FSSK PCBs (1st round)
Halvar
03 Apr 2016, 22:46
Aw yiss.
vivalarevolución
formerly prdlm2009
04 Apr 2016, 05:00
Red. Why not. Should look cool.
lot_lizard
04 Apr 2016, 08:52
I$...
I contacted a couple of weeks ago that I wanted two of these, but didn't see my name on the list. Please add me to the group buy if possible
Redmaus
Gotta start somewhere
04 Apr 2016, 09:01
Hell yeah red PCB's look awesome.
idollar
i$
04 Apr 2016, 11:13
lot_lizard wrote: I$...
I have PMed you. Please check your messages
idollar
i$
05 Apr 2016, 09:27
An update status on the GB - The order has been reviewed, approved and paid. Under production
ramnes
ПБТ НАВСЕГДА
05 Apr 2016, 11:47
Yay!
Khers
05 Apr 2016, 13:05
Awesome!
Halvar
05 Apr 2016, 14:26
Excited!
Is that a beamspring-like edge connector on one side of the PCB now?
Alkhar
05 Apr 2016, 19:04
Youhou !
idollar
i$
05 Apr 2016, 20:29
Halvar wrote: Excited!
No, It is not. There would not be space in the box for the controller.
idollar
i$
08 Apr 2016, 00:25
Following, the updated list of lucky future FSSK owners updated. Please check it.
  • Techno Trousers
  • Hypersphare
  • alh84001
  • pyrelink
  • micrex22
  • Halvar
  • Khers
  • snoopy
  • hypkx
  • vivalarevolucion
  • elRetto
  • Lurch
  • Redmouse
  • ramnes
  • Alkhar
  • HAL
  • orihalcon
  • Phenix
  • lot_lizard
shreebles
Finally 60%
08 Apr 2016, 16:08
I$, I messaged you on march 25th stating that I wanted to buy a second PCB from you. Therefore I am surprised to not find my name in this list. I have a prototype PCB from you (thanks again) and am waiting for a controller to finally start using it.
But I would've liked to participate in the run of "final" PCBs also. If it's not possible, that's okay too. In that case I will build only one, instead of two FSSKs.
bocahgundul
Sell me 5k please
08 Apr 2016, 16:45
I think I might want to buy a pcb but I need to ask first
are this fssk feels like a genuine model F?
Techno Trousers
100,000,000 actuations
08 Apr 2016, 16:47
idollar says it does. I'm not sure if anyone else has completed theirs, though, so that's the only report we have so far.
Redmaus
08 Apr 2016, 16:58
lmao we are sure gonna feel silly when the FSSK feels CAN buckling spring and we no longer have an SSK
chzel
08 Apr 2016, 17:04
It's pretty close, I have completed mine, but haven't got around to program it yet, but it's snappy and nice!
It doesn't feel as sturdy and solid as my AT, but that's expected. Definitely better than an M though!
hypkx
Chasing the Dream
08 Apr 2016, 17:21
idollar wrote: Following, the updated list of lucky future FSSK owners updated. Please check it.
  • hypkb
Maybe you want to update this :)
Phenix
-p
08 Apr 2016, 19:13
Is this controller fine?
http://www.ebay.com/itm/Xwhatsit-IBM-Mo ... SwrklU5QIE
Or is there an better (or cheaper) way to get the xwhatsit?
chzel
08 Apr 2016, 19:42
As fine as they get. Orihalcon is here, PM him directly.
idollar
i$
08 Apr 2016, 21:34
Status update:
FSSK (25 units ordered)
FEXT (5 units ordered)
No progress at all :-(
The shipment is done together
lot_lizard
08 Apr 2016, 22:40
Nice progress updates... They have been busy ;)
idollar
i$
10 Apr 2016, 09:18
Status update:
Redmaus
10 Apr 2016, 09:28
Has anyone thought of making a metal barrel plate for this project? That would really wrap it up and make it 100% model F goodness.
Also what does AOI mean?
alh84001
v.001
10 Apr 2016, 11:22
https://en.wikipedia.org/wiki/Automated ... inspection
It might be more model F then, but it would be less SSK. From strictly philosophical reasons I find the current setup ideal :)
Phenix
-p
10 Apr 2016, 15:13
regarding the case (I have no SSK, so I need to build one myself):
http://steampunkworkshop.com/keyboard-shtml/
Could something like that work?
how is the plate attached to the construction?
lot_lizard
10 Apr 2016, 15:37
@Phenix.. The following thread would have several pictures showing the base plate and barrel frame. The PCB would be sandwiched between the two with a buckling spring and flipper for each barrel in the frame. workshop-f7/ibm-model-m-screw-nut-and-b ... t9169.html
To be honest, the cheapest and most effective starting point for you (assuming you are wanting a custom case for this project) would probably be to find a broken 101-key model M, and cut it down to an 84-key (removing the right side with the 10-key). Finding a broken SSK (84-key) as a starting point would be tough.
You would need to perform a "bolt/screw mod" like the attached thread to add the new PCB. You will also need to find model F springs and flippers (which is the point of this exercise)
Edit... I misread your question. The plate and frame assembly just "floats" in the case resting inside clips at the front (4-5 of them), then "loops" over two pegs at the top. The top half of the case just sandwiches the floating plate/frame assembly onto the two top pegs
Phenix
-p
10 Apr 2016, 15:48
heres my other thread
https://geekhack.org/index.php?topic=81 ... msg2133290
I ordered 229 flippers recently. Screw-mod should not be an big problem.
I am mostly having issues with getting the case
Just ordered another Model M, will check whats going to be easier (cutting down or building that case)
[ XMIT ]
10 Apr 2016, 15:50
Phenix, what was your source for these 229 flippers?
Phenix
-p
10 Apr 2016, 17:54
I got them from 0100010.
But shipping was quite high (around 23$)
