Ellipse
Leyden Jar update and request for help:
So far over 130 F122's and their Leyden Jar controllers have shipped. After some firmware updates the reports are good so far!
Here are some plans for the Leyden Jar controller:
Need help - Split communication between halves, with one half powering the other (for future split ergonomic layouts):
"Well for the moment one half is working but I have trouble making the split feature work. I need time to understand what is wrong with my code: as I have a custom matrix scanning this looks to complicate stuff (all the project I have seen look to use standard QMK matrix scanning). I need to make split working and also try different settings like full duplex (testing half duplex at the moment), various detection of left and right parts"
Rico has kindly published this test code for split communication with the below link. If anyone can help it would be much appreciated to make these controllers even more powerful and useful with various keyboard projects. Rico confirms that the controllers work even with non-capacitive keyboards. https://github.com/mymakercorner/vial-q ... r_impostor
I would like to use a "USB C cable to connect the two ends instead of a TRRS cable" as the latter may result in accidental shorts if the keyboard is powered on during disconnection.
4 layer PCBs:
Using 4 layer PCBs as innovated by wcass to remove the trace area around the PCB, for a smaller PCB (better for the future compact designs mentioned in the Google form above.
PS/2 support:
Rico has started this but it is not yet working. If you'd like this feature and can help, please do! https://github.com/mymakercorner/Leyden_Jar
RedESC please see my previous F122 update post from a couple months ago (March?) regarding the queue and shipping timeline.
4 layer PCBs:
PS/2 support:
- wobbled
- Favorite switch: Topre
- DT Pro Member: 0192
Have you ever considered paying people to help you with this shit considering you're the one profiting from everyone's work?Ellipse wrote: 25 May 2025, 22:59 Leyden Jar update and request for help:
4 layer PCBs:
PS/2 support:
Ellipse
Additional transparent relegendable template:
With permission I am reposting a transparent relegendable template:
credit to geekhack member Cyber_engineer – Twitter @Mates_ENGINEER
Very nice template!
Very nice template!
- cyber_engineer relegendable template.zip
- (4.17 MiB) Downloaded 116 times
thrillscience
- Main keyboard: Model F
- Main mouse: Logitech Vertical
I just got the Model F 122. (I already had a Model F 104 which I'm using right now and am very happy with it.)
I managed to get the two vertical stabilizers on the numpad in upside down (i.e., rotated 180) and can't pull them out with any method I've seen. (I tried the screw and paper method, the q-tip method, spring hooks, etc.) I don't want to break the cylinder that contains the stabailizer trying to pull these out so I guess I need to open the inner assembly to push them out from the botton.
Two questions:
1) In the video he cautions against having a gap between the tab and the bottom plate (https://youtu.be/zjik1eiOSlk?feature=shared&t=150) but I'm not sure which gap he's talking about. Is it the vertical gap because the horizontal surface of the tab isn't flush with the plate, or is it the horizontal gap because the bottom plate hasn't been slid over enough?
2) He mentions using 4-6 clamps to aid in putting it back together. I would love to see a picture of the use of these clamps. (He says they're needed for the bigger keyboards, which I assume the F122 may need it.) What exactly do I need to squeeze? I just don't want to break anything. (I already broke a key trying the "wiggle method" before I realized the stabalizer was rotated 180 degrees.)
Two questions:
thrillscience
I need to open up my new F122 (I inserted the two vertical stabalizers rotated 180 degress and need to push them out from the bottom because all other methods of extracting them failed.)Ordinary Witch wrote: 23 May 2025, 03:07 my F122 arrived safely just earlier today, but with some minor easily fixable damage (bent pins on solenoid driver) to the accessories.
