan 2017, 19:45
M0116? Change the numpad into a nav cluster?
mike52787
Alps Aficionado
29 Jan 2017, 19:48
ohaimark wrote:I'd like to build a cheap Alps TKL. I'm fine with form factors all the way down to 40%. Any recommendations?
clueboard? cut an acryllic case and cut down a 101 plate? The real limiting factors in that statement is the cheap factor.
Hypersphere
29 Jan 2017, 22:22
My own favorites:
Form factor = 60%
Layout = HHKB. A workable compromise is a standard layout, using RCtrl as Fn.
Your preferences may vary.
[ XMIT ]
29 Jan 2017, 22:36
So, my Alps64 board cost about $40 from Japan and a cheap Poker-compatible case cost $20. Cutting down an AEK II's plate with a band saw was free with my Techshop membership.
You could always order a KBparadise V60 with white Fukka/Fuhua Alps clones from mechanicalkeyboards.com for $99. That gets you mediocre switches and key caps, and a bottom row that is a challenge to fulfill with donor caps from vintage boards. For an additional $10 you could get Matias switches.
The very cheapest option would be to chop down an AEK II and hand wire the switches to a Pro Micro. This would be the first suggestion without the Alps64 PCB.
mike52787
Alps Aficionado
29 Jan 2017, 22:42
I got a KBP v60 from ebay for around 60$, desoldered it, and in process fucked the pcb. so, I got an alps64 pcb and with a little bit of modding it fit perfectly. If you do get a KBP v60, please be careful with the pcb when desoldering it. it's multi layer with a ground plane in the middle, and that makes it really hard to desolder.
Menuhin
29 Jan 2017, 23:00
Filco Zero TKL
Not sure if it is still there, at about $60, and normally an agent will charge 10% + shipping which is not too expensive.
https://2.taobao.com/item.htm?spm=2007. ... 1372059346
29 Jan 2017, 23:07
Menuhin wrote:
Filco Zero TKL
at about $60
That would be a deal! They seldom turn up, and easily go for 2X-3X that price.
Mr.Nobody
30 Jan 2017, 07:33
Menuhin wrote: Filco Zero TKL
Wow! How to link a 咸鱼 listing? Isn't it only accessible for cellphones?
Menuhin
30 Jan 2017, 12:03
Really don't know how to access those on a cellphone (probably need a China number), but I found that item on their search engine.
30 Jan 2017, 12:04
All I get is a log-in screen:
Menuhin
30 Jan 2017, 12:20
It happens to me when I access TaoBao through different networks.
Some will redirect me to world.taobao.com and some requires login.
The reason is unknown.
arkanoid
30 Jan 2017, 15:02
I saw this listing a long time ago. The image of the backside shows some scratches and torn off warranty sticker (so it is possible that its pcb is modified, or damaged if not handled carefully). Do you guys think it is still worth buying?
need
30 Jan 2017, 20:34
The description says it's a media evaluation unit used only for photo purposes.
However this obviously isn't a "media evaluation" unit that he claims to be, just look at how shiny those caps are :?
Hypersphere
31 Jan 2017, 00:44
XMIT wrote: <snip>
<snip>
I was thinking of getting a KBP V60 with white Fukka/Fuhua switches and modifying them. For starters, I would like to swap out the top housings with housings from white (pine) Alps switches, but I have never worked with Fukka/Fuhua switches before, and I do not know if the top housings are interchangeable with those from SKCM Alps switches. Does anyone know if the top housings are interchangeable? From the pics in the DT wiki, it appears that the sliders and click leaves might be interchangeable, but I notice that the switch plate and contact leaves are of a different (simplified) design.
[ XMIT ]
31 Jan 2017, 03:47
Hypersphere wrote: Does anyone know if the top housings are interchangeable? From the pics in the DT wiki, it appears that the sliders and click leaves might be interchangeable, but I notice that the switch plate and contact leaves are of a different (simplified) design.
I've got some here and will check when I have a chance, but, I doubt it.
[ XMIT ]
31 Jan 2017, 04:05
Checked. Definitely not compatible. The Orange Alps switch top I tried seemed to be too "tall" and would not click in to the FD (Fuhua) bottom.
