How to properly gets dents out of aluminum cases?
hKing
06 Mar 2020, 12:13
Hey there,
maybe it's a bit of an unusual question for a keyboard forum:
How do I get dents out of an aluminum case?
If have two dents in a newly cerakoted case. They bug me a lot.
Is it possible to just ask a professional metalworking company if they can get out the dent just by drilling the whole surface?
-[°_°]-
06 Mar 2020, 12:30
it would be very expensive to mill out the imperfections, you also need to re-anodize everything... so you would probably need to sand blast the original anodization away, fix the dents (possibly even by hand) and then anodize it back.
I mean anything is possible but you'd need to find a friend/maker/workshop willing to do it.
