IDENTIFY THE KEYBOARD thread
12 Aug 2022, 16:11
Habakuks wrote: 12 Aug 2022, 16:00 That was fast... looks like I have come to the right place after a long time of looking for my lovely keyboard.
I took a look on the suggestions here (Mitsumi, Aristotle, Chyros donations)... but it seems I had something different.
The keybard I had was very soft in touch and silent... buttery and light as Muirium put it. When you type, it feels like cutting through hot butter with knife (as we say in German).
Is it possible that it was some kind of rubberdome?
But yes, you're right. I found a KB-5193R with clicky Cherry MX Blue switches. So "R" is not for rubberdome.
It really sounds like a board with these:
wiki/Mitsumi_miniature_mechanical
But in good condition.
Habakuks
12 Aug 2022, 16:50
Muirium wrote: 12 Aug 2022, 16:11 It really sounds like a board with these:
This one, right?
https://www.youtube.com/watch?v=tum8hoa1YOY
Too loud, actually...
12 Aug 2022, 17:55
They sound nothing like that in a chicony chassis. Watch chyros’s vid I linked earlier.
Chassis make all the difference. Everything is meaty in a thicc one. ;)
Edit: Actually they sound little like chyros’s vid either. His mic is too close. All thump, no switch. They’re actually quite subtle. Even a Topre will sound like a racket if you mic it from the table. :P
Habakuks
12 Aug 2022, 18:27
Aahh, yes, that might be the reason :-)
I'll give it a try and buy one.
Thanks, Muririum and others.
Great forum!
Edit: The more I watch typing videos with this switch, the more I think you're right.
morbid42
19 Aug 2022, 17:50
Anyone know what's this keyboard used for, the model is RT8756L with white linear spaceinvaders
Pwrtn
29 Aug 2022, 16:11
Anyone can ID these switches? The windowed caps are really throwing me off.
Obscure
29 Aug 2022, 22:52
I asked a friend to bring any keyboard from his Tokyo trip.
Well, one piece more for the collection, I guess I never will bring it back to service.
Any idea, what this one was made for? Thank you for infos, cheers
TNT
29 Aug 2022, 23:35
Pwrtn wrote: 29 Aug 2022, 16:11 Anyone can ID these switches? The windowed caps are really throwing me off.
Looks a lot like a Bondwell/Omron board: https://imgur.com/a/Mif2Tky; https://imgur.com/a/mCGfsa8. I used to own one of those which had some excellent amber Omrons in them. Might be worth checking this one out.
jsheradin
30 Aug 2022, 01:02
Obscure wrote: 29 Aug 2022, 22:52 I asked a friend to bring any keyboard from his Tokyo trip.
It's an NEC PC-98 board of some sort. Likely NMB dome with slider. TMK supports the protocol.
https://twitter.com/Foone/status/130152 ... 50/photo/1
Pwrtn
02 Sep 2022, 13:23
TNT wrote: 29 Aug 2022, 23:35
Thank you for the tip, I have it with me now and yes, it has amber Omrons. They seem clean on the outside but the feel is not very good, kinda mushy. Will try deep cleaning when I make some time.
clickandthock
02 Sep 2022, 17:36
Thanks!
jsheradin
02 Sep 2022, 18:09
clickandthock wrote: 02 Sep 2022, 17:36
Thanks!
Philips torsion spring by the looks of it.
clickandthock
02 Sep 2022, 19:37
jsheradin wrote: 02 Sep 2022, 18:09
Thanks!
That make sens!!! Thanks !
hellothere
05 Sep 2022, 17:30
Pwrtn wrote: 02 Sep 2022, 13:23
As I currently own two amber Omron keyboards, I'll first say that they are excellent clicky switches and can feel absolutely fantastic. The second thing is that if you find a couple switches aren't working properly, check out this thread.
As far as I can tell, you can't open the switch plate. You also have to desolder the switch to open it.
