IDENTIFY THE KEYBOARD thread
Nuum
23 Nov 2016, 08:46
I think, IvanIvanovich had one of these or something very similar and it was a very specially numbered POS G80. I can' find his thread about it, though.
ba7777
飞不动的加林查
23 Nov 2016, 10:31
kbdfr wrote: Have a look there:
photos-f62/hoft-wessel-pos-keyboard-t7290.html
Thank you sir.
Laylie
03 Dec 2016, 02:28
Can anyone identify this keyboard?
03 Dec 2016, 02:34
Laylie wrote: Can anyone identify this keyboard?
The keycaps look extremely Key Tronic, but I don't recognise the switch Oo .
y11971alex
03 Dec 2016, 03:14
[ XMIT ]
03 Dec 2016, 03:36
PCB-trace based magnetic valve. Same as my NCR K430.
keyboards-f2/ncr-k430-magnetic-valve-se ... 11152.html
If you're not interested, let me know and I'll pick it up. Repairing these boards is one of my specialties.
Laylie
03 Dec 2016, 11:01
thanks for the info i was so curious about the switches. Still curious about the rest of the board though. It 's not mine, i found it for a realy good deal and this is the only photo i got.(XMIT I ll let you know if i decide to take it and not satisfied)
gcardinal
03 Dec 2016, 12:07
Got this in a sms from an older lady, no markings and she could only identify 1987 on the back
Edit:
Got quite unclear picture of the back
y11971alex
03 Dec 2016, 15:59
MperorM
03 Dec 2016, 17:37
Hi, I was scrambling through a webshop for used goods, when I stumbled upon this keyboard. I couldn't find any information about this specific keyboard online.
Does anyone know anything about this keyboard? Is it another boring rubber dome, or does it use the fujitsu switches?
thanks for any help you can give me, I appreciate it! :)
Here is a link to the pictures: http://www.dba.dk/tastatur-fujitsu-comp ... illeder/1/
gcardinal
03 Dec 2016, 18:10
MperorM wrote: ...
Judging from small media buttons on the upper row and age I would naturally think its a rubber dome indeed.
mike52787
Alps Aficionado
03 Dec 2016, 18:28
gcardinal wrote:Got this in a sms from an older lady, no markings and she could only identify 1987 on the back
Edit:
looks super rubberdomey to me.
mike52787
Alps Aficionado
03 Dec 2016, 18:29
MperorM wrote:Hi, I was scrambling through a webshop for used goods, when I stumbled upon this keyboard. I couldn't find any information about this specific keyboard online.
rubberdome
y11971alex
03 Dec 2016, 18:35
y11971alex wrote: Image
Hello? ;)
mike52787
Alps Aficionado
04 Dec 2016, 03:33
Hello? ;)
looks alpsy to me
emdude
Model M Apologist
04 Dec 2016, 03:39
Hello? ;)
BTC keyboard, so some BTC switch. Foam and foil or rubberdome, probably.
EDIT: It's in the wiki, foam-and-foil: [wiki]BTC_5060[/wiki]
thebluefox
05 Dec 2016, 12:07
Is this the original Chicony KB 7903?
alh84001
v.001
05 Dec 2016, 12:17
That spacebar :o
thebluefox
05 Dec 2016, 12:22
Exactly! :-)
Kouni
05 Dec 2016, 14:41
Hi guys, any idea what's under there ?
Box says "Worldwide Information Systems Bull", AT connector.
Nuum
05 Dec 2016, 14:43
Most likely Cherry MX Blacks, the keycaps look like Cherry profile.
Kouni
05 Dec 2016, 14:47
I thought they might be, but that layout is weird and I couldn't be sure.
Laylie
06 Dec 2016, 11:06
Have anyone seen this one before?
y11971alex
06 Dec 2016, 11:32
 It's a Greek language board!
The wavy shape suggests that it's comparatively recent, as do the Windows keys. The large recess on the capslock button might, as a guess, indicate that it's a poorly stabilized switch.
chzel
06 Dec 2016, 15:24
Yeap, Greeks, can confirm, but Laylie already knows that (with the apparetly common issue with the ς). The keyborad itself is most likely rubber dome though.
Edit: Just saw this on the PC, the badge is from Quest, it is a company that sells assembled systems branded with their logo, and usually built to budget (They still exist but with a very limited market share). It's almost 100% RD...
thebluefox
06 Dec 2016, 15:44
Rubberdome, most likely a Mitsumi.
06 Dec 2016, 16:23
thebluefox wrote: Rubberdome, most likely a Mitsumi.
It is, Mitsumi hybrid switches, probably the tactile ones.
It's a quite common board, but haven't seen a Greek one yet.
thebluefox
06 Dec 2016, 16:59
I also have one with linear (spring) switch.
Laylie
06 Dec 2016, 18:28
Yeah indeed greek language. Ty about the info on brand never heard about this one
marijan
07 Dec 2016, 10:02
Hi, Deskthorians.
Does anyone have an idea what the keyboard in this old thing could be?
It's an old Philips P2000C portable computer that I have a chance of buying. However, I do not have the space for it and would mostly be interested in the keyboard, if it could be of any use in more modern systems (and if it is any good).
Here is the (much better) image I found online at http://www.computinghistory.org.uk/det/ ... 00C-P2012/
Edit:
Here is an even better photo of the keyboard.
This is taken from the thread at http://stardot.org.uk/forums/viewtopic.php?f=45&t=9566
I have read through all posts, but the only relevant piece of information seems to be authors response on cleaning solution used to clean the keys:
@Mark - Armor All "Low Gloss" but I imagine the shiny stuff will do just as well. I am using it because the design of the Philips keys has a tube that fits over the shaft that rubs on the switch housing when you press it. ...
I hope this helps in identification
Edit:
I seem to be slowly answering my own questions :-)
So far I know that the connector is 6-pole DIN 45 322 (240°)
Edit:
I found the service manual at https://archive.org/stream/P2000CSystem ... 0/mode/2up
Spare parts listing shows this for what I think could be key switches:
DESCR. CODE NUMBER SERVICE NUMBER
Switch LP Assy (92 OFF) 5112 291 43290 * 5103 109 30340
Switch LE Assy (2 OFF) 5112 291 42910 * 5103 109 30350
