Hello, I have a new Model F122. When my computer (Lenovo, Windows 11) is put to sleep it seems to shut down power for the Leyden Jar controller (Num Lock LED turns off). I then cannot wake the PC with the keyboard. If I wake it using other means the F122 stays off, the only way to use it again is to unplug and to replug. I checked settings in the Device Manager and don't see any issues. Other keyboards don't have this issue.
Has anyone come across this and has advice for me?
Leyden Jar loses power when Computer sleeps
- Falkenroth
- Main keyboard: 1994 IBM Model M 51G8572
- Main mouse: Standard Issue Lenovo
- Favorite switch: Catastrophic Buckling Spring
My Unicomp Mini M was doing the same thing a few years ago but I thought that was corrected back then. What year is the board? My Mini M is a 2022. I had to send it back to Unicomp and have a controller replaced or software installed on the controller. Can't remember. Yea it's a annoying issue.
- fohat
- Elder Messenger
- DT Pro Member: 0158
I never use "sleep" but I think it is fair to assume that the adapter does not "wake up" until some moments after the motherboard "wakes up" and activates the USB ports.
