Restoring keyboard ibm model f
mpereiro
15 Jun 2017, 13:56
I am restoring an ibm model F keyboard and I do not know how to connect the motherboard pins with teensy 2.0. There is some scheme The keyboard output is 15-pin or game port
2017-06-11 18.15.54.jpg (3.35 MiB) Viewed 4132 times
2017-06-09 22.00.08.jpg (2.63 MiB) Viewed 4132 times
15 Jun 2017, 14:06
Hello mpereiro,
what kind of IBM Model F is that exactly you have? Is there a sticker on the back? That connector looks like the one on my bigfoot. Show us a picture of the keyboard if you're not sure.
mpereiro
15 Jun 2017, 14:13
I think it's a bigfoot.
2017-06-09 22.07.09.jpg (2.64 MiB) Viewed 4112 times
2017-06-09 21.30.54.jpg (2.76 MiB) Viewed 4112 times
pixelheresy
15 Jun 2017, 14:22
Wow that's dirty.
Can't find the exact pinout, but I know I have seen the board pinouts for where the connector goes into the controller board. Regardless of connector, you have ground, data, +5 and clock pins on that connector on the inside. If you want the easy route, remove the old cable, put in a USB and hook up the Teensy inside, soldiering the pads to the board-end of the original cable.
Someone have the pinout?
Yeah, going to be doing just this for a Model M.
If you have a meter, you can do a continuity test for the individual pins on the original cable to clock, ground, 5v and data and build a box for the connector end (if you want to keep it 100% stock). But that requires a meter. And receiving connector. And a box to put all the jazz in. And that all assumes the cable is in good enough shape.
15 Jun 2017, 14:53
Here you go mpereiro:
workshop-f7/ibm-model-f-bigfoot-with-ar ... t9418.html
If you use our search function you will find more information useful to you. ;)
mpereiro
16 Jun 2017, 14:11
The cable is perfect and gives continuity. With the pin board I think I solve my problem. I wanted to keep the keyboard intact so I would build an external box for the usb.
Thank you very much for the help
16 Jun 2017, 14:13
Great, show us some pictures when you are done!
snoopy
16 Jun 2017, 14:20
I love Model F restoration threads. Keep us updated! :)
17 Jun 2017, 04:13
Great thread. I am restoring and modding one of these Bigfoots as well. The arduino info is definitely useful.