Why not just go down the rabbit hole of desoldering? It's a useful life skill. :lol:
rominronin
31 Jan 2017, 13:26
How is the Omnikey to use, with the navigation cluster in the middle like that?
Worth trying in a new board?
mike52787
Alps Aficionado
31 Jan 2017, 13:46
rominronin wrote: How is the Omnikey to use, with the navigation cluster in the middle like that?
Yeah, give it a shot, but expect to feel like throwing your romer gs in the garbage afterwards after you experience a real keyboard :P
Hypersphere
31 Jan 2017, 18:54
Thanks, XMIT! It is very useful to know that the Fukka/Fuhua switch tops are not exchangeable with those from SKCM Alps switches. Disappointing, but this knowledge saved me $100 and some frustration.
Yes, I need to overcome my reluctance to do desoldering and soldering. It's not that I have never done it -- many years ago, I built a Heathkit stereo amplifier (vacuum tubes and everything!) that required a considerable amount of soldering. After the final component was soldered in place, I plugged in the amp, and it actually worked! Part of the problem today is that I no longer have a good workshop space for soldering. Nevertheless, I could create some makeshift space in my study and try to rehone the almost-lost skills of yesteryear . . . .
31 Jan 2017, 19:16
I guess it depends — I like the fact that less tactile switches offer reduced obstruction to my fingers, and Alps switches are meant for strong fingers! Romer-G intrigues me — I won't diss it without giving it a try, as it might suit me nicely. Alps is up at the top when it comes to tactile (with some clones even more so) but I prefer something smoother.
Green Alps on the other hand, now those are enticing.
rominronin
31 Jan 2017, 20:03
Lol, I have just updated my board/switch preferences to reflect my CURRENT usage. I hadn't updated my profile since I first registered!
Oh, and I'm here because I'm looking into a Matias build with aekii caps for my next custom board ;)
Hypersphere
01 Feb 2017, 00:45
The Northgate Omnikey 101 (ANSI, horizontal Enter key) was my first genuine Alps keyboard, purchased some time after owing a KBP V60 with Matias Quiet and another KBP V60 with Matias Click switches. I still enjoy the V60s, but now I prefer the smoother action and more refined sound of real Alps.
I like the Omni 101 with its SKCM white (pine) Alps switches, but after using 60% form factor boards with a HHKB layout, I find it difficult to use a full-size keyboard.
My future plans include building a custom 60% with white or blue Alps switches, using a Hasu Alps64 PCB, a custom-cut plate, and an aluminum case. I like the TEX cases, but I think they have some issues with diode placement in the Alps64, so I might go with a different brand of aluminum case.
rominronin
01 Feb 2017, 15:09
Hypersphere wrote: I like the Omni 101 with its SKCM white (pine) Alps switches, but after using 60% form factor boards with a HHKB layout, I find it difficult to use a full-size keyboard.
I can certainly sympathise; my wrists are so accustomed to split+rotated boards, that using 'ordinary' straight boards for any length of time can cause joint pain. Apart from the occasional laptop usage, I couldn't go back to a straight board
cfraser
01 Feb 2017, 18:08
I replaced all the main keys in an Omnikey Ultra with ALPS Green internals. I never use the numeric keypad nor the SFx keys so didn't bother with them, and the odd key I left as white/clicky, like the space bar and lock keys. I really like ALPS greens, they feel nice, have a nice sound, and are very reliable.
The Ultra has way too many keys! Was a lot more useful in the days before Windows/mice were common. A 60% form factor is a bit too small for me, but I do like some of the "80%" models, lots of decent choices now, more than ever quality keyboards accessible to the PC user.
Hypersphere
04 Feb 2017, 23:52
Does anyone here know if there is any other Alps keyboard with a layout like that of the Zenith 163-73 with a 1.5u Right Brace and 1.75u bottom-row mods? (See the pic below from the DT wiki):
w/images/8/84/Zenith-163-73-Front.JPG
mike52787
Alps Aficionado
04 Feb 2017, 23:54
Hypersphere wrote: Does anyone here know if there is any other Alps keyboard with a layout like that of the Zenith 163-73 with a 1.5u Right Brace and 1.75u bottom-row mods? (See the pic below from the DT wiki):
The ZKB-2 and the ZKB-2r have the same layout.
