Great/Interesting Finds
emdude
Model M Apologist
03 Sep 2016, 01:21
Thanks for the clarification, I was confused because I thought you had just one of these keyboards.
Hypersphere
03 Sep 2016, 02:09
@emdude: Your'e welcome. I think I might even have one more. If so, I will hand it off to Mrs. Hypersphere and get it listed within the next few days.
Lynx_Carpathica
04 Sep 2016, 20:30
Hi
Is a USB G80-1800 for 10€+6 shipping on German ebay, great deal?
Phenix
-p
04 Sep 2016, 21:20
which model?
if its HAD most likely
chzel
04 Sep 2016, 21:33
Being USB, it's probably lasered, and should be worth only if in very good condition, otherwise it's 5€ from cumb.de
Lynx_Carpathica
04 Sep 2016, 21:49
well, I hope it did worth it, otherwise... gonna go cry :P
maybe not, but... :D At least the keycaps are lasered, not pad printed. If for nothing else, gonna be good for a "ok" cheap switch acceptor.
Is the build quality OK? what to expect? or G80-3000 level erm... Brown stripe?
H3lium
04 Sep 2016, 23:10
It's not a particularly bad keyboard.
But it probably has MX-Blacks so desoldering the switches might make no sense (since nobody buys used blacks). The keycaps are lasered thin PBTs so they are not very special either. And the bottom row with all those 1x1 keys is almost useless when it comes to using the keycaps on a different board.
If you can stand MX-Blacks, like the layout and if you want to use it it probably is a good deal. If you bought it just for the heck of it you might get disappointed.
chzel
04 Sep 2016, 23:38
H3lium wrote: ...since nobody buys used blacks...
I buy used blacks! :evil:
Smooth ones that is! :evilgeek:
shreebles
Finally 60%
04 Sep 2016, 23:52
True dat. You can take new blacks and shove them... But old blacks are aight. Same for Browns :D
H3lium
05 Sep 2016, 00:01
So I guess I was wrong.
Of course it has nothing to do with me hating MX-Black switches 8-).
And maybe I am a bit frustrated that you can buy 100 of those boards with mx blacks for 200 € (not joking) but getting a single mx blue board for a real bargain seems to be impossible. If you can stand knockoffs it might even make sense to buy a new cheap mechanical and desolder the switches (TKL ISO 88 keys for 30 € -> 0,35 € per switch). If you like soldering that is ( I do).
Khronokrator
05 Sep 2016, 03:26
NIB DC-3014 for a cool $700:
http://www.ebay.com/itm/DC-3014-LEADING ... 2170527500?
I feel like this one was posted before, and it turned out the board actually came with White Alps switches.
elecplus
05 Sep 2016, 03:42
Khronokrator wrote: NIB DC-3014 for a cool $700:
I can ask him to pull a cap, if you want. He is one of my dealers. He also knows the $700 is a totally retarded price, and does not expect to get that.
Khronokrator
05 Sep 2016, 04:22
I think he'd have more luck just running a bidding war; that's where all of the major Blue Alps sells of the last few months went. Wouldn't be surprised if he got up to at least half of his asking price. ;)
(Make no mistake, I'd love to own it, but I couldn't really afford that either.)
Lynx_Carpathica
05 Sep 2016, 07:44
I don't mind desoldering, but clones? Not really. If they're done right, ok, but putting them in a cherry board... Nope, thank. :D I might go on hunting for a G80-3000 with MX Blues.
Thanks for the answers. :)
Hypersphere
05 Sep 2016, 14:43
If this is the same listing as before, I asked him earlier to pull a cap. He didn't publish the pic, but told me it was white Alps. I told him the price was much too high, but he has persisted in listing it at ~ $700 and describing it simply as "Alps switches".
jerue
06 Sep 2016, 18:17
bolt modded 1392464 SSK (rare! especially with full key set)
http://www.ebay.com/itm/IBM-1392464-Mod ... 1930866700
//gainsborough
ALPSの日常
08 Sep 2016, 06:33
http://www.ebay.com/itm/COMMODORE-AMIGA ... Sw-KFXfqTR
This looks like it's in really good condition. Are these boards compatible with any standard 5-pin DIN to PS/2 converter?
lot_lizard
08 Sep 2016, 08:23
jerue wrote: bolt modded 1392464 SSK (rare! especially with full key set)
Jealous of the Esc (Exit) key. That little devil is never there on these guys. Standing offer.. If someone ever has one, and removed to put on a Bro-cap or something... I would pay 30 bucks for that cap alone. It's about what they cost to reproduce as a one-off.
