Nice, I was watching that listing, and I might have bid if it had double shot caps and a 2u backspace. I'm getting picky in my old age. The seller must have several of these; they put up another listing as soon as the original one ended.xicanoink wrote: 30 May 2019, 21:44 So I lost the bid war at first and was sad due to missing out on this handsome fellow.
But later that night got a second chance offer! The bid winner must've flaked.
Thank the stars he did!
Mint condition black case KB-6251EA, metal backplate, pine white Alps so fresh and brand new that the click sounds deep and satisfying and a close challenger to a blue Alps board I'm currently cleaning. Right now it's hard to choose which one I like better.
Good problem to have right?
I know I drooled over the black FK-2001 so I'm stoked to have my own black white Alps board.
Are there any other known boards with unique case coloring that also have Alps switches?
Alps Appreciation
- Polecat
- Chyros
Ah yes, that green one. Nice to see it made it into good hands
I know of very few interestingly coloured Alps boards, to be honest. That transparent mac thing barely qualifies, I think xD . Closest I have is that red FLAGK Iori board, and the black Pioneer board with grey, mint-green and purple legends (which isn't even SKCM, just Alps-compatible).
xicanoink
- Main keyboard: Realforce 87UW55
- Main mouse: Kensington Expert Trackball
- Favorite switch: Topre
- DT Pro Member: 0236
Unfortunately, they're not. Got a textured feel to them and attract grease easily. Can also feel the texture of the print, especially on the right Shift key.
xicanoink
And of course that beauty, that black FK-2001 of yours.Chyros wrote: 31 May 2019, 13:00 Ah yes, that green one. Nice to see it made it into good hands.
- Drclick
- Main keyboard: HHKB
- Main mouse: logi anywhere 2s
- Favorite switch: Brwon
Really weird keyboard, I thought they were normal SKCM blues.
But most of them have 'FD' logo on the bottom! (not SKBM, grey switchplate)
Unfortunately, I thrown out the PCB yesterday, so no more useful information
- Chyros
Ah yes, my baby <3 ^^ .xicanoink wrote: 31 May 2019, 16:17And of course that beauty, that black FK-2001 of yours.Chyros wrote: 31 May 2019, 13:00 Ah yes, that green one. Nice to see it made it into good hands.
I know of very few interestingly coloured Alps boards, to be honest. That transparent mac thing barely qualifies, I think xD . Closest I have is that red FLAGK Iori board, and the black Pioneer board with grey, mint-green and purple legends (which isn't even SKCM, just Alps-compatible).![]()
- Polecat
Hokey smokes, Bullwinkle! Are those pre-Alps blues? Perhaps ForwarD Electronics? (...according to their website Forward Electronics was formed by Alps and Chung Hua in 1970...) Quite the find, I'd say. Could this explain why the early upper housings were unbranded?Drclick wrote: 31 May 2019, 17:51 Really weird keyboard, I thought they were normal SKCM blues.
Unfortunately, I thrown out the PCB yesterday, so no more useful information![]()
- //gainsborough
- ALPSの日常
- DT Pro Member: 0188
so to be clear, the only switches with the complicated switchplate are the ones with the "alps" logo on them? Or do the internals of these switches look exactly the same?Drclick wrote: 31 May 2019, 17:51
- Polecat
My latest purchase, a Laser white SKCM board. It has been used, but minimal shine and no yellowing. And more importantly no crud inside. I don't think it had ever been opened before. I wish the Lasers had serial numbers. I didn't know my other one was really a Monterey K102 until I asked about it here, and I had been using Monterey K104 keyboards just about forever.
- After a 30 second wipedown with a damp cloth.
- DSCN0425.JPG (818.41 KiB) Viewed 14684 times
- Thirty years of dust, that's it!
- DSCN0432.JPG (789.22 KiB) Viewed 14684 times
- My blue SKCM Laser was lonely until now...
- DSCN0435.JPG (825.89 KiB) Viewed 14684 times
- JP!
- DT Pro Member: 0194
- Drclick
Pretty sure 'FD' means ForwarD Electronics. I don't think they are pre-Alps blues, some early blues have black switchplate, as far as I know.Polecat wrote: 31 May 2019, 23:31 Hokey smokes, Bullwinkle! Are those pre-Alps blues? Perhaps ForwarD Electronics?
