DIP Switches on the CH Trackball Pro or Kensington Expert Mouse 2.0?
zerker
02 Dec 2018, 14:13
Hello folks. I have two classic, full-sized trackballs for my Retro PC, but both of them have banks of DIP switches, and I cannot find a manual or documentation anywhere online to describe what is what. Photos follow:
The Kensington Expert Mouse 2.0 (serial):
And the CH Products Trackball Pro (PS/2):
Any help would be appreciated!
madrobby
02 Dec 2018, 17:31
For the CH Trackball Pro, I believe here's a scan of the relevant manual: https://imgur.com/a/dTW3Z#bqzSr
zerker
02 Dec 2018, 17:34
Thanks, though that looks to be for a newer edition with four extra DIP switches. However, it will still be very helpful, as the switches I have probably have similar features. It should just be a matter of testing to see which ones correspond to the listing in the scan.
madrobby
02 Dec 2018, 17:38
Yeah, just noticed that the IMGUR think says "Note: The Gen1 DT225 has DIFFERENT DIP Switch Settings" :/
zerker
02 Dec 2018, 18:01
Well, here are the results of my testing:
1: Swaps Left/Right Buttons
2: Unknown
3: Unknown
4: Unknown
5: Double Cursor Speed
6: Half Cursor Speed
7: Disable Left Click Lock Button
8: Disable Right Click Lock Button (though only if 7 is also set)
2-4 didn't do anything obvious. I tried setting all three with the click lock buttons disabled, but I still didn't get a unique middle mouse click to register. If anyone has any more information, it would be great. At least I found the double-speed switch though :)
stratokaster
19 Dec 2018, 22:52
Click-lock buttons look very useful, sounds like a perfect solution for drag-and-drop with a trackball.
rocco_16v
17 Apr 2024, 04:17
I'm uploading the full User's Manual for the CH DT225 trackball with 8 pin dip switch setup on the bottom. Hope this helps someone in the future.
CH Products DT225 Manual V1.0.pdf
(2.49 MiB) Downloaded 979 times
