SMK 2nd Gen MX Mount LInears
Airplane
06 Sep 2020, 11:04
Anyone tried these? If so, what do you think about them?
mode1ace
06 Sep 2020, 14:24
I have one as a loose switch. They're pretty smooth. Not a fan of linear though tbh, only bought them as I was curious if you could swap in alps mount SMK click leaves. I just can't for the life of me open them reliably.
zrrion
06 Sep 2020, 18:21
I have a few nos ones and they aren't lubed, I'm pretty sure harvested ones are. The source for the nos ones probably got some really late production switches where they had decided to forgo lubing. Without lube they are scratchy so unless you are harvesting or plan to June them yourself they aren't that great.
mode1ace
07 Sep 2020, 20:41
This surprises me, mine's perfectly smooth. No idea if it's lubed, but it's in no way scratchy.
