Does this dell at101 have pbt keycaps.
latemodel24
02 Apr 2019, 03:34
I bought this dell at101 and I was wondering if it had pbt keycaps. The rest of the case is yellow but the caps aren't. It is a silitek model. The fcc id is gyum97sk.
Fkazim
02 Apr 2019, 11:14
By the looks of it yes it does have pbt key caps I'm going by the way the case has yellowed and the key caps have not. The other possibility is that the key caps were replaced somewhere down the line and have not had a chance to yellow yet hope that helps.
Noobmaen
02 Apr 2019, 11:17
I don't think any silitek dell at 101 have pbt caps. The spacebar is equally unyellowed even though it would be ABS in any case.
02 Apr 2019, 11:27
GYUM97SK should be ABS, and as noob mentioned, the spacebar hasn't yellowed. I'm thinking transplant.
davkol
02 Apr 2019, 11:43
derp
E3E
02 Apr 2019, 12:24
You don't need to look past the homing bars to identify these caps; no, they are not PBT.
latemodel24
02 Apr 2019, 13:47
Also the switches seemed to be lubed. I took one of the switches apart and it felt like it was lubed.
cli
02 Apr 2019, 14:11
IMO, it doesn't need lubing. I have lubed the sliders of my Dell AT101 once. It changed the feel and click, but can't say it was a big improvement so I removed the lubing at the end.
latemodel24
02 Apr 2019, 16:10
No, the switches already seemed to have been lubed.Which I find weird for black alps to be lubed. My understanding is that only early alps were lubed. I guess this board may have been tampered with, which would explain the keycap swap.
cli
02 Apr 2019, 17:03
You're right, only early Alps were lubed. Alps stopped lubing and used smoother plastic sliders instead with later models.
Have you checked the tactile leaf ?
02 Apr 2019, 17:39
I've mentioned it several times before, but nobody seems to pick up on it xD . I've found lube on switches as late as bamboo blacks xD .
kakan
02 Apr 2019, 17:56
Chyros wrote: 02 Apr 2019, 17:39 I've mentioned it several times before, but nobody seems to pick up on it xD . I've found lube on switches as late as bamboo blacks xD .
The deep voice gets lost in all the noise.
cli
02 Apr 2019, 18:12
The deep voice should tell us more and enlighten us with keyboard lubing video's ;-)
... it's first time I read about lubed bamboo blacks.
latemodel24
03 Apr 2019, 00:23
I have opened around half of the switches so far for cleaning and the lube amount varies by large amounts. The num-lock had generous amounts of lube, some just have like a film of oil, and some feel like they have none at all.
Lbibass
03 Apr 2019, 04:39
Wait. Like, actual grease? That doesn't seem right...
03 Apr 2019, 06:56
Someone fucked around with it.
latemodel24
03 Apr 2019, 16:24
Not grease, but like a light oil film on it.
husnulhamidiah
04 Apr 2019, 17:16
Sorry for out of topic, but where you get that keyboard?
latemodel24
04 Apr 2019, 22:10
Bought it off ebay.