I took the inner assembly apart and modified the board by putting in basically as many flippers as I humanly could, aside from not splitting the enter key. put it back together with 3" C-clamps and some application of a hammer, installed the solenoid and driver and flashed the new firmware. this thing is working amazingly, and I somehow didn't have to redo a single part of this. I can confirm that the solenoid is deafeningly loud. it's the type of noise I'd expect from an airgun being fired
I've never done this before (I have an F104 that I've never had to take apart) and want to be very careful. Where, exactly, did you clamp it? How do you know how tight you need? I presume these are to get the bottom tabs in place? Did you take a picture of it clamped?
ms264556
- Main keyboard: Filco MJ2 Full ANSI
- Main mouse: Logitech M505
I used the packing tape transfer method to label mine. It's a shame about these having random colours - for transparent inserts, it'd be much nicer if I could have an entire set of pearl or pebble keys (or at least no black keys).Ellipse wrote: 01 May 2025, 20:39 Update: the F122 orders have started shipping out this week. A lot of folks like the transparent relegendables with these keyboards. Please do share photos of how you have customized your transparent relegendable Model F / M keys, whether new or original, as I have not seen too many such photos. Any advice for how to use these keys?
thrillscience
thrillscience wrote: 28 May 2025, 23:20Ok! I never did this before, but I got the inner assembly taken apart and put together again. I needed to use 6 clamps on this F122. Most of the "clamping" procedure became obvious once I started to actually do the work. (I regret not videoing the entire process so other noobs can see how it's done.)Ordinary Witch wrote: 23 May 2025, 03:07 I've never done this before (I have an F104 that I've never had to take apart) and want to be very careful. Where, exactly, did you clamp it? How do you know how tight you need? I presume these are to get the bottom tabs in place? Did you take a picture of it clamped?
Ellipse
With permission I am sharing the first photo of the Hebrew English key set on the new F122!
There are a couple dozen available key sets and it is nice to see photos of some of the rarer key sets.
thrillscience kindly see my replies below:
1. The issue is "the horizontal gap because the bottom plate hasn't been slid over enough" because the plates may not line up properly and could be more likely to separate. The plates should be able to slide so that they cannot travel any more and the sides of the tabs of the TIA make contact with the BIA cut out areas.
2. Yes, I'd like to take a photo one of these days showing the clamps, but feel free to search for "F122 model f clamps" to see how these larger keyboards are put together. It takes a few minutes with the right tools, or an hour otherwise! Some of the clamps should be inserted so that they are compressing the area between the function keys and top row of numbered keys, so that those TIA tabs rise enough above the BIA to clear it and allow the plates to slide together.
ms264556 the recommendation is to print out the templates on paper and cut out each one to fit the key. That way the legends can all have the same paper color, the key stem is no longer visible after the template is installed, and one can change the legend in the future. Unicomp provided the stems (they are regular Model M stems for two-piece keys) and noted that they are all assorted colors; no way to have all the same color.
thrillscience
I installed the Solenoid, taking extreme care to make sure that the red wire is on the square pad of both the LeydenJar controller and the xwhatsit solenoid driver.
I couldn't get the solenoid to do anything, so I tried installing the latest firmware from The ModelFKeyboards website using the LeydenJar diagnostic software and eh F122 firmware that was in Joe's zip file
According to Vial, these are the keymappings on layer 2 that control the solenoid.
If I press the layer-2 selectors and "T" (Haptic Toggle) the solenoid will go THUNK! But if I start typing after that, the solenoid doesn't sound. I tried turning the haptic dwells all the way up and down and it doesn't make a difference. The only time the solenoid will sound is if I press the Haptic Toggle key.
Ellipse
The solenoid should work by default without any configuration or keypress combinations. I recommend erasing the eeprom in the leyden jar tool and reflashing the firmware. Since the solenoid is able to fire, it may be an issue with your USB port (not enough power, USB hub, etc.). I recommend trying another port, another computer, and maybe trying your other Model F keyboard if all else doesn't work.
thrillscience
Thanks, Ellipse!
I tried selecting the "Erase Firmware" option and then dragging in the firmware again (before I just entered the bootloader and dragged it in.)
It definitely didn't work "out of the box" with the firmware that was there. That firmware wouldn't even sound the solenoid when I hit the toggle combo (which, according to VIAL was something different than above): It's plugged directly into the a USB port on computer mobo. I tried all the ports on the computer. I looked at the current draw with a USB power meter, and I don't see any signs the device drawing more current than my mobo can provide. It will THUMP reliably when I hit the toggle combo, louder when it's ON and softer when it's OFF.
