Unicomp Unix Keyboard
- Main keyboard: Unicomp Model M
- Main mouse: some generic shitty mouse
I have one and really like it. It is so hard to go back to a non-split backspace on my coworkers' keyboards.
It works on windows and Linux fine. The help key is the only key that doesn't seem to register on windows.
- BPX-926
Thank you for your reply! I am glad to hear it brings you enjoyment to use. I am happy works on Windows and Linux PCs.
Is your keyboard stock? Have you made any modifications?
Would you be able to share some photos of it? There is only one very poor photo on the Unicomp website. I would like to see the keyboard closer.
Here is the mostly stock version:
The only mods I've done was dying some key caps. The goal was for them to be black they turned out more bronze.
You have to be a bit creative in how you ask for it. The key is to ask for the right shift from the Japan 106 set. It only comes in the pebble color.emdude wrote:Wow, I didn't know Unicomp offered full-width 1.75u keys!
- BPX-926
Thank you very much for sharing the photos! It's a lovely keyboard.
Thank you also for sharing how to get a non-step Control key replacement. This is one thing that was bothering me a little.
Does the keycap Japan 106 Right Shift need any modification or changes to work, or does it simply pop in place without any issues?
Are the tab and backspace keys the same size?
How did you dye the keys? Was it an easy process?
- DT Pro Member: 0167
That tip is amazing.
Do they do the old style case in the UNIX layout ?
It just pops into placeBPX-926 wrote:Thank you very much for sharing the photos! It's a lovely keyboard.
They're the same size.BPX-926 wrote:Are the tab and backspace keys the same size?
I used iPoly fabric dye. It was a pretty easy process. Just boil some water, add the dye, then the caps. Though I don't think I would do it again as it made my apartment smell like ink for a couple days. I'd probably just buy caps in the color I want from unicomp.BPX-926 wrote:How did you dye the keys? Was it an easy process?
- BPX-926
Thanks for the replies and for sharing your knowledge. I really do appreciate it.
I think that the Wiki should have a page about this keyboard. May I use your photos on this wiki page? I would give attribution of course.
Yeah for sureBPX-926 wrote:Thanks for the replies and for sharing your knowledge. I really do appreciate it.