Lalaland124
07 Sep 2022, 16:25
Anyone have an idea? Siemens or Robotran would be my guess..
dancingtara
22 Sep 2022, 02:36
What switches this could have?
Note that box doesn't fit the keyboard.
It says Acer 6311-N
John Doe
22 Sep 2022, 03:23
dancingtara wrote: 22 Sep 2022, 02:36What switches this could have?
wiki/Acer_switch
dancingtara
22 Sep 2022, 04:57
John Doe wrote: 22 Sep 2022, 03:23
wiki/Acer_switch
I think so. Awfully sounds like Alps but very dirty sounding. Was afraid of pulling off the keycaps because I don't have a wire puller in hand.
Meowmaritus
22 Sep 2022, 08:39
dancingtara wrote: 22 Sep 2022, 02:36 20220922__2.jpg
It says Acer 6311-N
I have one of these it's indeed Acer switch. Mine has the slightly better old version of the switches so maybe yours will too
guidemetothelight
24 Sep 2022, 12:41
Anyone has any info on that keyboard ?
Especially Switch Type?
I have a chance to get it for free but i have to drive a fair bit to get it , wondering if its worth it :D
mmm
24 Sep 2022, 12:48
guidemetothelight wrote: 24 Sep 2022, 12:41 48cm_compaq_1-474623859.jpeg
Looks like a Compaq KB-9968 (rubber dome, possibly a boring one?)
guidemetothelight
24 Sep 2022, 12:58
mmm wrote: 24 Sep 2022, 12:48 Looks like a Compaq KB-9968 (rubber dome, possibly a boring one?)
Ah ok , thanks for clarifying.
Its from a bin of Electronic Scrap , but all Boards look to be Rubber domes , maybe theres a G80 3000 with lasered keycaps in there , but thats not worth the 60 km drive.
OleVoip
27 Sep 2022, 10:45
Lalaland124 wrote: 07 Sep 2022, 16:25 Anyone have an idea? Siemens or Robotran would be my guess..
F596A238-5B25-4FCF-8E02-C349BEECD204.png0C1CB410-4278-43FA-99CF-DC7237809573.pngC1349798-5EE0-4D06-9527-FB1BF6B66F9D.png
Definitely Robotron — Siemens put such top-hat caps only on low-profile switches.
guidemetothelight
27 Sep 2022, 13:26
Anybody got any clue ?
Cant find anything in the web , FCC ID isnt on the DT Wiki List.
Polecat
27 Sep 2022, 17:07
guidemetothelight wrote: 27 Sep 2022, 13:26 Anybody got any clue ?
Samsung rubber dome.
https://telcontar.net/KBK/Keycombo/keyboard?id=214
guidemetothelight
27 Sep 2022, 19:05
Polecat wrote: 27 Sep 2022, 17:07
Thanks ! Pretty cool website
justin423
01 Oct 2022, 14:31
Wyse Ultimate???
https://imgur.com/a/CPo8PQq
I am looking for a Wyse with a 10 pin DIN to pair with my Wyse-50 terminal. (going to try and use it with on an Odroid HC4)
But this one doesn't have a part #.
I want to spend like 40-50 bucks, but that seems impossible because it seems everyone took those old Wyse's and separated them.
guidemetothelight
02 Oct 2022, 20:35
Any Idea on that one ?
Very few Numbers on the back / branding.
Please Keyboard Wizards, share your knowledge. :?:
Polecat
02 Oct 2022, 20:50
guidemetothelight wrote: 02 Oct 2022, 20:35 Any Idea on that one ?
Datacomp DFK-501F, Futaba MA switches:
https://www.ebay.com/itm/324709565404
wiki/Datacomp_DFK-501F/502F
guidemetothelight
02 Oct 2022, 22:41
Polecat wrote: 02 Oct 2022, 20:50
Datacomp DFK-501F
Impressive , thank you.
Since iam limiting my collection to Alps , MX , One Model M & hopefully some topre in the future, not for me.
