[WTS] IBM M50
thokir
05 Sep 2019, 17:58
Working fine, just tested all keys on my PC. Comes without a cable. One clear cap is missing.
Thinking about 150€ + shipping, including PP fees.
I'm from germany, contact me for shipping costs.
Donnelly20
05 Sep 2019, 22:40
Did you test this on Windows 10, if so do you know if it is possible to program the keys on windows 10, if so how ?
05 Sep 2019, 22:43
Donnelly20 wrote: 05 Sep 2019, 22:40 Did you test this on Windows 10, if so do you know if it is possible to program the keys on windows 10, if so how ?
Not OP, but I can help you. Get an SDL to USB Soarer Converter cable and define the mappings for each key- I have several .SC files you can use as a starting point to do what you might want..
Donnelly20
05 Sep 2019, 22:46
Thanks for the response, unfortunately im on the other side of the world although soarers converters are worth it the shipping is not.
thokir
06 Sep 2019, 06:40
I did test on win10. I don't think there's an easy way to program the keys.
But in case you're really interested in the board i'd take a look into converting it to usb with soarers.
79f0167
07 Sep 2019, 02:45
PM'd :D
Return to “For sale”
