Great/Interesting Finds
thefarside
23 Feb 2023, 18:10
Not sure what the switches are like but here’s a Datacomp / Dauphin DCK-84 with tall black SKFR alps:
https://www.ebay.com/itm/255989407026
Dingster
23 Feb 2023, 19:09
engr wrote: 23 Feb 2023, 16:21 The prices for DC-3014s are getting insane. A few years ago you could get a NOS one in that price range.
Just because someone is asking an absurd amount doesn't mean that's the price. You have people asking over 1000$ for ordinary model Ms and that's not an "absurdly priced board" :P
engr
23 Feb 2023, 20:31
Dingster wrote: 23 Feb 2023, 19:09 Just because someone is asking an absurd amount doesn't mean that's the price.
Yes, but DC-3014 have actually been sold on eBay at pretty steep prices recently, like $500 or so.
TessierAshpool
24 Feb 2023, 21:45
ArtyomTheMetroHopper wrote: 06 Dec 2022, 12:23 Found this thing on Japanese yahoo auctions:
https://www.jauce.com/auction/x1060733880
Its way too expensive for my taste but it appears to be a touch screen IBM with editable layout :shock:
Whoa, never seen one of those before! Any idea what kind of connector that is?
25 Feb 2023, 01:09
TessierAshpool wrote: 24 Feb 2023, 21:45 Whoa, never seen one of those before! Any idea what kind of connector that is?
Looks to be a (regular IBM-issue) SDL socket:
Unusual to see it alongside a mains plug!
25 Feb 2023, 13:14
thefarside
25 Feb 2023, 20:20
I thought this IBM 2260 was interesting. Seems to use a Selectric-style mechanism instead of beam springs:
Link to listing: https://www.ebay.com/itm/125789594914
25 Feb 2023, 20:26
Aw, so cute!
Scarpia
26 Feb 2023, 12:49
Wow, look at those keycaps!
thefarside
06 Mar 2023, 16:25
Symbolics keyboard:
https://www.ebay.com/itm/115723621634
inozenz
06 Mar 2023, 16:43
thefarside wrote: 06 Mar 2023, 16:25 Symbolics keyboard:
im not sure, is it really worth that much? i mean there are plenty good space invader keyboards.
thefarside
06 Mar 2023, 20:32
inozenz wrote: 06 Mar 2023, 16:43
Not worth it for me. For the money I’d get a Keymacs version, but I’d have a hard time with the layout.
06 Mar 2023, 20:55
inozenz wrote: 06 Mar 2023, 16:43 im not sure, is it really worth that much? i mean there are plenty good space invader keyboards.
Is it worth it? That all depends on who you ask. Anything Symbolics related is highly sought after even in bad condition. At least replacement Space Invader switches are available to refresh this keyboard. Also for someone with the actual hardware and needs a keyboard there isn't much alternative.
thefarside
07 Mar 2023, 16:53
I thought this was interesting. It looks like this F122 was converted to an M122? I first thought it was an F122 because it has the black metal bottom case:
But after looking at the label it appears to be converted to a Model M:
I don’t know much about the 122 key battleships, but am curious if that means they would have replaced the entire internal assembly, or just the PCB, foam and flippers?
Link to listing: https://www.ebay.com/itm/285172996458
07 Mar 2023, 17:11
thefarside wrote: 07 Mar 2023, 16:53 But after looking at the label it appears to be converted to a Model M:
That is wild. I've seen a number of F122's mistakenly labeled as Model M's but never one as being labeled as converted to a Model M with a specific part number. It does have the right angled keyboard cable connector that matches what a type II M122 has with this part number. Maybe it is still a Model F at heart but with slight modifications such as the controller and cable. That would be the best scenario for any prospective buyer but of course is mere speculation at this point.
07 Mar 2023, 22:58
JP! wrote: 07 Mar 2023, 17:11
That would be my guess, too. One possibility is that the controller was modified to allow the earlier Model F to work on a somewhat later processor that usually expected to be talking to a Model M.
thefarside
08 Mar 2023, 04:10
fohat wrote: 07 Mar 2023, 22:58
Forgive my ignorance, but do the Model F and M battleships talk to different terminals/computers? I always thought it was the switch type that differentiated between F and M, but could see the controllers also being a factor.
