- macmakkara
What do you guys think how much original IBM APL caps are worth?
- Redmaus
- Gotta start somewhere
Need pics mate
- JustLiQuiD
- Main keyboard: Ducky Shine Mini II @home JD40 on the run :D
- Main mouse: Zowie AM-FG
- Favorite switch: MX Blue
- klikkyklik
- Main keyboard: Northgate Omni Key/102 w/Blue Alps
- Favorite switch: Blue Alps
A few of these are rubber domes, but ignoring those - if these were cleaned up to be in fair/average condition, what do you think the lot might be worth?
EW4KK R4018 (rubber dome?)
IBM M2 1395300 (7/20/1993)
HP 46020A
HP C3346-60201 (rubber dome?)
IBM 1391401 (5/19/1987)
Triumph FKB4700 (x3)
Focus FK-5001
Focus FK-2000
Leading Edge DC-2014 (blue Alps)
IBM 1390120 (1/6/1987)
APC-H412 (NEC blue ovals)
HP 46020A
Focus FK-5001
Focus FK-2000
- guk
- 1896 Vintage Reds
- Main keyboard: SSK,Novatouch
- Favorite switch: BS
?+20(m2 go rather cheap in the US and I doubt that this one can be cleaned completely)+20(both hp should be rd but the ones with the red on white, odd keycaps do sell on ebay)+1+35(doubts about "cleanability" too)+5+5+5+30+20(if white alps or clones, too yellowed)+80+75+30(pretty yellowed)
Rough estimates, depends too much on overall condition of the keyboards.
- Chyros
As for the rest, if you clean them and can get them working, I reckon the 2000 plus is worth about £ 20 depending on the switches and condition, the NEC something similar (these are too unknown as of yet so they keep turning up very cheaply), and the LE DC is by far the biggest prize, worth about £80 if the switches are in okay to decent condition (possibly more if in great condition). The M2 is probably faulty but may fetch £20 or so as a curiosity if it does. The FKBs are usually sold fairly cheaply, about £10 or so maybe.
- klikkyklik
Thank you for the responses, guys- I do appreciate it.
- Redmaus
Would like that blue alps board if possible for cheap price.
Certainly not cheap!
Could be impossible. You haven't shown the connector. Unless it is one of the handful people have decoded and adapted, you're on your own to work it all out. I've had a Honeywell terminal stranded for years now.
- Scottex
- Main keyboard: Realforce 55g TKL
- Main mouse: Logitech G500
- Favorite switch: IBM Beam Spring
alldayrelief
- Main keyboard: quark
- Favorite switch: clear
How much would a planck quark keyboard be worth with clears, dsa pbt caps, and a milled bottom case? Hand-wired.
Hello everyone.
I'm decided to sell 100 Gateron blue switches: 13 brand new and 87 desoldered from the keyboard, which are not used since I ruined the pcb.
I also want to sell the Calm Depths keycaps set, barely used and in great condition.
Only note: I had to glue the inserts in the stabilized keys, since the holes are a bit loose.
How do you think I should ask for them?
Picture of the keycaps: https://imgur.com/nBusW8I
Thanks.
Thanks.
- Prelim
- Main keyboard: GH60 rev.C, DS3 TKL, Dolch PAC, OG Cherry stuff
- Main mouse: Deathadder
- Favorite switch: 65g custom Cherry/Gats linear and still ISO lover!
the gateron pack (120 switches) on massdrop was around $40 so I think ~$30 would be a good deal for you, although in GH GB gaterons were sold way cheaper than that.
the calm depths set, it depends on condition so make sure the stabed caps are good to go... a bit less than GB price is also fair
- Azrael
- Main keyboard: Cherry G80-1000
Hey guys,
can anyone guess which would be a good price for this Made-in-Germany beauty "Preh MCI 96"?
its the USB version. Im looking to sell it.
Take care,
Azrael
Take care,
Azrael
- preh.jpg (16.33 KiB) Viewed 8272 times
- IMG_8442.JPG (879.81 KiB) Viewed 8272 times
Well, I got mine from Cindy for $25. But that's the same price I paid her for my SSK…
Anyway, I'd say say $25-$40 is a fair price for a working M2. There's plenty more that need their capacitors redone. That means a good supply of spare cases out there, if you want to go back to the stock look.
Hello everyone.
I got some spare pieces that I do not need, which are:
- Poker 2 stock pbt keycaps
- Part of a Vortex pbt+pom keycaps set, black color, basically the F-keys, the numpad keys and the other pieces I do not need on my 60%
- The top part of a Filco majestouch 2 tkl cover, black
- A backplate and 5 Costar stabilizers coming from a no longer working Wasd Code tkl.
The plate need a bit of cleaning and painting.
- A Filco cable mod and a green usb coiled cable, with usb-a connectors on both ends, made by Pexon.
I was wondering if this stuff is marketable, and how much coul it be worth.
Thanks.
Thanks.
I also have a Wasd code tkl controller and the micro usb connerctor.
I was wondering if they could be used to build a custom keyboard, and how much they could be worth in the case they are.
Here's a picture: https://imgur.com/okD9qxS
- hammelgammler
- Vintage
- Main keyboard: IBM Model F Unsaver
- Main mouse: G-Wolves Skoll
- Favorite switch: Buckling Spring (Model F)
Does anyone know what's a good price for a used IBM Model M15?
I may be able to get one, but I don't know what a good price is.
