Tai-Hao TH-5539
From Deskthority wiki
(Redirected from Tai-Hao TH-5539-5)
Tai-Hao TH-5539
FCC ID GOG3YLTH-5539
Manufacturer Tai-Hao
Layouts Focus layout, ISO, 101-key ISO-like
Keyswitches Alps SKCM Blue
Tai-Hao Aruz
Tai-Hao APC series
Interface XT/AT switchable
TH-5539 refers to a variety of keyboards manufactured by Tai-Hao, using a number of different cases and switches, and sharing a single model number and FCC ID. The specific variant designations given on this page were provided by Tai-Hao, and may not be completely accurate considering how much time has passed since the keyboards were manufactured. Many such examples carry the Fame badge, a name used by Tai-Hao before APC and Clicker.
All examples found so far use a DIN 5 connector and are XT/AT switchable.
The Tai-Hao brochure below refers to the keyboards as "APC-n", e.g. "APC-8". Tai-Hao expanded "APC-8" as "APC switch, TH5539-8" and "APC-3" as "APC switch, TH5539-3".[1]
Unknown variant
The specific model number of this variant is not known. The case style is reminiscent of the Chicony KB-5161 and both may have been inspired by the Alps Bigfoot series. It uses Alps SKCM Blue switches, suggesting that this was one of the older designs of TH-5539 keyboard, before Tai-Hao started using their own switches. The keycaps are pad printed. The PCB accepts both Alps and Cherry MX switches, similar to the NTC KB-6151N. Due to the "102" marking additional switch positions on the PCB, an ISO version may have existed.
TH-5539-1
Confirmed only as "APC-1". This is a flat, minimalist design with no margin above the function keys for a legend strip. The shape is very similar to TH-5539-3, without any adornments, and with the status LED panel lined up with the function keys as there is no recess for a badge. This can be seen in the Tai-Hao brochure. In the 1992 example below, the switches are APC-branded, and the PCB is marked "APC-3A", indicating that APC-3 and APC-1 share the same PCB.
TH-5539-2
TH-5539-2 features a gentle bowl profile, with the whole keyboard curving up gently towards the sides to complement the sculptured keycap profile. The keyboard has been found with Alps SKCM Blue switches and TH series doubleshot keycaps.
TH-5539-3
TH-5539-3 is one of the better-known models. The design is quite similar to the more common TH-5539-5; TH-5539-3 has a narrower border, and the keycap skirts have round corners instead of the square corners of those of TH-5539-5. There is also a thin groove around the edge, and it lacks the central dip of TH-5539-5.
The images below show APC switches and laser marked TI series keycaps. It was also sold with Alps SKCM White switches[Citation needed] and with doubleshot TI series keycaps.[2]
TH-5539-5
TH-5539-5 is the most common TH-5539 model, typically found with Tai-Hao Aruz switches and doubleshot keycaps. The enter key uses an Alps SKCM White switch;[3] in one instance this has been found to be a circa 1989 or 1990 switch,[4] in a keyboard from 1989.[5]
The case dips down in the middle of the alphanumeric cluster. Aruz examples have TH series keycaps, but a different version also exists with TI series keycaps and coloured modifier legends.[6] The switches in the referenced example are cited to be a 'white ALPS "complicated" clone'; the pictures show a switch with long side tabs, which may be the rare unbranded Alps SKCM White. The switches do not appear to be APC series.
Tai-Hao's example
This example uses doubleshot TH series keycaps; the Arabic legends are silkscreen printed.
Additional example
This example uses doubleshot TH series keycaps.
TH-5539-8
TH-5539-8 relocates the status LEDs to the space above Insert/Home/Page Up. The status indicator space is instead used to hold a pad of sticky notes. A flip-up function key legend holder is placed above the function keys. The switches are APC series and the keycaps are double-shot and appear to be TI series.
TH-5539-9
TH-5539-9 has an IBM Enhanced Keyboard-style case, and has been found with blue Alps switches. The keycaps are a different series; they are ABS and are likely to be silk-screen printed. This may be the last keyboard model made with this keycap series.[7]
Literature
External links
References
  1. Correspondence with Tai-Hao, 2017-02-03
  2. utensilia.tk — Fame / CTS 5539
  3. Deskthority — Let's have a look at the T̶a̶i̶-̶H̶a̶o̶ Aruz switch!
  4. geekhack — Tai-Hao FAME TH-5539 (Aruz switches)
  5. YouTube — Tai-Hao FAME TH-5539 review (Aruz switches)
  6. utensilia.tk — Fame 5539
  7. Correspondence from Tai-Hao, 2017-05-11
