Hello everyone,
The group buy is running.
This group buy is for:
iGK series wireless bluetooth hot swap MX switch keyboards iGK61S, iGK64S & DIY kits, PCBs, and bluetooth hotswap optical keyboard iGK66
Custom 2019 arris aluminum keyboard case & semitransparent Polycarb keyboard case(Fit for iGK6X keyboards, compatible with most other 60% keyboards, such as GH60)
Custom GSA pbt dye-subbed keycaps sets for iGK61, iGK64(multi- colors optional)
Invented fiber glass plate (pre-built with Gateron Taiji satellite axis),strong and elastic without deformation, let you experience no-steel feeling. Fit for iGK6X keyboards, compatible with most other 60 keyboards.
iGK series wireless blueooth keyboards' features:
Bluetooth 5.0/wired dual mode keyboard (can conect 3 bluetooth equipments at the same time)
Full RGB backlit
hot swappable PCB
5-layers (1 default layer; 4 layers fully programmable: 1 layer online programmable and 3 layers onboard programmable) keyboard
With driver software
USB type-C cable
Quick group buying entrances:
Portable 60% Bluetooth hot swap keyboards & DIY kits, PCBs,and DIY parts all here
60 percent Bluetooth keyboard custom barebones kits
66 keys hot swap Bluetooth optical key switch keyboard iGK66-bt
Cheap blueooth hot swap keyboards
Custom bluetooth keyboard with RGB backlit, programmable, hot swappable mechanical switches
DIY 60 wireless Bluetooth hot swap keyboard parts
iGK61S 61 keys 60% portable wireless Bluetooth keyboard, custom diy kits, PCB, parts...
iGK64S 64 keys 65% compact bluetooth mechanical keyboard, custom kits, PCB, parts...
Buy custom keyboard cases: 2019 new arrival - arris aluminum keyboard case, high quality & nice semitransparent Polycarb case
Buy fiber glass plates built with Gateron Taiji statellite axis for iGK61(GK61) and iGK64(GK64), compatible with most 60% keyboard cases
Buy custom keycaps sets: GSA profile dye-subbed pbt keycaps for iGK61,iGK64
Buy 60% wireless bluetooth hot swap PCB, 61 keys nad 64 keys layout optional
Group buy timeline for above items:
Group buy opens - September 14, 2019
Group buy closes - September 25, 2019
Estimated ship date - October 15, 2019
Another related infos:
Regular iGK6X wired keyboards and related items, you also can buy on our Epathbuy website,as usually, we have most of them in stock, and can ship them in one week.
Custom 60% hot swap switch RGB mechanical keyboards & DIY kits shop online store main page
Buy 60 hot swap mechanical keyboards
DIY 60% keyboards custom hot swap kits - many kinds optional
Mechanical keyboard switches - Cherry MX, Kailh box, Gateron mechanical & optical switches optional
Hot swap mechanical keyboards buying guide
Introduction about optical switches & optical keyswitch keyboards
[GB]60% wireless hot swappable keyboards & DIY custom kits ( 61 & 64 keys mx switch, 66 keys optical switch optional)
ingeniousmonkey
- Main keyboard: mechanical keyboard
- Main mouse: wireless mouse
- Favorite switch: blue switch
- GK64S wireless bluetooth keyboard diy kit.jpg (215.9 KiB) Viewed 5123 times