08 Sep 2016, 15:14
I like the stepped Control keys. Stepped Alts are not that rare, but Control is harder to find.
Otherwise, at least some of that set looks like the Wheelwriter set, or maybe not.
alh84001
v.001
08 Sep 2016, 15:45
I was wondering if stepped Ctrl keys existed. And those shifts are more similar to 1386304/1392595 than to Wheelwriters since legends are vertically centered.
jerue
08 Sep 2016, 22:02
I've had people offer me about 50-60 before for mine (when I had a BBv2 on the Esc key), but still said no. Interesting that's what it costs to get caps reproduced. Good to know :)
I just noticed that F7 key on the keyboard is the only missing special key in the set...shame :(
lot_lizard
08 Sep 2016, 22:56
Nakazato has been dye-subbing PBT M keys for a bit now, and is getting very good at it. He made me a couple of unicorns. It took me a few iterations with him to really dial it in (helped when he finally gave me his template to do the tweaking myself). They are indistinguishable if done correctly. The custom one-offs have a minimum order of 35 bucks (at least did at one point). The $5 dollar variety below are ones he already has the templates produced for.
https://www.etsy.com/listing/194579578/ ... ome_feat_2
Darkshado
09 Sep 2016, 01:02
Slight O/T: What about Unicomp? If this was a standard legend at some point shouldn't they have the template for it?
emdude
Model M Apologist
09 Sep 2016, 01:46
Yes, Unicomp can certainly do key caps with custom legends. However, the quality of the legends is often less than stellar compared to those on original IBM caps.
Darkshado
09 Sep 2016, 04:25
Funny you mention... Got my keyset, keycaps and case not long ago.
I remember seeing comments of blurry legends, looks like that's not a problem anymore. Alignment is.
I just opened a ticket earlier today about these and am awaiting news, probably next week:
First on the left are from my 1989 1391413, then from the keyset I ordered from Unicomp, then pairs of custom keys for both my boards. (The other one is a 1391402, originally with the AZERTY layout.)
IBM 1989 and Unicomp 2016 keycaps
Pause key - IBM 1989, Unicomp 2016.jpg (1014.56 KiB) Viewed 7321 times
Échap key - IBM 1989, Unicomp 2016
Échap key - IBM 1989, Unicomp 2016.jpg (1.19 MiB) Viewed 7321 times
Still, at about 2 $ a keycap, it's worth a shot.
Regards,
Darkshado
emdude
Model M Apologist
09 Sep 2016, 05:00
Yes, I'm personally a bit nit-picky about the legends of their key caps, but on their own, they aren't so bad. The alignment is definitely an issue, a common one, that bothers me a lot more.
Here is an RGB set that I purchased from them in January, compared with mods from a 1391401:
Unicomp sent me a replacement set, but it was hardly better.
Techno Trousers
100,000,000 actuations
09 Sep 2016, 05:21
I think what bothers me most about the Unicomp caps is that their "pebble and pearl" doesn't match color with the original IBM variety. So it really sticks out when you try to mix and match.
LewisR
09 Sep 2016, 05:40
emdude wrote: Yes, I'm personally a bit nit-picky about the legends of their key caps, but on their own, they aren't so bad. The alignment is definitely an issue, a common one, that bothers me a lot more.
That's more terrible than I expected.
hypkx
Chasing the Dream
09 Sep 2016, 07:39
I experienced the same, also there was some colour differences between keys (different shade of green between the shift keys) and a really muddy looking red on a ESC keycap.
Wodan
ISO Advocate
09 Sep 2016, 09:10
Oh wow those caps look like they were all out of f'cks to give when they made them ...
Return to “Other external”
