File:Matrix scan current flow without diodes.svg
Jump to navigation
Jump to search
Size of this PNG preview of this SVG file: 733 × 398 pixels. Other resolution: 320 × 174 pixels.
Original file (SVG file, nominally 733 × 398 pixels, file size: 73 KB)
Description | Example diagram of three keys being pressed on a keyboard matrix simultaneously, where there are no anti-ghosting diodes protecting the circuit: a fourth keypress is being incorrectly detected due to current passing through a switch in the wrong direction. |
Source | Own work |
Date | 2012-10-07 |
Author | Daniel beardsmore |
Licence | Public domain or nearest equivalent |
Notes | TODO: Make suitable for colour-blind readers |
Licencing
Public Domain. If your country doesn't have any such notion, treat the work as having all rights waived.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 02:39, 7 October 2012 | 733 × 398 (73 KB) | Daniel beardsmore (talk | contribs) | Row and column labels reversed >_< Also, worked around issues with the way the wiki renders the image compared to Inkscape (font size, and incorrect clone stroke) | |
02:23, 7 October 2012 | 733 × 398 (72 KB) | Daniel beardsmore (talk | contribs) | Example diagram of three keys being pressed on a keyboard matrix simultaneously, where there are no anti-ghosting diodes protecting the circuit: a fourth keypress is being incorrectly detected due to current pass... |
- You cannot overwrite this file.
File usage
The following page links to this file:
