Modern switch closest to the Alps Salmon or Oranges switches in the AEK
- fohat
- Elder Messenger
- DT Pro Member: 0158
Yes, there are differences. I think the earliest ones have salmon ALPS and also PBT key caps - these are highly desirable. I think that the PBT caps outlasted the salmon switches by some time, but my memory may be weak on all this.
The rubber dome variant has an "R" in the model number. I had one once but can't remember whether the key caps are ALPS-compatible.
- engr
But these were AT101, not AT101W. I'm pretty sure all the variants with Windows keys had black Alps.fohat wrote: 16 Nov 2023, 21:23 Yes, there are differences. I think the earliest ones have salmon ALPS and also PBT key caps - these are highly desirable. I think that the PBT caps outlasted the salmon switches by some time, but my memory may be weak on all this.
- engr
I've done it before (on an AT101W, as it happens) and I would probably not do it again. I find it less tedious to swap entire switches (if you are comfortable with soldering/desoldering and have a good desoldering gun).sliceoflemon wrote: 16 Nov 2023, 10:58 Correct me if I'm wrong, but the difference between the black and orange alps mostly comes down to the slider, click leaf and possibly the spring isn't it? Wouldn't it then be simpler to switch (no pun intended) those between the Dell AT101W switches and the ones in the AEK and achieve the same thing?
- Main keyboard: Matias Quiet Pro
- Main mouse: Logitech Something
- Favorite switch: Orange alps
I guess I'm the other way around. I can solder but don't have a desoldering gun, so it takes a lot longer for me to swap switches. I don't mind opening up alps style switches so I tend to go that way by default.engr wrote: 16 Nov 2023, 22:39I've done it before (on an AT101W, as it happens) and I would probably not do it again. I find it less tedious to swap entire switches (if you are comfortable with soldering/desoldering and have a good desoldering gun).sliceoflemon wrote: 16 Nov 2023, 10:58 Correct me if I'm wrong, but the difference between the black and orange alps mostly comes down to the slider, click leaf and possibly the spring isn't it? Wouldn't it then be simpler to switch (no pun intended) those between the Dell AT101W switches and the ones in the AEK and achieve the same thing?
I just suggested it in case OP is more comfortable that way.
- Main keyboard: Apple Extended Keyboard (Salmon Alps)
- Main mouse: Kensington Slimblade Trackball
I just bought a Dell AT-101W off eBay. It will be here on Monday.
If it’s rubberdome: bounce it back!
If not, congratulations, and good luck with the desoldering. Obviously give the board a little time, stock, first. You want to learn its foibles, and to give its native switches enough time to charm you.
I'm in no mood to take on a soldering and desolder project now. I'll use it stock with a Soarer's Converter.
- funkmon
- Main keyboard: Unicomp Model M
- Main mouse: Razer Deathadder
I don't think so. I think the rubber domes were introduced with the Quietkey branding, but we've all been wrong before.
- fohat
- Elder Messenger
I have owned these keyboards although it was some years ago. My experience is that the Dell AT101R (and presumably the ISO variant AT102R) is the rubber dome version.
I have had several Dell Quietkey keyboards and the earlier ones from Malaysia (or was it Indonesia?) were excellent, some of the best rubber domes ever. They had colored "domes" in yellow or blue set into a transluscent sheet. To me, the later ones made in China were inferior.
The Big Foot is here.
This is a nice board. A little yellowing, but not too bad.
Took me about 20 min to find my Soarer's Converter before I could use the thing. But, so far so good. It will get a good workout as I work tomorrow.
Black Alps, right? As you didn't mention the switches, I anticipate a mixed review.
Black Alps can actually be quite good. Love the key-feel of my NeXT, for instance, but it's a good bit older than any Windows keyed PC board (and NOS).
- Main keyboard: Matias Ergo Pro w/ Salmon ALPS + white PBT keycaps
- Main mouse: M570
- Favorite switch: ALPS Orange, Salmon, Blue
The suspense is killing me! lol. Rubber domes I guess...
They are Black Alps. I like them. I like the Salmon Alps better. But not so much so that I would be willing to go through the effort of transplanting them between keyboards.
Rollover?
I haven't needed to experiment much with key rollover. I've just been typing away while I work and haven't had any issues.
It took me an hour to find my Soarer's Converter. I had it on my desk. It fell down and behind my computer. I'd forgotten how much I prefer the Soarer's Converter over QMK/VIAL.
- Main mouse: M570
Thanks for the update!
I always wanted Orange ALPS but ended up with Salmons. I have gotten used to the slightly stiffer springs, but had thought of replacing the springs with aftermarket ones that are a bit weaker to match the softer feel of the Oranges. But then decided I'd probably just mess up a bunch of my switches taking them all apart like that and didn't bother.
- Main keyboard: AEKII
That merger is the one thing that annoys me about the AEKII. My ISO AEKII isn't even labeled with Alt Gr.
Not to drag us offtopic, but there were PC compatability cards available at the time for the SE and Mac II.Muirium wrote: 16 Nov 2023, 14:15 That's not the only goof about the AEKs. See those Num Lock and Scroll Lock LEDs? They indicate states which don't exist on the Mac, so would never light. They seem to have been intended as PC compatible, yet the AEK is of course ADB so couldn't connect to a PC with the use for them.
I think part of the reason for those lock lights may have been because they were using a generic ALPS circuit board they used when making keyboards for a number of vendors. I know my ADB to USB converter will throw on the Caps Lock and Numlock lights when used on a PC.
