Alps Appreciation
directheatedtriode
15 Jul 2017, 03:37
directheatedtriode wrote: This is my experience so far with SKCM blue- the switches feel very smooth, very slightly smoother than SKCM orange though I think I would need to do a back and forth comparison between the two to notice that difference. Also on my M0116 they are not as forgiving to off center keypresses and require a bit more effort, with this blue board I can make off center key presses and it still feels fine and not much effort is needed to press the keycap.
The switches do feel a bit "sticky". Hard to describe but it feels like there is a molasses sort of feeling when typing on it and I can only feel it when typing rapidly. It feels completely normal when just pressing single keys. And this is extremely minor. I am not sure if this is just due to the heavier weighting comparing to the SKCM orange or the switches need a good cleaning.
I'm just wondering if this is what people describe when they say that Alps blue switches are very smooth? Because there is a complete lack of any scratchiness at all; something I did notice on my modern MX Blue keyboard quite a bit.
Damn, that crisp tactile actuation point/sound and snap followed by the rapid bottom out and sound is just so satisfying :o It was nice to hear in videos, and I can't help running my fingers along ASDF (you know that tapping motion people do with their fingers going from pinky to index when they are impatient) when I'm not typing something.
Sorry to quote myself. The more I use these switches the more this "molasses" like feeling is starting to feel a bit more normal?
15 Jul 2017, 11:24
My question is then; who makes all these other keycaps? There can't be THAT many companies that do it, right?
15 Jul 2017, 13:20
//gainsborough wrote: I hadn't noticed the rounded corners, that definitely makes them easier to identify. The second from the left keycap I believe is a monterey keycap!
I don't know who made it, but yes it is from a Monterey K102.
Chyros wrote: My question is then; who makes all these other keycaps? There can't be THAT many companies that do it, right?
Tai-Hao don't know who made those keycaps that look like theirs. There are a number of very distinct product ranges, as you can see from the photo — I listed some of the known brands under [wiki]Double-shot moulding[/wiki]. Topre is also listed there, but I doubt Topre make them, and I should probably remove them.
I see that Key Tronic isn't covered, but should they be? BTC used completely identical keycaps for a while, suggesting that Key Tronic sourced theirs from a third party and that BTC then used the same third party. However, BTC could have simply copied them just as how Tai-Hao made a faithful replica of old Cherry keycaps including the typeface.
There are various companies whose keycaps are fairly distinctive, but the OEM is not known. I got the feeling that GRI and MEI may have shared an OEM, but no, they're different:
GRI: https://www.flickr.com/photos/123564336 ... 377873472/
MEI: wiki/File:Acorn_Atom_--_keycaps_pulled.jpg
At some stage I should be getting a pile of old Clare/Pendar keycaps from NSI, which I can inspect, to see if those match anything.
The typical mix of in-house tooling vs outsourced supply is as complicated as it always is.
15 Jul 2017, 14:50
Sweet that Acer of yours mike52787!
Thanks for the Tai-Hao research Daniel, another small step in the endless Alps vortex / puzzle. Honestly it does not suprise me that there was at least one other manufacturer. I'll have to check if I have the diagonal strut type here.
Menuhin
17 Jul 2017, 01:22
Have been procrastinating on this challenging cleanup task for a few months...
17 Jul 2017, 01:44
Surprising how much variation there is in those blues ....
mike52787
Alps Aficionado
17 Jul 2017, 04:33
Menuhin wrote: Have been procrastinating on this challenging cleanup task for a few months...
So you want to attempt the impossible... :O are those taobao blue alps? THE WORST!
Menuhin
17 Jul 2017, 08:21
Yep, from a 'broken' IBM keyboard.
May need to get some help from ultrasonic cleansing.
Wingklip
17 Jul 2017, 09:05
Menuhin wrote: Yep, from a 'broken' IBM keyboard.
Where do these fake "IBM"'s come from?
Menuhin
17 Jul 2017, 09:48
These "fake" IBM keyboards were manufactured by IBM Japan, where they decided not to use the buckling spring key switch mechanisms.
Wingklip
17 Jul 2017, 15:55
What the hell, are they model m's? What model number?
mike52787
Alps Aficionado
17 Jul 2017, 15:58
Wingklip wrote: What the hell, are they model m's? What model number?
They have the same PN as the common pc compatible m101 with a metal badge, 1390131. however the cases do not fit a normal model M, and the plates do not fit in a normal model M case.
directheatedtriode
17 Jul 2017, 19:44
What are TaoBao blue alps?
mike52787
Alps Aficionado
17 Jul 2017, 19:47
Simple, blue alps that came from taobao, and had been lying in some chinese junkyard submerged in mud and dirt. some of the absolute worst switches I have ever had, both in feel and condition.
Menuhin
17 Jul 2017, 20:24
mike52787 wrote: So you want to attempt the impossible... :O are those taobao blue alps? THE WORST!
Not good even after ultrasonic cleaning?
I kind of agree that this seller probably stores these switches in conditions like those in the junkyard - exposure to humidity and large temperature change and dust and sunlight.
mike52787
Alps Aficionado
17 Jul 2017, 20:27
Menuhin wrote: Not good even after ultrasonic cleaning?