I also tried touching up the solder on the driver board. The original solder job looked sketchy.
Ellipse
Check the leyden diganostic tool signal level monitor - maybe a key is being registered as pressed down.
Maybe the solenoid L bar itself needs adjustment as it's getting stuck. Does the cylinder move freely by hand and not get stuck? Are you seeing 6 to 9 volts where the solenoid is plugged in, when keys are pressed? Then it may be due to the solenoid.
thrillscience
The solenoid isn't stuck--if I keep pressing the toggle key it will click away happily. I don't think there's a key stuck down on the keyboard--I tested them all several times after setting up-- but it's an interesting theory: because of nkro it may confuse the software but the keyboard may still appear to be operating normally even if F22 is stuck down, etc. I'll check again when I get back to the office, and I'll put the 'scope on the solenoid output and see if it's trying to pull it.
If that fails, I'll hook it up to my other ModelFKeyboard and see if it works there--that would indicate a problem in the LeydenJar board or the software.
Ellipse
Great news from Rico - split communication is now working on the Leyden Jar controllers!
Please see Rico's update post here and head over to the github pages linked below:
https://www.keebtalk.com/t/the-leyden-j ... s/17489/45
https://github.com/mymakercorner/vial-q ... leyden_jar
https://github.com/mymakercorner/Leyden ... ostic_Tool
KeyboardPony
- Main keyboard: New Model F 122
- Main mouse: Microsoft Wheel Mouse Optical X08-71118
- Favorite switch: Model M Buckling Spring
I have used M122s for quite some time now. So I'm quite used to the 22 extra keys.Ellipse wrote: 01 May 2025, 20:39 Please do share photos of how you have customized your transparent relegendable Model F / M keys, whether new or original, as I have not seen too many such photos. Any advice for how to use these keys?
For me, the left 10-key-block is where I put things I use very often for me that's
- Escape. It's there, because M122s don't have a key where the Esc key is on standard keyboards. So on my M, I mapped the most left upper key to Esc which is that one. I have become so used to this position, that I also mapped it there on my F. I'll have to see how fast I can retrain my muscle memory to use the standard Esc position.
- MS Teams raise hand
- Print (= Screenshot) Window
- Print (= Screenshot) Area
- Output Volume Up
- Output Volume Down
- MS Teams mute mic
- Hardware mute mic
- Stop (On my M I used to have LCtrl there)
- Play/Pause (On my M I used to have LGui there)
F20-F24 map to hardware control (turn on/off touchpad etc.)
For optical reasons, I've always kept these F13-F24 instead of relabeling them (a meaningful label would require a too small font).
While I like the labels on terminal keys, I also like my keys not to be misleading. I'd rather prefer an unlabeled key (like the LGui/RGui keys on my F122) than misleading ones. This is why I don't use "original" terminal keys for my custom keyboard functions.
Ellipse
Posting (with permission) another great F122 setup.
This one is special as it has an old hi-fi Pioneer badge (for a cool retro styling) and Unicomp Esc and APL keys.
Ellipse
Posting (with permission) a nice F77 setup. The photo was just sent to me today and was taken after a year of usage by a writer who is working on a novel!
This F77 has one of the most popular add-ons, the solenoid, which is installed inside the case.
Takashi
- Main keyboard: Model F 77 repro
Ellipse
Yes, as noted from the beginning of the project, all stepped keys are from Unicomp, including ISO enter and caps lock. Their color is slightly different from the original Model F key colors.
As a recap, the factory failed to produce these extra keys to my specifications and they did not function reliably, so the order was cancelled. At some point I hope to resume that project to offer those extra few non-stepped keys (PC AT Enter, ISO Enter, Code) in various project colors.
If interested please sign the Google form: https://docs.google.com/forms/d/1vsamkl ... kDG39r08Q/
Ellipse
New as of June 2025: Mac Icons+Text 6 key set
By popular request - a set combining the Mac Icons and Mac Text key sets. This is a special order set that will arrive later this year, so you'd need to wait for delivery if combining shipping with a current order, or order separate shipping.
