Post your keyboard/keycaps!
shreebles
Finally 60%
28 Mar 2018, 10:46
hansichen wrote: For now I'll use the board to test 60% layouts so that I'm prepared for the case by Plastikschnittstelle. In future this board may purpose as a travel board. The silent blacks are really smooth and they are even more silent than expected, a perfect board for open workspaces.
I've used nothing but silent reds for the last 4 months. I haven't been active in any keyboard community.
They are great if you want an install-and-forget Switch, and (since I travel a lot) it's so quiet that it's the first keyboard I can actually use anywhere without attracting too much attention. If I could choose only one switch forever, it would be this one.
And they are great if you want to give yourself (and your wallet) a break from the hobby. You become allergic to clacking. Other mechs need not apply. Most Topres are louder.
ramnes
ПБТ НАВСЕГДА
28 Mar 2018, 11:04
Your left Alt seems broken. ;)
shreebles
Finally 60%
28 Mar 2018, 11:08
ramnes wrote: Your left Alt seems broken. ;)
It's intentionally broken.
If you consider this broken, consider the shape of the human thumb broken. :D
(or, has others have already realized, regular keyboard design does not follow human ergonomics)
hansichen
28 Mar 2018, 11:41
shreebles wrote:
hansichen wrote: Most Topres are louder.
I didn't expect that but I have to agree. My unsilenced realforce is louder and the silenced one is probably around the same, the only "issue" on mx boards is the sound of the space bar and other stabilized keys but with some modification those keys are very silent too.
shreebles
Finally 60%
28 Mar 2018, 12:14
hansichen wrote: [...]the only "issue" on mx boards is the sound of the space bar and other stabilized keys but with some modification those keys are very silent too.
See the little translucent plastic bit under the space bar? That's a QMX Clip, designed to make PCB-mounted switches silent. It's far less amazing than the MX silent switches but both can be combined to make a rather quiet space bar (since the space bar is the only PCB-mounted switch on this keyboard)
As for the stabilizers, the metal bars should be lubed where they clip into the plastic, use a thick lube to eliminate rattle.
thokir
28 Mar 2018, 12:40
shreebles wrote: See the little translucent plastic bit under the space bar? That's a QMX Clip, designed to make PCB-mounted switches silent. It's far less amazing than the MX silent switches but both can be combined to make a rather quiet space bar (since the space bar is the only PCB-mounted switch on this keyboard)
How does a qmx clip make a silent switch even more silent? I mean, basically the silent switches should be silent and dampened, the only thing I could imagine the qmx clip does in addition is reducing the wobble a little bit.
On my kbd75 with silent blacks and strongly greaded stabs there is no way to get anything (beside of the little scratchy sound of the switches) quieter... pcb mounted stabs, plate mounted switches. My planck with plate mount blacks and qmx clips is very loud when comparing them next to each other :)
hansichen
28 Mar 2018, 12:43
A qmx clip should reduce the travel so you can't really bottom out those switches. So maybe you don't push the stab all the way down with qmx clips and therefore the sound of the stab is reduced. On the switch itself it shouldn't make that much of a difference.
thokir
28 Mar 2018, 12:49
hansichen wrote: A qmx clip should reduce the travel so you can't really bottom out those switches. So maybe you don't push the stab all the way down with qmx clips and therefore the sound of the stab is reduced. On the switch itself it shouldn't make that much of a difference.
Hmm, good point. Though I didn't notice my stabs being loudest on bottom out... I guess I have to try the qmx clip on my g80 later. The stabs can be heard like 3 rooms away currently.
shreebles
Finally 60%
28 Mar 2018, 12:54
I cannot say why, as I am unfortunately no longer very interested in keyboard science due to a lack of time.
But I can say that I compared the sound of my silent red space bar with and without the clip and found the sound more pleasant with the clip.
davkol
28 Mar 2018, 14:09
derp
RaleghDirat
Prisoner of Technology
29 Mar 2018, 12:28
Desktop upgrade:
From
Cherry:
To Siemens:
Khers
31 Mar 2018, 19:47
Easter meant some time to build this thing that arrived earlier this week:
Laser
emacs -nw
31 Mar 2018, 23:24
Latest build, Tada68 with Aliaz switches 60g (silent, tactile) and Dasher SA keycaps.
zslane
01 Apr 2018, 01:10
That looks hot!
I'm really curious what typing on it sounds like.
Laser
emacs -nw
01 Apr 2018, 13:14
It doesn't sound like ... much, i.e. the keys are pretty silent, and all you can hear is some kind of hhhhrrrrffffffffffrrrrrrrrrrhhhhhrrrrr punctuated by the sound of the spacebar (which is somewhat louder due to the stabilizers), or, rarely, by those of the other stabilized keys (left shift, enter etc.).
Khers
05 Apr 2018, 20:05
One layout to rule them all
Love grows where my function key goes
Etcetera
16 Apr 2018, 17:36
Wingnut @ Varmilo VA69M:
chzel
16 Apr 2018, 17:43
Look who's showing off! First one is nice! What's that under the keyboard?
16 Apr 2018, 17:49
chzel wrote: Look who's showing off! First one is nice!
Thanks, sure why not it's not like I've been posting anything.
chzel wrote: What's that under the keyboard?
I set the Varmilo on my Ducky acrilic wrist rest because I like the height better. The MX reds are nice in that metal case!
18 Apr 2018, 12:23
Enjoying my XT...
pr0ximity
18 Apr 2018, 12:48
Quite like this one, enjoyPBT Cyrillic and the artisan that came with Hammer's GMK Red Alert set, snow day in the background:
Flickr
18 Apr 2018, 12:52
pr0ximity wrote: Quite like this one, enjoyPBT Cyrillic and the artisan that came with Hammer's GMK Red Alert set, snow day in the background:
Very nice, thanks for sharing.
mike52787
Alps Aficionado
18 Apr 2018, 16:38
Flickr
I dont know why... but I just cant get on with the legends on the mods that epbt uses. The rest of the set looks nice, but the mods totally kill it for me.
Blaise170
ALPS キーボード
18 Apr 2018, 18:18
Mountain Dew Escapism (Alps). Unfortunately the stem snapped a couple of years ago so I'll have to try and repair it with another stem at some point.
18 Apr 2018, 18:22
Oh nice, I own a Matias mini tactile pro also. Havn't used it in along time though.
enrique.aliaga
19 Apr 2018, 00:12
My beloved HHKB with some KBDFans blanks for the “arrow keys”. This is the board I currently use at work (I’m constantly switching).
pr0ximity
19 Apr 2018, 03:00
Flickr
Really? Never heard that before. They're the same (or extremely similar) to original Cherry legends. I quite like them for that reason.
cookie
19 Apr 2018, 17:30
enrique.aliaga wrote: Image
How are the KDBFans blanks compared to the original ones?
I am totally into the arcade font set, seems they will release mods for it soon.
enrique.aliaga
19 Apr 2018, 17:44
They are slightly more textured. I like that, though.
Also, they produce a significantly louder sound as compared with the stock caps. I don't really know why this is, since the KBDFans caps appear to be the exact same thickness as stock.
Beware with the spacebar, though. My KBDFans spacebars feel mushy, that's why I had no other choice but to keep using the stock ABS one that you see in the picture, which doesn't have this undesirable trait.
Any idea of what to do to make it feel right?
In conclusion, I really like these keycaps, except for the spacebar.
Iggy
19 Apr 2018, 18:11
My RealForce RGB.