I never attempted ultrasonicing mine, I simply threw away the top housings and sliders, they were beyond repair. I know other people who have ultrasoniced them, and they say that it does not completely remove the scratchiness or the bind.
directheatedtriode
17 Jul 2017, 20:32
mike52787 wrote: Simple, blue alps that came from taobao, and had been lying in some chinese junkyard submerged in mud and dirt. some of the absolute worst switches I have ever had, both in feel and condition.
The shade of blue on them (almost a greyish on some of the switches) makes it look like they are real SKCM?
mike52787
Alps Aficionado
17 Jul 2017, 20:34
Where did I ever say they were not genuine SKCM Blue alps? I was simply saying where they came from and the fact that they were in utter shit condition.
//gainsborough
ALPSの日常
17 Jul 2017, 21:07
fohat wrote: Surprising how much variation there is in those blues ....
This! That's crazy. No way they come with this much variation from the factory, right? This has to be sunbleached, I'd imagine.
directheatedtriode wrote: The shade of blue on them (almost a greyish on some of the switches) makes it look like they are real SKCM?
They are real SKCM blue. They got the name "TaoBao Blues" based on where they come from. They are stereotypically considered to be in absolutely awful condition.
directheatedtriode
17 Jul 2017, 21:17
Gotcha I thought you meant they were a TaoBao clone.
17 Jul 2017, 21:55
Menuhin wrote: These "fake" IBM keyboards were manufactured by IBM Japan, where they decided not to use the buckling spring key switch mechanisms.
What leads you to believe this?
Menuhin
17 Jul 2017, 22:10
It sounds like Daniel wants to correct some imprecise information I stated in that sentence. :oops:
Please just let us know what is instead correct according to your years of investigations on keyboards and key switches. ;)
To answer your question directly: skimming of DT and GH posts about Alps, not super thoroughly - like reading newspapers' headlines and then first, second, and last paragraphs only.
directheatedtriode
17 Jul 2017, 22:19
$103 for an Apple M0116 mentioning SKCM orange in the title: http://www.ebay.com/itm/Vintage-Apple-M ... 2578829851
Jeez are these the next SKCM to blow up in popularity? :?
mike52787
Alps Aficionado
17 Jul 2017, 22:26
directheatedtriode wrote: $103 for an Apple M0116 mentioning SKCM orange in the title: http://www.ebay.com/itm/Vintage-Apple-M ... 2578829851
it is only due to the condition. people who collect vintage apple computers want the keyboards as well, and this is an especially nice condition example. yellowed ones still can be had for $40-$50.
Mattr567
17 Jul 2017, 22:39
Yep, I ultrasonic'd mine, lubed, did EVERYTHING I could to fix them. They ended up OK I guess, but off center keypresses were still bindy.
Yours look to be in better condition than mine were :o
After everything:
Tuntematon
17 Jul 2017, 22:50
Still too much. Nice condition, but no box, slight yellowing and no guarantee of switch condition.
Not as bad as this lunacy though :o
http://www.ebay.com/itm/Apple-Extended- ... SwwzhZUGte
17 Jul 2017, 23:13
Menuhin wrote: To answer your question directly: skimming of DT and GH posts about Alps, not super thoroughly - like reading newspapers' headlines and then first, second, and last paragraphs only.
Apart from the iffy badge, as I recall there was no clear identification of any kind on these keyboards. As has been noted, IBM were extremely particular about part numbers, so I must agree with the sentiments that it's not likely that IBM would recycle a part number for a totally different design of keyboard. Also, I would expect at least something inside the keyboard to have IBM markings.
While generally Far East products stop short of actually violating trademarks, the bizarre [wiki]Aristotle Yellow[/wiki] switches do appear to have counterfeit Cherry MX mouldings complete with dodgy Cherry logos. As such, it seems perfectly possible that the IBM badges are counterfeit.
We can rule out Alps as they always had recognisable codes on the PCBs, and we appear to be able to rule out IBM on the grounds of the part number abuse it would require. As I understand it, so far as keyboards were concerned, IBM Japan generally subcontracted to other manufacturers.
I can't find more than one topic showing pictures though — like most things keyboard-related the details are scattered in far-flung places due to persistent disorganisation.
Menuhin
18 Jul 2017, 01:05
Ah.... so you are referring to some parts of this sentence, especially the "IBM" part, and "manufactured by IBM Japan" part.
...manufactured by IBM Japan, where they decided not to use the buckling spring key switch mechanisms...
I can try to check the PCB after I have desoldered all the switches. It was advertised with an IBM keyboard label.
Mattr567
18 Jul 2017, 01:35
Menuhin wrote: I can try to check the PCB after I have desoldered all the switches. It was advertised with an IBM keyboard label.
Its not made by IBM, thats for sure. Its some kind of Chinese clone. IBM never cloned part numbers, the fact that it shares a part number with a genuine M shows that its not genuine. I have one of these and I actually restored it :) Haven't posted it yet.
18 Jul 2017, 09:34
Interesting:
http://www.solutionsinplastic.com/keycaps-101/
Under bullet 15, "What Font is used on Signature Plastics’ standard keycaps?":
Signature Plastics wrote:Thus the font became known as Gorton Modified and was used to produce millions of keycaps for years for keyboard companies like Wyse, Wang, Oak Industries, Maxi Switch, Beehive and Honeywell, among others.
Honeywell keyboards with Signature Plastics/Comptec keycaps — something to watch out for.