They look exactly the same except the bottom logo.//gainsborough wrote: 31 May 2019, 23:46 so to be clear, the only switches with the complicated switchplate are the ones with the "alps" logo on them? Or do the internals of these switches look exactly the same?
And I found a same case here
- Polecat
Interesting reading, thanks for the link! So it's sounding more like the FD-branded lower housings may have been from an alternate factory. Again note that Forward was an entity created by Alps and Chung Hua, so it's not surprising that Alps would use their factory to make some of their switches:Drclick wrote: 01 Jun 2019, 03:16Pretty sure 'FD' means ForwarD Electronics. I don't think they are pre-Alps blues, some early blues have black switchplate, as far as I know.Polecat wrote: 31 May 2019, 23:31 Hokey smokes, Bullwinkle! Are those pre-Alps blues? Perhaps ForwarD Electronics?
http://www.fwd.com.tw/en/companythings.aspx?uid=6
I have a very early (July 1988) Northgate 102 keyboard with blue Alps switches. The mold markings on the upper housings are different than the later ones I've seen, which I documented here:
viewtopic.php?f=2&t=17963&p=395632&hili ... te#p395632
Note that I desoldered an example with each type of marking and checked the lower housings, and all had the normal Alps logo. I have an even earlier blue Alps board (Datacomp DFK-777) from 1986 that I'm using as a switch donor, so I'll have to check the switch markings on that one.
- Polecat
Well thanks again for the ebay tip! It works perfectly, and feels and sounds very much like the blue Alps version. I haven't done a direct comparison yet; to do that I'll have to open up the blue Alps one to remove the sheet of closed cell foam I stuck under the PC board 25 years ago to try to quiet it down a bit. Like most of my keyboards I had put it in storage and forgotten about it until I wore the legends off my K104's caps and went digging for a replacement. I had no idea anyone besides me still valued these keyboards until I found this forum.cli wrote: 01 Jun 2019, 01:35 Congrats, your copy is even better than mine. My copy looks more like your Alps blue board.
Guchay
- Main keyboard: SSK & F50
- Main mouse: Microsoft BTE
- Favorite switch: Blue alps
Nice, I had one of those laser branded k102s too, I really liked the badge but I ended up slaughtering it for it's switches. Also on the note of the current discussion, DrClick can you see if those blue alps fit on regular alps keycaps. I had a Copam 430 which is probably one of the rarest blue alps keyboards next to yours, and the switches used on it don't support any of my alps keycaps besides the ones they came with. Here is a picture, I ended up slaughtering this one too and I'm going to rebuild it with blue alps that are compatible with alps keycaps.
- mcmaxmcmc
- Main keyboard: Boring Box
- Main mouse: Endgame Gear XM1
- Favorite switch: Hirose Clears
That looks like plain blue alps to me. Why does it not fit Alps caps?Guchay wrote: 01 Jun 2019, 11:30 Nice, I had one of those laser branded k102s too, I really liked the badge but I ended up slaughtering it for it's switches. Also on the note of the current discussion, DrClick can you see if those blue alps fit on regular alps keycaps. I had a Copam 430 which is probably one of the rarest blue alps keyboards next to yours, and the switches used on it don't support any of my alps keycaps besides the ones they came with. Here is a picture, I ended up slaughtering this one too and I'm going to rebuild it with blue alps that are compatible with alps keycaps.
Lbibass
- Main keyboard: It varies.
- Main mouse: MX Ergo
- Favorite switch: VINTAGE SHIT
because it uses shitcony caps, which stretch stems. Same with Montery boards.mcmaxmcmc wrote: 02 Jun 2019, 01:58That looks like plain blue alps to me. Why does it not fit Alps caps?Guchay wrote: 01 Jun 2019, 11:30 Nice, I had one of those laser branded k102s too, I really liked the badge but I ended up slaughtering it for it's switches. Also on the note of the current discussion, DrClick can you see if those blue alps fit on regular alps keycaps. I had a Copam 430 which is probably one of the rarest blue alps keyboards next to yours, and the switches used on it don't support any of my alps keycaps besides the ones they came with. Here is a picture, I ended up slaughtering this one too and I'm going to rebuild it with blue alps that are compatible with alps keycaps.
