IDENTIFY THE KEYBOARD thread
15 May 2020, 19:51
Lekrafter wrote: 15 May 2020, 03:10 Good evening everyone!
Would anyone be so kind as to enlighten me on what keyboards these are and what switches they might have?
The bottom keyboard is a Sun Type 4. I think it has Key Tronic foam-and-foil switches.
Notice the left key cluster, Compose key, Control key position and Meta ⋄ keys.
(There are a couple of mentions in the Wiki, but no actual article)
Lekrafter
16 May 2020, 07:16
Is this, what I think it is!?
16 May 2020, 10:51
Lekrafter wrote: 16 May 2020, 07:16 Is this, what I think it is!?
If you think IBM AT, then no. AT layout, yes. But no.
imdatperson
16 May 2020, 11:07
Kinda looks like a Futaba MA board with those caps. Diggin the look of it!
16 May 2020, 12:21
Pretty sure it's a Datacomp with Futaba MA switches. I think I covered that exact model in a video.
Lekrafter
16 May 2020, 15:15
Oh man! After a little digging around that's what I had figured out but at first I though it was a Monterey K2AX with SKCM blues...
ppCircle
16 May 2020, 15:50
Lekrafter wrote: 16 May 2020, 15:15 Oh man! After a little digging around that's what I had figured out but at first I though it was a Monterey K2AX with SKCM blues...
You can define that by looking at keycaps. > stepped =alps
Lekrafter
16 May 2020, 17:28
Chyros wrote: 16 May 2020, 12:21
Futaba MA one of the worst souding switches ever eh?
Robauke
17 May 2020, 13:30
@ntv242 @kbdfr thanks for the insights!
buying fitting keysets seems to be a challenging topic in itself, any place here in the forum to get to know that road better?
Lekrafter
18 May 2020, 16:09
Anybody know what this is?
Thanks!
Polecat
18 May 2020, 16:31
Compaq Enhanced Keyboard. Wiki says both foam and foil and rubber dome versions exist.
Lekrafter
19 May 2020, 02:17
And what would this one be?
wadeak78
19 May 2020, 03:02
funkmon
20 May 2020, 02:50
I need some right help on this one. It's a square badged Model M terminal from the early years with a metal 240 degree DIN plug, non removable, and stubby feet. Which one is it? I just bought it on ebay for cheap as hell but I don't know what I'm getting into here.
John Doe
20 May 2020, 02:58
It's like 1386303/1386304 terminal 102-keys layout M , but with an metal plug? interested me...
funkmon
20 May 2020, 03:03
John Doe wrote: 20 May 2020, 02:58 It's like 1386303/1386304 terminal 102-keys layout M , but with an metal plug? interested me...
Or the 670, yeah, but as far as I can tell, they don't have metal plugs.
According to the wiki, could be the 680, or a 1390305, maybe, but the image I can see of the 1390305 has more plastic on the DIN plug.
John Doe
20 May 2020, 03:54
funkmon wrote: 20 May 2020, 03:03
Yeah, quite surely it's 1390305 now.
found this after google:https://www.recycledgoods.com/ibm-13903 ... -keyboard/, details matched.
Hausen
20 May 2020, 19:22
Does someone know this keyboard ? And the switches that are being used? That keyboard has a turbo button which is strange mhm..
kelvinhall05
20 May 2020, 19:30
Hausen wrote: 20 May 2020, 19:22 Does someone know this keyboard ? And the switches that are being used? That keyboard has a turbo button which is strange mhm..
Interesting board. No idea what it is but I can almost guarantee it has rubber domes.
20 May 2020, 21:37
The shape of the keyboard case reminds me of a rubber dome keyboard that was super-common back in the second half of the '90s... but that style would date it from 1999 to only a couple years forward (copying the Tangerine iMac from '99).
Unikey/Chicony used that arrangement of 1.5u modifiers on the bottom row.
If you can see right through it, you can see that it has no plate and no PCB ...
A Turbo key modifies how fast the keys repeat when held down.
AJM
21 May 2020, 17:51
Keybug wrote: 27 Mar 2020, 13:49
AJM wrote: 25 Mar 2020, 20:33 This button is connected to the long weird feet under the keyboard. On my keyboard one of the feet wiggles, when I press it. Either something is stuck or I don't press hard enough. I'll find out, when I have the time to open and clean it.
An ingenious mechanism to lower the feet without turning over the keyboard?! Wow...
It's quite a nifty construction. Here's a video of the mechanics and 2 pictures of my cleaned keyboard:
22 May 2020, 01:44
I think that I had a buckling spring knock-off that looked like that many years ago.
It was dramatically inferior to an IBM and caps and parts were not interchangeable..
Lekrafter
23 May 2020, 05:00
What would this one be?
random keeb.jpg (89.47 KiB) Viewed 12199 times
mike52787
Alps Aficionado
23 May 2020, 05:11
Silitek dome with slider
Lekrafter
23 May 2020, 05:14
And what about this one?
how about this one.jpg (76.97 KiB) Viewed 12189 times
RiverDax
24 May 2020, 00:22
This is all the info I have
PlacaFromHell
24 May 2020, 00:41
RiverDax wrote: 24 May 2020, 00:22 Image
Philips P2000C, but no idea about the switches.
RiverDax
24 May 2020, 01:27
Thanks, someone also help with identifying
https://www.old-computers.com/museum/co ... st=1&c=846
HC514
25 May 2020, 00:15
Looks like it's related to this one.
textadventurer
25 May 2020, 14:15
Hi folks, my first post here. Picked up this keyboard. It has no logo or stickers, and I don't know what it is. It has some German keys on it (ß), and a key saying "EXTRA TEKEN" which is Dutch. The connector is of a phone cord type.
Anybody knows what this is?
