DSA-like keycaps but angled?
Mikhail-222
12 Aug 2021, 20:39
Hi there!
I am new to the forum and keyboard modding.
I've been searching for a good keycap set for a while, I must say, among the mass produced I like only DSA-like keycaps, but I wondered if there exist DSAs but with Cherry-like angles (sculpted? is that the right term?)
Anyway, it is quite hard to research and I am not that informed on the topic. But just few days ago I found this interesting set on aliexpress:
https://www.aliexpress.com/item/1005002 ... 516cmPelHo
BTW, I can't find out how to post images yet, I guess I need to use some image hosting and make a link?
The seller's info: "Doubleshot ANSI UK ISO LA Cherry Ball Shape Thick PBT Keycap For MX Keyaboard 61 87 104 Melody 96 KBD75 FC980M Keychron".
The brand is YMDK I guess. So they name it "Cherry ball shape". The keycaps look really good, I ordered these and will see. It seems to be exactly what I was looking for.
Do you recognize this profile? Any examples of keyboards with such caps?
And on a side note: why there are so few keyboards with such caps? Is that only me who thinks DSA-like has the most comfortable tactile feel?
Johnbo
12 Aug 2021, 20:55
SA or MT3 profile caps might interest you. I have an MT3 set and I love it.
Rayndalf
12 Aug 2021, 22:13
DSS is an angled form of DSA SP (re)introduced a couple years ago.
It's similar to SA or MT3 (in that it's a sculpted spherical set), but DSS is shorter like Cherry or DCS.
Palatino
12 Aug 2021, 22:43
Mikhail-222 wrote: 12 Aug 2021, 20:39
Welcome to the site! To add images without the need for a link, click on the Attachments tab at the bottom of the message editor, then on the Add Files button, browse to select a file, wait for it to upload, then finally hit the Place Inline button. If it's a particularly large file or you want to add many, you can use the Spoiler button at the top of the editor to tuck it away like this:
12 Aug 2021, 22:49
SA has a smooth surface, while DSS and MT3 are textured.
I find that MT3 is a bit too dished for my taste though.
Mikhail-222
13 Aug 2021, 00:45
Rayndalf wrote: 12 Aug 2021, 22:13 DSS is an angled form of DSA SP (re)introduced a couple years ago.
Thanks, yes I think DSS is the closest to what I found, only the ROW 4 surface angle on DSS is bigger than on that "Cherry Ball" lets call it so.
Image:
As for the SA cap itself, they look similar in the dish area, but the sides are too steep compared to DSA, so that is a departure from
what im looking for. I feel like I'd prefer a more pillow-like shape, like DSA with even a bit more rounded-off and gentle side slopes.
13 Aug 2021, 08:31
Mikhail-222 wrote: 12 Aug 2021, 20:39[…] So they name it "Cherry ball shape". […]
I would suppose "ball shape" actually refers to "spherical" (as opposed to "cylindrical").