- //gainsborough
- ALPSの日常
That's actually fixable. Take some pliers and put some cloth/paper towel around them (so that the metal tips don't scuff up the stem) and close the "gap" with the pliers by pushing them closer together. Don't press too hard, but the fix is pretty permanent. Whatever the plastic the sliders are made out of is relatively pliable but also sturdy.Lbibass wrote: 02 Jun 2019, 04:18 because it uses shitcony caps, which stretch stems. Same with Montery boards.
Lbibass
//gainsborough wrote: 02 Jun 2019, 05:26That's actually fixable. Take some pliers and put some cloth/paper towel around them (so that the metal tips don't scuff up the stem) and close the "gap" with the pliers by pushing them closer together. Don't press too hard, but the fix is pretty permanent. Whatever the plastic the sliders are made out of is relatively pliable but also sturdy.Lbibass wrote: 02 Jun 2019, 04:18 because it uses shitcony caps, which stretch stems. Same with Montery boards.
Yup! I know.
I just haven't gotten around to doing it yet.
- Polecat
Today I dug this Focus FK-2001 out of my storage. This is as I got it, twenty-some years ago. Surprisingly clean, not much use. The Blue Alps were not a surprise, but I didn't expect it to have a single stabilizer and guide pin on the Enter key. Previous Focus boards I've worked on have had two stabilizers there, but this one has a pop-out pin guide instead, just like a Northgate. ("ANSIfy me...") Also this batch of blue switches seems to have very uniform color, for whatever reason. Since the caps are randomly yellowed my plan is to swap the PC board and plate into my black FK-2002. Anyone see any reason this wouldn't work, or any other reason not to do it?
edit: I forgot to mention that this Focus has a silver (unpainted) plate, compared to black-painted on the later ones; another similarity to Northgate.
- Top side, early FK-2001
- DSCN0457.JPG (816.17 KiB) Viewed 14193 times
- Bottom side and labels
- DSCN0462.JPG (810.21 KiB) Viewed 14193 times
- uniform blue color, Northgate-style guide pin on Enter key!
- DSCN0479.JPG (810.09 KiB) Viewed 14193 times
- //gainsborough
- ALPSの日常
Wow! This is in amazing condition! It should fit just fine into the 2002 case.
cli
- Main keyboard: Dell Click Mod AT101W
- Main mouse: Logitech Marble FX 2
- Favorite switch: Chicony KB with Futuba
Wow, pristine blue alps switches. They deserve a good heavy keyboard.
I recently got a Chicony with blue Alps, it's ok, but it's like a Lada with a Ferrari motor. Great switches, good electronics (N-Key rollover), shit housing.
- Polecat
Thanks for the encouragement! I started a new topic in the Gallery for this, and hopefully I won't hit any major stumbling blocks.//gainsborough wrote: 16 Jun 2019, 05:50 Wow! This is in amazing condition! It should fit just fine into the 2002 case.
viewtopic.php?f=62&t=22072
I bought the black case donor new back in the '90s, and it deserves a second chance. We'll see what happens...
- Polecat
So far I have blue Alps in a KB-101A, a couple early Northgates, a Monterey K102, a Leading Edge 2214, and probably some more still in storage. So the black Focus will be in good company.cli wrote: 16 Jun 2019, 06:50 Wow, pristine blue alps switches. They deserve a good heavy keyboard.
I sent you a PM about my leftover Chicony case, but sounds like it's not what you're looking for. I put my 5160 (Futaba switches) in a Franklin (Multitech) case. Not a drop-in swap, but not too hard to make work.
- ppCircle
- Main keyboard: Focus Fk-2002 HS Alps Blue / IBM 5140 Alps Brown
- Main mouse: Rival 300
- Favorite switch: Alps Blue / Alps Amber / Alps Brown / Alps N Green
This is interesting
latemodel24
- Main keyboard: Apple m0116
- Favorite switch: Ibm Capacitive buckling springs/orange alps
Oof, that stinks, but cool find.
- //gainsborough
- ALPSの日常
Yoooo! That’s an amazing discovery! SKCL cream in a videowriter!? Does it appear to have been resoldered or anything? This is so neat!
- ppCircle
Imo pcb and solders looks like as in others videowriters. Also looks fabric.
Edit: Probably browns was desoldered but anyway i "got scammed" for good price.
- //gainsborough
- ALPSの日常
I just realized these are dampened creams and not actual SKCM creams =(
That really does suck.
edit: actually I can't really tell. What are they? I mean if they are legit SKCM creams I'd say you got a better deal than if they were browns. If they are dampened then yeah that's unfortunate.
