IDENTIFY THE KEYBOARD thread
New_User1
27 Nov 2022, 14:30
ThePipersSon13 wrote:
27 Nov 2022, 12:21
Hey all really struggling to figure out what this is. https://imgur.com/a/yk9pz7B
My only thought is I don't think I have ever seen a keycap with a Spade on it.
Cheers in advance.
I have only found one similar keyboard. But some of the buttons are different.
Link
27 Nov 2022, 14:36
Aha! Indian.
inozenz
27 Nov 2022, 16:13
27 Nov 2022, 12:21
Cheers in advance.
the font screams foam and foil to me but i might be wrong
Man from Mars
30 Nov 2022, 09:26
Good morning people of the keebs, I have come across a Unicomp 122-key terminal keyboard (no lock lights) with PS/2 connector from 1999, no info from the seller until now, no luck in searching part number on the label.
Any clue if this could be a BS board? Or just a big rubber dome?
Mistery Unicomp
Mistery Unicomp
pic2022-11-30 091636.jpg (90.23 KiB) Viewed 16716 times
flowerlandfilms
01 Dec 2022, 08:30
Muirium wrote:
19 Oct 2022, 21:11
Back on topic:
Yes, Empire of the Sun, but what about that tape console system he’s so not playing the monitor isn’t even on?
Whoa! Christian Bale was the raddest kid on the block.
Man from Mars
01 Dec 2022, 09:04
Man from Mars wrote:
30 Nov 2022, 09:26
Got some info back from the seller, it doesn't click :( (I mean, the keyboard, not the seller him/herself ;) )
ProfTroutington
10 Dec 2022, 03:30
Any idea what this may be? Doesnt seem to have any identifiers what so ever.
John Doe
10 Dec 2022, 06:08
ProfTroutington wrote:
10 Dec 2022, 03:30
Maybe its this.
june bug
10 Dec 2022, 10:07
10 Dec 2022, 03:30
looks like a falco 5220 keyboard, the only indication of the make / model on mine are on the pcb
ProfTroutington
10 Dec 2022, 11:21
that certainly seems to be the one, cheers!
guidemetothelight
10 Dec 2022, 12:42
10 Dec 2022, 03:30
Looks a lot like this Board i've found a while ago.
Someone said its probably a monterey K9 , but i didnt find out more.
guidemetothelight
10 Dec 2022, 12:51
Correction: Its probably the Keyboard of a dec vt220
10 Dec 2022, 16:46
DEC had Ceefax? ALL RIGHT! :D
ProfTroutington
11 Dec 2022, 09:53
I thought it was at first but the line feed key below the arrow cluster and the stepped keys made me pause. It definately looks like the aforementioned falco board, I bought it any way so I guess we will find out in a few days.
ProfTroutington
13 Dec 2022, 06:08
I can confirm it is a Falco board with Hosiden linear switches, unfortunately a couple of the switches got broken in transport.
justin4232000
13 Dec 2022, 16:46
guidemetothelight wrote:
10 Dec 2022, 12:42
10 Dec 2022, 03:30
A sys req key and a Line Feed key? I thought Sys Req was for PC's and Line Feed was for mainframe terminals, like EBCDIC, where line feed and carriage return are separate codes.
13 Dec 2022, 17:37
\n and \r remain different codes, on non-Microsoft platforms. :geek:
Polecat
13 Dec 2022, 18:20
justin4232000 wrote:
13 Dec 2022, 16:46
10 Dec 2022, 12:42
10 Dec 2022, 03:30
How about a PC used as a mainframe terminal? Here's a photo of the other Monterey K9 on my list (not mine). The "AX" in the model number is almost certainly for "AT/XT", in other words for a PC, but with a DEC layout to be used as a terminal. K9 is the model number, which was apparently part of Monterey's earlier numbering system before the Kxxx numbers came out.
Second photo is to tie the gray serial/model number label (different model, same label style) to Monterey.
ZeFritz
26 Dec 2022, 11:23
Keyboard on EBay. Looks like there had been a trackball installed in it.
The pink switch looks like Rafi RS 76 M.
Keycaps remind a little bit of the Rafi DT01/02.
JSDSocHill
02 Jan 2023, 01:25
I'm having a hard time finding info on the WYSE 724 keyboard, does anyone have any info for a newbie, like myself? I have several of these and I'm wondering what something like this would be worth. How can they be tested to see if they work or not?
Thanks in advance,
scottd
photekq
Cherry Picker
02 Jan 2023, 02:00
JSDSocHill wrote:
02 Jan 2023, 01:25
They're rubberdomes. Pretty much worthless, I'm sorry to say.
justin4232000
02 Jan 2023, 22:12
Or you can do what this guy did on Ebay, by putting this as the auction title...
Where is the facepalm emoji?
"Wyse 901867-01 Vintage Mechanical Keyboard - NICE"
03 Jan 2023, 09:05
02 Jan 2023, 22:12
"Mechanical"?
03 Jan 2023, 09:16
The “NICE” may be the even more egregious lie. :lol:
If it really is the same guy selling this on ebay, he’s got a brass neck for sure. Smart choice omitting those switch pics! Maybe someone can request them on eBay for a ruse?
justin4232000
06 Jan 2023, 04:01
Oy vey...
Another one.. (and this guy is a recycler)...with this description..... And deliberately didn't post a picture of the underside... I wonder why...
"Wyse Terminal Mechanical Keyboard | Cherry Blacks | 840358-01 / 901865-01 |"
06 Jan 2023, 04:13
We need a Bad Finds / Dodgy Sellers thread. :roll:
justin4232000
06 Jan 2023, 17:20
surprising response from the seller...
"It has a Vecmar sticker on it. On their site it shows both numbers so I put both up. The keyboard came from a box that has nothing else but 840358-01"
is it a 840358-01? I vaguely remember the yellow arrow keys meaning something.
photekq
Cherry Picker
07 Jan 2023, 00:50
06 Jan 2023, 17:20
It has MX switches, I can tell you that much. Does the specific P/N matter to you?
justin4232000
07 Jan 2023, 01:15
There were so many of the Wyse keyboards, I can't keep the combinations straight. I was more concerned it was a dome 9 series instead of a mechanical 8-series..
justin4232000
12 Jan 2023, 01:43
DEC rebranded?
Has that big "do" key.
