Elrick
15 Nov 2015, 01:37
Ellipse wrote: Depending on interest, all of the HHKB style PCBs may have detachable controllers so you may be able to bring your own controller for those as well. I will let everyone know.
Would love to see current HHKB owners disembowel their keyboards for yours Ellipse :D .
15 Nov 2015, 01:46
Kishsaver: not quite so good on the lap! I can tell you from experience. Always a relief to get those 3 hard kilos out of the way and some blood-flow back…
Elrick
15 Nov 2015, 04:19
Muirium wrote: Always a relief to get those 3 hard kilos out of the way and some blood-flow back…
Definitely helps to build up your strength if you've lived a life like most nerds do, here on DT ;) .
darkspider
15 Nov 2015, 04:25
Muirium wrote: a relief to get those 3 hard kilos out of the way and some blood-flow back…
It may lead to crush syndrome!
Ellipse
15 Nov 2015, 21:04
What USB cable lengths are preferred for those who signed the interest form? I was thinking 10 feet, which is really 9 feet as part of the cable is routed inside the F77/F62 keyboard. People can use their own cable but it doesn't cost much to have the preferred cable already configured.
Elrick
16 Nov 2015, 02:05
Ellipse wrote: What USB cable lengths are preferred for those who signed the interest form? I was thinking 10 feet, which is really 9 feet as part of the cable is routed inside the F77/F62 keyboard. People can use their own cable but it doesn't cost much to have the preferred cable already configured.
I want my cable to be long enough to lasso a runaway wombat 8-) .
16 Nov 2015, 11:05
10 feet sounds good.
What colour is it going to be ? I recommend black for the industrials
Ellipse
16 Nov 2015, 13:35
They will be black. If you have another preference pls PM me.
16 Nov 2015, 15:57
10' is good. Black would work for grey and black cases. I would imagine a beige color cable would be better for the off-white color case?
Samir
16 Nov 2015, 16:11
There seems to be a cable length limit for usb 1.0 of 3 meters, so it will be important that the cable is designed for usb 2.0 and the signaling of the keyboard is of a usb 2.0 device in order to have longer cable lengths.
Ratfink
16 Nov 2015, 18:52
Samir wrote: There seems to be a cable length limit for usb 1.0 of 3 meters[...]
Well then, it's a good thing that it isn't 1997.
RoastPotatoes
16 Nov 2015, 19:26
The longer the better I think. I really like the 2.75m mega long Model M cable. I think that is 9 foot ish.
Vizir
16 Nov 2015, 21:52
My AT model F had an original black cable on beige box
Elrick
17 Nov 2015, 00:41
Vizir wrote: My AT model F had an original black cable on beige box
Black cable is ALWAYS sexy, especially when it's slick and glossy........ 8-)
Samir
17 Nov 2015, 14:44
If the signalling and cable is only usb 1.0 (which most input devices are), then this is still important today.
17 Nov 2015, 14:46
You likely mean USB 1.1 which displaced USB 1.0 in ancient times.
Checking my Xwhatsit equipped Kishsaver just now, I do indeed see USB 1.1 rather than 2.0 or above:
Screen Shot 2015-11-17 at 1.47.18 p.m..png (142.3 KiB) Viewed 7849 times
Amsuingly, Xwhatsit chose to use USB Vendor ID 0481. Not IBM, like I expected, but someone else who made some of my keyboards…
0481  Zenith Data Systems
http://www.linux-usb.org/usb.ids
Samir
17 Nov 2015, 16:56
Muirium wrote: You likely mean USB 1.1 which displaced USB 1.0 in ancient times.
Yes, thank you for the correction on the version. But I believe 1.1 is still limited to the 1.0 cable specs. I can't seem to find anything that says otherwise.
bhtooefr
17 Nov 2015, 17:34
It's worth noting that there's a couple USB VIDs out there that are available for use by open source projects:
1209 (so far - they're soliciting donations of other VIDs from companies that got one and are no longer in business, and got their VID before USB IF banned transfers of VIDs or PIDs): http://pid.codes
1D50 (Openmoko, Inc.): http://wiki.openmoko.org/wiki/USB_Produ ... roduct_IDs
It's a better approach than piggybacking on someone else's VID (unless, of course, your chip vendor offers a unique PID for your use, or you need to use someone else's VID/PID to get their drivers (ala Matias Mac keyboards using Apple's VID and the PID of the wired Aluminum keyboard)), IMO, and the xwhatsit adapter is open source...
17 Nov 2015, 17:36
Can't we just thwack Zenith's zombie IP lawyers with our Kishsavers?
17 Nov 2015, 17:44
Muirium wrote: Can't we just thwack Zenith's zombie IP lawyers with our Kishsavers?
No because any Kishaver is much too nice for anything like that. ;) Use some heavy dome or something instead.
17 Nov 2015, 18:09
Can we not just use IBMs USB ID ? Its not as if they are going to care about 20 -30 keyboards
17 Nov 2015, 18:37
Sure. You speak hex, right? It's in there. Somewhere.
Firebolt1914
17 Nov 2015, 19:00
I will finally work on making a post on OTD; sorry I haven't had much time.
Would I also be able to see more pictures of the flippers?
Ellipse
18 Nov 2015, 03:38
Sorry Firebolt I only have barrel/flipper photos that I posted. The factory will be assembling the prototypes (I don't have everything yet). We are still waiting on the powdercoating of the cases, the inner foam, outside foam/box, and flipper/spring assembly. I am now hoping for prototype delivery by the end of the month (a bit delayed unfortunately). I have arranged for a few sample barrels/flippers to be mailed in advance of the prototypes; they should arrive in a week or so. Then I can post some higher resolution photos.
Elrick
18 Nov 2015, 10:36
Ellipse wrote: Sorry Firebolt I only have barrel/flipper photos that I posted. The factory will be assembling the prototypes (I don't have everything yet). We are still waiting on the powdercoating of the cases, the inner foam, outside foam/box, and flipper/spring assembly. I am now hoping for prototype delivery by the end of the month (a bit delayed unfortunately). I have arranged for a few sample barrels/flippers to be mailed in advance of the prototypes; they should arrive in a week or so. Then I can post some higher resolution photos.
We are all waiting with excitement on these babies, looking forward to seeing some pics before handing over all that moolah for them 8-) .
courtesi
18 Nov 2015, 19:30
What baffles me is how much Ellipse has accomplished; yet we still don't have an ETA on a Unicomp SSK?
18 Nov 2015, 19:34
Easy: ain't gonna happen. Next question!
kuato
18 Nov 2015, 20:00
Ellipse's next project could be making capacitive guts for the IBM SSK. Man, I would buy that in a second!
18 Nov 2015, 20:28
Is not the F77 essentially an SSK? Sure you have to manage the number row and F row being combined - but it seems close enough.
kuato
18 Nov 2015, 20:52
They're close, sure but I would bet that a reasonably priced upgrade like that for the SSK would be of interest to a lot of people.
