[IC] First Ever Devlin Q-Series keyset voting!
UKKeycaps
15 Oct 2016, 22:22
The two profiles are vastly different, Q series is similar to DSA (low profile) and K series is like SA(but unsculpted)
Jebbra - there's no purchase limit.
Bob
17 Oct 2016, 00:28
geostation wrote: whats the difference between the two series ?
Devlin's Q is basically a thicker version of Signature Plastic's DSA, whereas K is essentially a thicker SA (equivalent to uniform row three) - Q is uniform low profile and quite thick, K is uniform high profile and really thick.
I have some K series caps from the sampler pack, and I have some of Signature Plastics SA relegendable keys and they're pretty much the same height. I can't tell the height difference from using them on my keyboard, but if you measured them accurately enough I suspect they'd be off by a fraction of a millimetre.
UKKeycaps
18 Oct 2016, 13:01
Get hyped
UKKeycaps
18 Oct 2016, 20:54
Group-buy is open
DT discussion thread here
zslane
18 Oct 2016, 21:32
Are these ABS or PBT?
Bob
19 Oct 2016, 00:51
zslane wrote: Are these ABS or PBT?
From the "[MechSupply.co.uk] Devlin Novelty/Sampler Pack" thread:
UKKeycaps wrote: Like GMK, Devlin only produce ABS keycaps
jebbra
21 Oct 2016, 07:24
May I know why so much blank? I still dream about Devlin with Colemak layout and it still doable by replacing 2 of the blanks with non-homing F J :mrgreen:
salasource
21 Oct 2016, 13:48
Wow, RadAway looks very cool! Too bad its not for 60% but this set alone could be the reason to get Plank keyboard.
Quaranta
26 Oct 2016, 13:33
jebbra wrote: May I know why so much blank? I still dream about Devlin with Colemak layout and it still doable by replacing 2 of the blanks with non-homing F J :mrgreen:
I could use the 5 blanks instead of the 5 keys which don't match my local QWERTY layout:
comma, dot, slash, semicolon and quote.
But I totally support adding non-homing F and J.
Bob
27 Oct 2016, 06:38
I could definitely use the 5 blanks too - in fact I'll be needing 6 for my space "bar", but then I'm not putting these on a Planck so my needs probably won't match anyone else's needs.
If you're keen on getting the non-homing F and J you could request them once you place your order as instructed on the group buy page "If you would like keycaps for a different layout with also uses 1u and 2u keycaps please use the contact form"... of course, it would be an additional cost. I'm just more accepting of the fact that I'll have to fork out extra to realise my dream.
jebbra
27 Oct 2016, 10:11
I already emailed them regarding the 'request' for different layout but not yet got a reply. Just need non-homing F J and Homing T N though.
Bob
28 Oct 2016, 01:53
Ohhh I didn't even consider contacting them now for additional keys - I just assumed I'd have to refer to my order number.
Edit: I should have contacted before placing my order as I was working on the assumption that I'd be able to purchase other standard keys so long as they were 1U, such as number row and F row. Thankfully Joe at MechSupply was very understanding of my mistake and was happy to give a full refund. I'll just wait and hope that Atomic layout and maybe even full ortholinear/matrix layouts gain enough popularity that I don't have to resort to buying a total of 120 relegenable caps... :?