I asked the seller for a closeup of the barrel with the cap removed but I’m not hopeful I’ll get a response.
08 Mar 2023, 05:48
thefarside wrote: 08 Mar 2023, 04:10 Forgive my ignorance, but do the Model F and M battleships talk to different terminals/computers? I always thought it was the switch type that differentiated between F and M, but could see the controllers also being a factor.
Not sure on all of the nuances but I think most early M122's and most F122's are generally compatible with various terminal models. The type I M122 uses the same connector (240 degree 5-pin DIN) as an F122 and the type II M122 is essentially same thing but with a right angle connector. What distinguishes an F from an M is not the switch type as they both use the famous bucking spring mechanism but rather the primary difference comes down to the internal construction. The F uses a curved metal plate and a capacitive PCB for sensing while the Model M is the later design conceived as a cost saving measure and uses a plastic barrel plate and a membrane sheet for sensing. The F uses larger black flippers and has slighly lighter springs.
wiki/IBM_122-key_terminal_keyboards
wiki/IBM_Model_F#IBM_122-key_Model_F_Keyboards
thefarside
09 Mar 2023, 23:48
I know barely a thing about Cherry MX but I remember hearing about mystical Nixie switches. Is this Nixdorf one of the mythical boards?
Link to listing: https://www.ebay.com/itm/125798286969
10 Mar 2023, 07:10
thefarside wrote: 09 Mar 2023, 23:48 I know barely a thing about Cherry MX but I remember hearing about mystical Nixie switches. Is this Nixdorf one of the mythical boards?
No.
The "mythical" switches have a translucent switch top:
wiki/Cherry_MX_Black#Nixie_2
thefarside
10 Mar 2023, 14:58
Thanks! Meant to say “mythical” but didn’t catch it before posting. Damn iPhone audio transcription!
10 Mar 2023, 16:36
You're speaking your posts? And I thought I was nutty for tapping many of mine on my phone! :lol:
Back on topic: Nixies are indeed mystical because they are superb. Supposedly, they are simply Cherry MX blacks of a certain noble vintage, with the helpful identifier of Nixdorf's mysterious demand that they all have a clear top shell. (What were they up to?) A Nixdorf board with regular black topped MX blacks may well have switches of a similarly good age, so I'd consider taking a punt on it in any case. They won't be worth nearly as much as iconic clear topped Nixies, but they may be just as good, for all I know…
thefarside
10 Mar 2023, 21:37
Muirium wrote: 10 Mar 2023, 16:36 You're speaking your posts? And I thought I was nutty for tapping many of mine on my phone! :lol:
Yes, 99% of the time if I can (like this reply) I will speak, and I often forget to check what Siri has interpreted! :?
Nixie’s sound interesting and I’d take a shot at this board to see what vintage MX blacks are like, but shipping is too high for me.
10 Mar 2023, 22:05
thefarside wrote: 10 Mar 2023, 21:37
I will speak
Blasphemy! This is a proper KEYBOARD forum!
thefarside
11 Mar 2023, 00:55
fohat wrote: 10 Mar 2023, 22:05
I will speak
Sorry I should have added that it’s when I’m on my phone. Rest assured on a computer everything I write is on an alps or buckling spring, and I write often!
11 Mar 2023, 01:20
thefarside wrote: 10 Mar 2023, 21:37 I often forget to check what Siri has interpreted! :?
Nixie’s …
Impressed she understood Nixies. So impressed I’m dubious!
thefarside
11 Mar 2023, 02:41
She did! Along with Nixdorf!
zrrion
12 Mar 2023, 01:12
fohat wrote: 10 Mar 2023, 22:05Blasphemy! This is a proper KEYBOARD forum!
we have a board for mice so I think clicking on an on-screen keyboard would work too
kmnov2017
14 Apr 2023, 15:04
Hahahahah
https://www.ebay.com/itm/175688521398
14 Apr 2023, 15:15
Think how much it would cost with an Xwhatsit already installed. :D
Nice setting, btw.
Mine just works in front of a screen for a living.
Return to “Other external”
