IDENTIFY THE KEYBOARD thread
- Redmaus
- Gotta start somewhere
That's surprising. 4chan usually isn't very helpful
- Crazy Canadian XXIV
- Main keyboard: IBM 122-key Model F, circa 1985
- Favorite switch: Capacitive buckling spring
To their credit, they did manage to identify this beauty.
bricomaz
- Main keyboard: Ducky Zero
- Main mouse: Logitech MX310
- Favorite switch: still deciding...
Hi all! First time poster here...
I found this (and others
keyboard on a e-waste dump yesterday but I cannot pull a single keycap to identify what kind of switches it uses. The pcb started to bend
and i don't want to break it! I suspect they are some kind of Alps (I can see the stem is white if this can help) Is it possible that keycaps are somewhat glued to the switch?!? Is it normal for Alps keycaps to be so hard to pull out?
Anyway here are the pictures:
http://imgur.com/a/l8psB
can anybody help me? I really would like to clean it...
Pull harder. Alps can be real tight, just like that. Try the Control keys. They'll give you most leverage and no stabs to worry about.
- scottc
Always remember when pulling keycaps: don't apply a lot of force upwards, just move it side to side. Eventually it'll give. The tightest caps always do.
- Chyros
No don't move Alps from side to side, they'll snap off! Only pull straight up, use a keypuller. Specifically says so in the Omnikey manual!
- XMIT
- [ XMIT ]
- DT Pro Member: 0093
If you pull Space Invaders straight up a spring goes flying. If you pull NEC Blue Ovals straight up you break the switch housing and there is no way to repair it.
If you pull Key Tronic Foam and Foil to the side you break the thin vertical legs under the key cap.
This is clearly Alps or some Alps clone. Wiggle side to side as you pull up. If you can, wedge between the top of the switch housing and the underside of the key cap to reduce the risk of ripping the slider out. Good luck.
- ohaimark
- Kingpin
- Main keyboard: Siemens G80 Lookalike
- Main mouse: Logitech G502
- Favorite switch: Blue Alps
- DT Pro Member: 1337
Speaking of Space Invaders... Does this board have them? I did some Googling already and didn't manage to find anything definitive. The font is odd, in any case.
http://www.ebay.com/itm/141815525234
- gogusrl
- Main keyboard: Cherry G80-1851
- Main mouse: Logitech G9x
- Favorite switch: linear stuff
Guys on irc already ruined my dreams telling me it's a rubberdome but I require additional confirmation before I give up on such beauties.
bricomaz
Just for the record: you ALL that replied to me were right! I managed to pull off the CTRL key, wiggling a bit, using a self made keypuller
Alps (clone?) switches.
- DSC_0397.jpg (385.12 KiB) Viewed 7124 times
- Blaise170
- ALPS キーボード
- DT Pro Member: 0129
Yep clones of some kind, you can tell easily by the four tabs on the side instead of two tabs. Maybe Tai Hao or Fuhua.
terrycherry
- Main keyboard: Model M, dodoo dome keyboard,CherryMX numeric pad
- Main mouse: logitech Master,M705 and 3 Logitech mice
- Favorite switch: ff
[Single board computer]trainer/evaluation board with numeric pad(20keys)
It's from the China seller. when I mention to buy this, it sold.
Hope someone can id this switch. Maybe it should made from the China manufacturer, it seems like my China desktop calculater.
- scottc
I got a really strange thing in the post today. Anyone any idea what it could be? Linear-ish in feel, a bit scratchy when you hit it off-center. The keys are sorted into modules that are screwed on to the back (!).
- 5.jpg (760.03 KiB) Viewed 7045 times
- scottc
Curse of the Phantom Keyboard! No, I was expecting it. I wasn't expecting it to be so weird though!
Ah, not bad. Thanks.
It reads DIGIPOINTO INDUSTRIA BRASILEIRA. Can't find much about them online apart from this: http://www.jusbrasil.com.br/diarios/319 ... 08-03-1983
- ohaimark
- Kingpin
Ah, Brasil. They banned foreign IT imports down there throughout the 80s, which led to Brazil having a thriving computer market… of locally manufactured clones! Apple IIs, PCs, Macs, and their keyboards.
Brazil's still weird about foreign goods. Apple gear is super costly there. They've thought of building a Brazilian factory to cover South America as a whole. But Shenzen is Shenzen…
- Blaise170
- ALPS キーボード
- Blaise170
- ALPS キーボード
I don't know the exact model but it's probably an old Micro Switch keyboard from the 70's/80's. Here's an example:
P.S. Do you mind linking the thread? Seems like an interesting read.
domvar
- Blaise170
- ALPS キーボード
I found one even more similar. This might be similar to what you are looking for.
