Post your desktop.
Myoth
16 Dec 2018, 00:40
maybe the mouse isn't the problem :lol:
__red__
16 Dec 2018, 00:51
What's the resolution of that monitor? I like the form-factor. Curious if they get that by adding to the side or cutting from the vertical.
madrobby
16 Dec 2018, 00:53
__red__ wrote: What's the resolution of that monitor? I like the form-factor. Curious if they get that by adding to the side or cutting from the vertical.
3840x1600
https://www.dell.com/en-us/shop/dell-ul ... ccessories
Bass
16 Dec 2018, 02:04
Here's my setup. 43" 4k display on the left, 27" 1440p display in portrait on the right. I know the lighting is terrible but this is the best I can do for now.
2018-12-15 16.35.10.jpg (4.38 MiB) Viewed 12161 times
davkol
16 Dec 2018, 11:41
derp
Bass
16 Dec 2018, 18:15
davkol wrote: Isn't such a small distance between the screen and eyes (and also the field of view coverage) quite unhealthy?
I guess it's not apparent from the picture, but I don't sit as close to the screens as you might think (about 3 feet away). So neither of these things are any more of an issue than with a more typical multi-display setup.
davkol
16 Dec 2018, 18:23
derp
zslane
16 Dec 2018, 18:59
Well done, madrobby!
-[°_°]-
16 Dec 2018, 19:30
I love the mini C64 @madrobby
madrobby
16 Dec 2018, 20:18
matt3o wrote: I love the mini C64 @madrobby
Thanks, it’s the LEGO one from here: https://powerpig.ecwid.com/#!/My-First- ... y=15326736
I’m really tempted to get the full-size model... https://www.perifractic.com/Perifractic ... _Base.html
-[°_°]-
16 Dec 2018, 20:37
I always wanted to build a C64 like keyboard.... so far I limited myself to a keycap set :)
madrobby
16 Dec 2018, 21:24
matt3o wrote: I always wanted to build a C64 like keyboard.... so far I limited myself to a keycap set :)
That is *amazing*. Is that still available to buy somewhere?
-[°_°]-
16 Dec 2018, 23:34
madrobby wrote: That is *amazing*. Is that still available to buy somewhere?
I'm trying! Hopefully next year we'll be able to re-print it! You'll find it on Pimpmykeyboard
16 Dec 2018, 23:36
Make it into a 75% (instead of a 65%) and you'll make me incredibly conflicted. :-D
(also, ISO!)
Excelso
17 Dec 2018, 01:27
I do have a similar setup but with a 48" 4k screen and a couple of vertical 19" ones on the right side and, as they are in a real office desk, distance seems enough so I have I have everyhing inside my field of view while focused at the big screen.
John Doe
17 Dec 2018, 02:15
Bass wrote: Here's my setup. 43" 4k display on the left, 27" 1440p display in portrait on the right. I know the lighting is terrible but this is the best I can do for now.
I like this one, I really enjoy this one. :cry:
__red__
17 Dec 2018, 02:26
depletedvespene wrote: (also, ISO!)
I can't be the only person on Earth who does the combination ANSI/ISO thing? Can I?
ANSI enter/|\
ISO left shift plus additional
HzFaq
17 Dec 2018, 10:03
ANSI enter/|\
Nope, Ive grown to quite like it actually, my backspace is the wrong profile as well which makes hitting it a little easier, although this does make hitting the two keys above it a little trickier...
Usually I prefer ISO, but with Alps to you have to make some sacrifices sometimes.
17 Dec 2018, 10:40
What display is that? I have a ProLite X4071UHSU-B1 the image quality is good but the response time is so slow i can see trails behind scrolling text/ images like old early 90s laptops :P. I sent it to iiyama but they said there was nothing wrong with it.
Bass
17 Dec 2018, 11:16
It's an LG 43MU79. I don't know exactly how it compares, but response times haven't been a noticeable issue in my experience (it's rated at 8 ms).
If you are interested in buying it, be aware that there is a more commonly known UD79 model which is pretty much the same to the best of my knowledge except having only 1 year of warranty. I love the screen real estate provided by this display, but most 43" 4k displays I know of are bound to have some sort of flickering or image retention issues down the line, and this one is no exception. Mine started to experience image retention after around 8 months of use, but in practice it's only noticeable for me at the very start of fullscreen video playback.
17 Dec 2018, 11:22
Thanks! That looks quite good. I like the fact that its matte and not glossy!
I think i will wait till we can get 120htz models without having to go to ebay for off brand screens. I am sure they are fine but the warantee scares me!
gogusrl
18 Dec 2018, 19:53
ANSI enter/|\
I like it the other way around. ISO enter with ANSI shift and a row 3 \|.
01 Feb 2019, 09:19
samuelcable
28 Feb 2019, 04:18
sorry if the quality isnt the best. this is my workstation so its a little messy since i do a lot of soldering here :oops:
jani80k
01 Mar 2019, 09:49
The old keyboard (DELL) had to go...
The new one (75% Vortex) has MX Pink switches - so it is quieter than its rubberdome predecessor and no one at the office can comlain ;)
EDIT: New Trackball, I want to be like Nathan Kim!
WhatsApp Image 2019-03-20 at 12.33.24.jpeg (141.72 KiB) Viewed 10800 times
EDIT 2: Built a new 60 and got a deskmat.
EDIT 3: Built a new 60 without centre posts and PC Plate (clackityclack) and OG doubleshots
EDIT 4: IDB60 (plateless keyboard) with GMK WOB
foxtrott
15 Mar 2019, 17:02
my current setting
unfortunately I have to rebuild soon ...
15 Mar 2019, 21:43
weyyyyyyyyy
samuelcable
17 Mar 2019, 23:09
How do yall keep such perfectly clean desks
18 Mar 2019, 00:01
samuelcable wrote: 17 Mar 2019, 23:09 How do yall keep such perfectly clean desks
We don't. It's just for the photo op.
darkcruix
20 Mar 2019, 11:18
I recently built my new office desk and also received my freshly powder coated 3278 back as well. I thought I share a few pictures.
