Hi all!
I wrote couple days ago about my recently found F-122.
Today I was able to connect it with Soarer's converter to a pc, to discover that half a dozen keys are dead:
S,D,4, and a couple other keypresses aren't registered.
The same keys, when pressed, have a different feel/sound as well: they feel "linear", and in fact there is no click at the end.
After disassembling the plates, a first observation of the PCB doesn't reveal any obvious damage:
some spots are brighter, less opaque than the rest, but I assume it is caused by the contact with the foam mat.
All springs and hammers are in good shape (see attached photos).
Any ideas about possible causes?
Thanks in advance
gg
Help troubleshooting F-122 keypress not registered
gorgeous_george
- IMG_20180916_182225.jpg (2.36 MiB) Viewed 2191 times
gorgeous_george
You absolutely nailed it. Everythings fine after reassembling and carefully inserting the stems. Thanks for your prompt help!
xueyao
- Main keyboard: IBM Model F122 XT Beamspring 3727
These things are near indestructible. Water damaged and the controller is fried? No worries, just chuck a new xwhatsit and you're back in business! Only thing that could possibly damage it is rust, and even then it has to get through 2, 3mm thick steel plate before it can even be considered damaged beyond repair. I recall there's even a beamspring that was FIRE damaged and it was restored back to a fine condition. They're simply amazing.
Sent from my SM-G965F using Tapatalk
