Great/Interesting Finds
wadeak78
22 Nov 2020, 03:02
Interestingly the switches on that board seem to have 3 pins instead of the usual 4
hellothere
22 Nov 2020, 03:56
Cheapest Dasher I've seen in a while. $550 BIN. Includes the terminal.
Another black/grey BTC5100C. Now that I have one, I can recommend them. Tactile. Dome over slider. Pretty good price: $28 + shipping based on your location. Make sure it's not a 6 pin DIN.
MMcM
22 Nov 2020, 07:47
John Doe
22 Nov 2020, 13:54
ddrfraser1
22 Nov 2020, 13:58
John Doe
23 Nov 2020, 19:22
ddrfraser1
23 Nov 2020, 20:49
John Doe wrote: 23 Nov 2020, 19:22 https://www.ebay.com/itm/154207490260
MY-8300 worth a check.
That is an interesting specimen. The inconsistent yellowing and varying styles of the mods is bizarre.
Laundry_Hamper
27 Nov 2020, 01:04
hellothere
27 Nov 2020, 02:38
Solidly in the "Interesting" column, as this is $910 with shipping: Vintage Atex Copy Processing System Terminal News Keyboard
EDIT: I noticed that there was one switch pictured in the ad and it's labeled, "Micro USA." I'm relatively sure that these are Micro Switch SW/SD Hall Effect switches. (If I'm wrong, someone will be along momentarily to point that out :))
There's another Atex keyboard listed on this forum and it has Digitran Capacitive Leaf switches.
hellothere
27 Nov 2020, 02:59
"Never Used" IBM 3275/3277 Beam Spring. Currently 500 pounds sterling. 50 pounds for shipping. That's about $670 US and $67 shipping.
It'll be interesting to see how much this sells for. Ends in a week. Only 7 bids so far.
s-l1600 (2).jpg (219.93 KiB) Viewed 8173 times
EDIT: Sold for 2050 Pounds.
xxhellfirexx
27 Nov 2020, 05:30
hellothere wrote: 27 Nov 2020, 02:59 "Never Used" IBM 3275/3277 Beam Spring.
Incredible shine on spacebar. "Never used"
Riptide666
27 Nov 2020, 08:17
Love the two yellow double-shot keycaps. Never used.
hellothere wrote: 27 Nov 2020, 02:59 "Never Used" IBM 3275/3277 Beam Spring. Currently 500 pounds sterling. 50 pounds for shipping. That's about $670 US and $67 shipping.
John Doe
27 Nov 2020, 08:46
https://www.ebay.com/itm/UNCOMMON-amp-U ... 7675.l2557
mind to share abit about this whoever got it?
27 Nov 2020, 09:10
John Doe wrote: 27 Nov 2020, 08:46 https://www.ebay.com/itm/UNCOMMON-amp-U ... 7675.l2557
There are a few old threads about the "Comfort Keyboard"/"Comfort ErgoMagic"/"Comfort ErgoFlex":
viewtopic.php?f=45&t=22169
viewtopic.php?f=2&t=22715
And the manufacturer's web site is still up:
http://www.comfortkeyboard.com/keyboards_comfort.html
https://www.fentek-ind.com/Comfort-keyboard.htm
John Doe
27 Nov 2020, 10:30
Findecanor wrote: 27 Nov 2020, 09:10
Thanks, Findecanor. I didn't realise there's already a review, tho as one of Thomas's follower. :D
xxhellfirexx
29 Nov 2020, 02:21
hellothere
29 Nov 2020, 02:36
xxhellfirexx wrote: 29 Nov 2020, 02:21 Aristotle switches.
https://m.ebay.com/itm/Chicony-E8H51KKB ... 4557832735
I've bought from the seller before. No problems.
hellothere
29 Nov 2020, 02:39
MMcM
29 Nov 2020, 17:05
SD series with some triple-shots.
https://www.ebay.com/itm/313320230137
John Doe
29 Nov 2020, 18:04
Oh, no. I'm bidding it...
Riptide666
29 Nov 2020, 18:07
Don't waste money to bid too high lol. The original listing was the whole set with monitor, only a bit over 100usd.
:lol:
John Doe wrote: 29 Nov 2020, 18:04 Oh, no. I'm bidding it...
TNT
29 Nov 2020, 20:47
https://www.ebay.de/itm/124456001511?_t ... 1758.m4704
If it was someone of you guys who got this, mind helping out hasu with the XT-converter?
doomsday_device
29 Nov 2020, 21:01
TNT wrote: 29 Nov 2020, 20:47 https://www.ebay.de/itm/124456001511?_t ... 1758.m4704
pmd
TNT
29 Nov 2020, 21:21
doomsday_device wrote: 29 Nov 2020, 21:01
pmd
Wow, that was quick :mrgreen:
jgaynor
30 Nov 2020, 05:55
cheap pair of SSK (plastic?) plates with keycaps/barrels but no springs:
https://www.ebay.com/itm/143863939478
https://www.ebay.com/itm/143863947891
30 Nov 2020, 14:11
Interesting listings, but it is the external case is the single limiting component for the SSK.
ddrfraser1
30 Nov 2020, 16:21
Looks like it doesn't even have a pcb
cakeanalytics
30 Nov 2020, 17:07
And both barrel plates are cracked. At this point you might be better off just chopping a regular M barrel plate.
The keycaps should be worth something though.
inmbolmie
30 Nov 2020, 17:56
jgaynor wrote: 30 Nov 2020, 05:55 cheap pair of SSK (plastic?) plates with keycaps/barrels but no springs:
They look like if they were rescued from the deepest dungeons of Computer Reset. Hey! even the seller is in Texas! Maybe...
John Doe
01 Dec 2020, 13:28
Riptide666 wrote: 29 Nov 2020, 18:07 Don't waste money to bid too high lol. The original listing was the whole set with monitor, only a bit over 100usd.
:lol:
150$ should be high enough, glad to see someone will take it.
Return to “Other external”
