Coil OVER dome key switch?
snuci
Vintage computer guy
12 Feb 2016, 02:18
I recently acquired a vintage Sony M35 computer that I know nothing about (yet). Strangely enough, it has a mix of key switches (which is not normal, right?).
Sony M35 computer - computer unrestored
Sony M35 computer - computer unrestored - small.jpg (163.71 KiB) Viewed 1478 times
The Fx function keys are Omron B3G-S switches.
Sony M35 computer - Omron B3G-S
Sony M35 computer - Omron B3G-S - small.jpg (149.98 KiB) Viewed 1478 times
The interesting switch is the main keyboard keys that looks quite cheap and plasticy but the key switches actually felt prettygood. When I took a picture, I saw the internal spring below the key stem. Looks to be an internal coil but I would guess this is over dome?. Does anyone know what kind of key switch this might be?
Sony M35 computer - coil over dome
Sony M35 computer - coil over dome - small.jpg (164.28 KiB) Viewed 1478 times
This computer needs a serious cleaning and I'm not yet sure how to take it apart but that WILL happen shortly. Just wondering if anyone has seen these key switches before.
ohaimark
Kingpin
12 Feb 2016, 02:23
It's probably spring over membrane. Not sure what mechanism, though.
snuci
12 Feb 2016, 02:40
ohaimark wrote: It's probably spring over membrane. Not sure what mechanism, though.
It may be hard to see from the picture but it looks like a conical spring because you can see the spring from the gaps in the sides of the key stem as well. Looks to be wide side up to narrow side down; sort of like an upside down Topre conical coil.
ohaimark
Kingpin
12 Feb 2016, 02:47
Topre and Prototopre keyboards are the devil's work; they simply feel to good according to some people.
SoDoM = Spring over Dome over Membrane = SIN!
On a more serious note, snuci is right. Looks coil-ish at second glance... Not sure if there's a dome though. Show us more!
snuci
13 Feb 2016, 19:07
Just to circle back, I posted pics at this thread: photos-f62/sony-m35-laptop-omron-key-sw ... ml#p286126
It's an Omron key switch spring over membrane.