Feel free to head over to the Extra Keys page to see more details and order the set.
Ellipse
Today the (long overdue) blog update has been posted. This gathers together the many updates posted on the forum project threads.
Brand New Model F June 2025 Update: user reviews and photos, F122 and beam spring production, new design plans (Split Ortho, Planck, Preonic, F20, Kinesis, etc.), reorganized manual, updated firmware
https://www.modelfkeyboards.com/blog/
A new video below shows the process to open and close the inner assembly for the larger keyboard models (F104, F122, FSSK). This was just added to the manual as well.
Ellipse
I wanted to share a terrific 3d printed solenoid and solenoid driver holder project from f4pv:
https://www.thingiverse.com/thing:7076392
This allows for secure mounting of both the solenoid driver and solenoid inside the F62 and F77 keyboards, as well as being an external solenoid holder for the compact case F62 and F77 keyboards.
Thought I'd post a photo of my F122 w/ bonus cat. I don't have a use for all my keys yet so there are a few blanks. The ones I have added a legend for so far have used the template from @Cyber_engineer -- super handy.
I'd love to hear advice from folks on a few things I've been dealing with. The main one is that pressing "x" or "." bumps the space stabilizer a little, which causes the spacebar to rattle -- making the experience unpleasant. Is there any way to adjust (bend?) it so it clears freely and doesn't interfere with those keys at all?
Second issue is that I've not been able to find a setting or hardware arrangement for my solenoid that makes a nice subtle haptic "tak" -- it's more like a loud typewriter, even with settings that barely get the solenoid to fire at all. Am I doing something wrong or were my expectations just not reasonable?
- IMG_1204.jpeg (2.98 MiB) Viewed 3126 times
Ellipse
Nice photo TheJBW! Thanks for posting it. I would focus on the spacebar wire. I've also had success bending it in the other direction. I've just updated the manual with this additional information and a new photo. See action step 4 and let me know if this helps. Added text: "Additionally, as shown in the second photo below [added just now], you can bend the spacebar in the other direction, which would move the wire farther away from the > . key. "
Movement can also be reduced by pushing down the metal spacebar tabs slightly, not too much so as to slow down its movement.
You should not be adjusting the dwell times or other settings like that. Check out one of my last couple blog posts as someone modded the solenoid with electrical tape after adjusting the bracket to the shortest possible distance for the solenoid cylinder to move. Please keep us posted!
Ellipse
With permission here are photos of another nice F122 setup that combines two different-color key sets as well as the HHKB style split right shift and split backspace layout.
I like how these days the old style keyboards are bigger and heavier than the entire computers they are used with!
- Bits Passats
Hello,
@darkcruix
Are you still searching for the IBM 5322 and 5324 pictures?
I have a Spanish 5322, but I am to receive a faulty 5322 keyboard and I am negotiating a 5324 keyboard to repair, both from the USA. I wouldn't mind making pictures for you.
Regards
@darkcruix
Regards
Ellipse
Container shipment update:
The 7th container shipment for this project (with the second and final batch of F122 keyboards) departed last month and has arrived at the destination port! It should be delivered to me in the next couple weeks. Then I will work on organizing and preparing the remaining shipments to go out starting hopefully in late August, starting with the low serials.
Since I am mailing out so many orders, this will take months for me to mail these remaining orders. As always there is still time to upgrade your order to the low serial skip the line through that low serial store item.
After that, the only things we are waiting on will be the Round 2 beam spring keyboards.
Green Maned Lion
- Main mouse: X-keys L-Track
That looks truly gorgeous. After the money I've spent on the beamspring I ordered from you and four Battleships and a bunch of custom bolt-mod and keycaps and whatever, my wife's patience are a little thin (and I don't blame her), but if they weren't... I'd order one.Ellipse wrote: 02 Jul 2025, 03:24 With permission here are photos of another nice F122 setup that combines two different-color key sets as well as the HHKB style split right shift and split backspace layout.
