IDENTIFY THE KEYBOARD thread
gcardinal
09 Dec 2016, 00:23
Tryed my best googling, but wasnt able to find anything one this one
gcardinal wrote: ...
Ok, thank you!
09 Dec 2016, 00:40
Ok, thank you!
Key Tronic foam and foil most likely.
CoffeeHamster
10 Dec 2016, 22:20
Found this guy on Craigslist, wondering if it's worth picking up. Can't seem to find anything about it on the wiki so I can't determine the switch type. https://portland.craigslist.org/mlt/sop/5889531357.html
chzel
10 Dec 2016, 22:24
CoffeeHamster wrote: Found this guy on Craigslist, wondering if it's worth picking up. Can't seem to find anything about it on the wiki so I can't determine the switch type. https://portland.craigslist.org/mlt/sop/5889531357.html
Ah, the wiki saves the day again!
wiki/NMB_RT6856T
thebluefox
10 Dec 2016, 22:25
wiki/NMB_RT6856T
Most likely rubberdome.
thebluefox
10 Dec 2016, 22:26
:lol: :lol: :lol:
This is why I like this forum.
chzel
10 Dec 2016, 22:27
Ninja's abound!
CoffeeHamster
10 Dec 2016, 22:35
Sick, thanks guys. I'll pass on it and keep looking for not-broken Model Ms.
elecplus
11 Dec 2016, 20:23
Compaq portable keyboard Model 2680KB. Switches have inverse crosses, double shot caps have the +.
What type of switch is this?
Compaq 2680KB.JPG (807.14 KiB) Viewed 8463 times
ohaimark
Kingpin
11 Dec 2016, 20:35
Likely slider over dome or foam and foil. Compaq is known for using foam and foil switches.
elecplus
11 Dec 2016, 20:45
No springs, so prob not foam and foil? They are not clicky, but definitely not mush either.
mike52787
Alps Aficionado
11 Dec 2016, 23:26
gonna go with dome with slider on those.
thebluefox
13 Dec 2016, 21:24
What is inside this Siemens keyboard?
mike52787
Alps Aficionado
13 Dec 2016, 21:25
thebluefox wrote:What is inside this Siemens keyboard?
rubberdomes
thebluefox
13 Dec 2016, 21:26
I thought so :-)
13 Dec 2016, 21:39
Definitely rubber domes. I've found HUNDREDS of them at the recycling centre.
thebluefox
13 Dec 2016, 21:41
I think it is another RD but testing my hand :D
mike52787
Alps Aficionado
13 Dec 2016, 21:47
thebluefox wrote:I think it is another RD but testing my hand :D
definitely has the look of a rubberdome but I cant say for sure
thebluefox
13 Dec 2016, 21:52
thebluefox wrote: Is this the original Chicony KB 7903?
The attachment 2015_01_20_10_09_39.jpg is no longer available
What about this ?Still no second opinion.
mike52787
Alps Aficionado
13 Dec 2016, 22:20
Definitely domes. look through the pace between the keycaps, if you see plastic the same color as the case its 99% that its rubberdomes.
thebluefox
16 Dec 2016, 11:25
What Dell is this?
ohaimark
Kingpin
16 Dec 2016, 11:26
A rubber dome. By the by, you need to use direct links (end in .jpg) when hotlinking imgur files.
thebluefox
16 Dec 2016, 11:28
Yeap! Thanks, I thought I see white plastic under the caps.
ohaimark
Kingpin
16 Dec 2016, 11:32
No problem. I can remember the days when I couldn't identify keyboard switches by font, case shape, and other obscure characteristics...
Be careful with this hobby. It will consume you! :lol:
Mr.Nobody
17 Dec 2016, 11:01
What's this? Back plate is made of metal.
Ir0n
17 Dec 2016, 11:15
Mr.Nobody wrote: What's this? Back plate is made of metal.
Focus FK-747 I think :S
Mr.Nobody
17 Dec 2016, 11:41
[/quote] Focus FK-747 I think :S[/quote]
Thank you... :)
17 Dec 2016, 12:04
If you have it with you please go ahead and open the case to look for production details on the PCB thanks.
Ir0n
17 Dec 2016, 12:09
I was using my google-fu. Lol
Here is what I was looking at if you was wondering.
https://geekhack.org/index.php?topic=81035.0
17 Dec 2016, 12:18
Right, that's what I thought. You did say...
which is the key here, the only reason I'm being slightly obtrusive is so that we don't say anything wrong here. Chyros should know for sure anyway.
