Geekhack updates: WE ARE BACK
mintberryminuscrunch
19 Jul 2012, 19:48
The_Ed wrote:It says my password is wrong. And even when I type it in manually (instead of chrome autotfill) it still says it's wrong.
no passwords were transferred to the new website, so it can't be right, whatever you type!
The_Ed
Asperger's... SQUIRREL!
19 Jul 2012, 19:51
17 tries now. mkawa or somebody else needs to MANUALLY send me a password reset email. Or just let me use my original password, which I will then change after I'm in. Whatever is easier for me to gain access.
metafour
19 Jul 2012, 19:52
LittleStevieWonder wrote:Nope.
Any other ideas?
This post from Mkawa gives me little hope.
http://deskthority.net/geekhacker-refug ... tml#p58945
IDK, maybe you're banned...
inlikeflynn
19 Jul 2012, 19:54
The_Ed wrote:Why couldn't I just login with my previous password and then be forced to change it with a popup? That would have been a much easier method.
The old password db got compromised during the hacks, so it would have been a risk to continue using it.
You can see this in the r00tworm txt file as part of the password hashes for vBultin are out there.
hope this is no longer an admin password
19 Jul 2012, 19:54
No ptr record, this makes some mail servers reject mail as spam. Should be fixed by the company which handed out your ip number. Tell them you need a ptr record and give your ip number (65.111.241.203) and name (geekhack.org).
>dig ptr 203.241.111.65.in-addr.arpa
; <<>> DiG 9.4.3-P2 <<>> ptr 203.241.111.65.in-addr.arpa
;; global options:  printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 24234
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 2
;; QUESTION SECTION:
;203.241.111.65.in-addr.arpa.   IN      PTR
;; ANSWER SECTION:
203.241.111.65.in-addr.arpa. 3600 IN    PTR     runt-1.uhhh.org.
;; AUTHORITY SECTION:
241.111.65.in-addr.arpa. 3600   IN      NS      ns1.lldc.net.
241.111.65.in-addr.arpa. 3600   IN      NS      ns2.lldc.net.
;; ADDITIONAL SECTION:
ns1.lldc.net.           3600    IN      A       65.111.253.142
ns2.lldc.net.           3600    IN      A       65.124.105.6
;; Query time: 307 msec
;; SERVER: 67.19.0.10#53(67.19.0.10)
;; WHEN: Thu Jul 19 19:50:11 2012
;; MSG SIZE  rcvd: 150
metafour
19 Jul 2012, 19:59
Was there a disclosure about this from any of the GH mods?
I scrolled through some of the r00tw0rm release when it was first posted which seemed to indicate they got shell access. I never saw a transparent postmortem from anyone though which concerns me.
The_Ed
19 Jul 2012, 20:06
webwit wrote:No ptr record, this makes some mail servers reject mail as spam. Should be fixed by the company which handed out your ip number. Tell them you need a ptr record and give your ip number (65.111.241.203) and name (geekhack.org).
;; Got answer:
;; ANSWER SECTION:
So THIS is the reason I can't get into GH? If so how long does it take to fix?
19 Jul 2012, 20:09
Probably the time the ISP needs to address the support ticket + max 24 hours for dns.
xbb
19 Jul 2012, 20:39
Also, It's not possible to import them to a new system if they are hashed differently.
eth0s
19 Jul 2012, 21:17
Yeah, I can't log in either. GH doesn't recognize my old password, and won't send me an email to reset a new password. So whatever, it's still busted, at least for me.
The_Ed
19 Jul 2012, 22:20
I believe I'm up to 20 tries now... If webwit is right on the missing pointer record it needs to be fixed asap. There is probably a good amount of people who still can't get in because they never receive the password reset emails that are supposedly sent.
19 Jul 2012, 22:27
We had the same problem at one point... sometimes people didn't get their activation email. I looked into it when the problem grew sometime last year. It turned out this is a mechanism to prevent spam, with growing popularity. It's a very simple reverse dns mechanism. It checks if the IP number that is sending mail from foobar at example.com is indeed affiliated with example.com. Without it, a spammer could use foobar at example.com as the from address. This might not necessarily be the solution to geekhack's problem, as I don't know how they are sending mail (maybe by 3rd party). But they definitely don't have a ptr record.
quake4mhger
20 Jul 2012, 07:34
I login with old password, read the note, change to a new password, edit profile, upload an avatar, in 5 minutes :)
Parabellum
20 Jul 2012, 10:58
I wish I could log in..
megnin
20 Jul 2012, 14:13
Yeah, I wish I could log in, too. I never get the email. Tried entering just username and email address. Both say an email has been sent, click the link to reset password, buy I never get the email. Checked spam folder, etc.
20 Jul 2012, 15:27
Had no problem logging in (several times), never got the email, though.
So I changed the password in my profile.
mkawa
20 Jul 2012, 16:46
tweaking mail settings. stand by
ripster
20 Jul 2012, 17:28
I had no problems logging in.
dirge
20 Jul 2012, 18:14
So images and ban list broken?
MadScienitst46
20 Jul 2012, 18:28
mkawa wrote:tweaking mail settings. stand by
works for me now!
thanks!
Parabellum
20 Jul 2012, 19:47
Really? The link in the mail just takes me right back to the authentication reminder.
Limmy
20 Jul 2012, 19:50
It works for me too. Thanks!
MadScienitst46
20 Jul 2012, 19:52
Parabellum wrote:Really? The link in the mail just takes me right back to the authentication reminder.
clicking the ink didn't work for me neither, but copy/past the address did o.0
thegunner100
20 Jul 2012, 19:58
Going to "Forgot your password?" worked for me. But where's the spy?!
Parabellum
20 Jul 2012, 20:13
Thanks! ;)
20 Jul 2012, 20:14
"Users active in past 60 minutes"
It's showing double the amount of users "online" compared to the old geekhack, where this was an already generous 30 minutes. :mrgreen:
thegunner100
20 Jul 2012, 20:15
Would be nice if we could get a bigger editting box. The current one is pretty tiny =/
rknize
20 Jul 2012, 22:01
You can also just go into your profile and change your password there. If you are still having issues getting access due to missing emails/etc, shoot me, mkawa, or alaricljs a PM here on DT.
20 Jul 2012, 22:07
thegunner100 wrote:Going to "Forgot your password?" worked for me. But where's the spy?!
That worked for me, thx
The_Ed
21 Jul 2012, 07:49
Thanks for the manual reset mkawa. I guess comcast doesn't like the missing pointer record.
