How to Keyboard not working after cleaning. Is there any fix?
Hypersphere
22 Jul 2020, 14:52
@Roger789: The problem might be the silicone grease. Did you use this to lubricate each of the switches? Grease can literally "gum up the works" on this type of keyboard switch. Another possibility is that cleaning the PCB disrupted some of the traces.
22 Jul 2020, 19:33
The opening post is spam.
Perhaps I made a mistake when reporting it.
It’s a simple copy (with a spam link added) of a post made in April by someone else:
viewtopic.php?f=2&t=23786
but the original post has been deleted and the spam post is still here.
23 Jul 2020, 10:02
kbdfr wrote: 22 Jul 2020, 19:33 The opening post is spam.
I have banned this user and unbaned the one reported in error.
Locked
