This one is so very old.
I like this MX518 mouse.
In these day...I can't get this anymore...
Well, then there are quite a few machines out there, regardless of that, polling rate affects the smoothness of mousemovement alot because for example 1000hz syncs up better with 100hz(monitor refresh) than 125hz. Not to mention that AM010 is overall more responsive than the old Avago´s(including 3090, which is very old from a technical viewpoint).chzel wrote: If you can discern 8ms vs 1ms of "lag" due to polling rate you are not a gamer, you are a machine.
Angle snapping maybe, polling rate...no...First of all you are most likely refresh rate limited. If you cannot see with better resolution than 17ms, you can't even begin to react fast enough for polling rate to be a major issue...
If you can reliably tell one from another in a ABX test, then by all means get a new mouse.
But don't fall for the trap of stats and specs and snake oil. Or the audiophiles might find you.
You are only reinforcing my point that the MX518 is obsolete, a lot of office mice already offer rebindable buttons and similar CPI. I also like how you are trying to sound smart by throwing "fancy" words around.davkol wrote:…and your logical fallacy is the false dilemma.
A whole bunch of developers, architects, designers,… is getting "gaming" mice, because ofdespite the "edgy" design.
- mid-/high sensitivity on HiRes-/multiscreen setups,
- more shape options,
- extra buttons and on-board memory with support for macros,
Obsolete also means outdated, which the MX518 is.
Polling rate is easily identified simply by Cursorpath.
MLT04 is still one of the most responsive platforms with nearly zero anglesnapping, thats why, A3080 on the other Hand while being responsive has massive Angle snapping.
Actually i play with 120hz and 240fps.
Been there, done that, also ping doesnt change the importance of cursorbehaviour, my point also wasnt about the 7ms, too many mice have latency similar to that anyway.
And the MX518 doesnt serve neither well according to the points he mentioned.
