Great/Interesting Finds
Harshmallow
05 May 2017, 16:15
The listing description also says it has White Alps. That may have been updated since you guys took a look though.
Hypersphere
05 May 2017, 23:23
I wonder if they are pine or bamboo white Alps in that Packard Bell?
mike52787
Alps Aficionado
06 May 2017, 00:44
Hypersphere wrote:I wonder if they are pine or bamboo white Alps in that Packard Bell?
Pine. that board is far too early for bamboo.
Flammberger
06 May 2017, 17:15
Apple IIC with Apple hairpin switches:
http://www.ebay.de/itm/Apple-IIC-2c-Tas ... 2278288115
06 May 2017, 17:21
Flammberger wrote: Apple IIC with Apple hairpin switches:
How can you tell?
mike52787
Alps Aficionado
06 May 2017, 17:41
How can you tell?
super easy to tell. There is no plate, and the alps ones have a plate.
06 May 2017, 18:03
How can you tell?
Ah, I see, excellent.
I've heard these switches are super awful. I'm interested 8) .
mike52787
Alps Aficionado
06 May 2017, 18:20
Chyros wrote: I've heard these switches are super awful. I'm interested 8) .
would love to see a video of them!
Slom
06 May 2017, 21:52
Here is a pair that is maybe not great but certainly interesting:
http://www.ebay.com/itm/Vintage-Micro-S ... 2504343824
http://www.ebay.com/itm/Vintage-Micro-S ... 2537573126
So what are the switches on the second board?
j0d1
06 May 2017, 22:54
A little bit outside my price range (shipping cost a leg to Canada, sigh):
* http://www.ebay.com/itm/222499908510
* http://www.ebay.com/itm/222499908506
07 May 2017, 01:41
Since I have vowed not to use eBay, I can neither buy these nor have someone proxy them for me, but they're worth having:
http://www.ebay.co.uk/itm/x1-Mount-Swit ... 2043761222
You'll see that it's one of only two known SMK J-M0404 known variants that I was unable to acquire:
wiki/SMK_J-M0404_series#Known_variants
With one eBay seller I was able to find him outside of eBay to buy the goods, but not this time, otherwise I'd buy that straight away!
However, you can see here something strange — black top and brown slider:
http://www.ebay.co.uk/itm/KEYSWITCHES-A ... 2419493348
Assuming that's not a Frankenswitch, that's also worth having if the seller still has one (the listing is for Mitsumi).
Topre Enthusiast
07 May 2017, 01:42
[ XMIT ]
07 May 2017, 17:17
For those of you in the US near a Harbor Freight, ultrasonic cleaners are on sale for $70.
https://www.harborfreight.com/25-Liter- ... D%3D%0D%0A
That URL includes coupon code 61918489.
Sometimes automotive trim tools (for opening boards) and digital calipers (for precise measurements) go on sale. I've gotten calipers for $8.
I have no affiliation with Harbor Freight other than sometimes spending too much money there.
ohaimark
Kingpin
07 May 2017, 17:42
Don't buy their ultrasonic cleaner. Better to pick one up from eBay. The trim tools and other accoutrements at Hobofarts, I mean Harbor Freight, are reasonable.
Techno Trousers
100,000,000 actuations
07 May 2017, 18:39
ohaimark wrote:Don't buy their ultrasonic cleaner. Better to pick one up from eBay.
What's a good, yet reasonably priced brand? The larger Branson ones are super expensive, even used.
gnmar2723
07 May 2017, 19:06
Ask wodan. He got his from ebay and he says it works great.
Hypersphere
07 May 2017, 19:12
Upon recommendation from XMIT, I got the iSonic P4820-WPB from Amazon for about $88 shipped. It has served me well thus far.
https://www.amazon.com/iSonic-Professio ... +p4820-wpb
[ XMIT ]
07 May 2017, 21:44
ohaimark wrote: Don't buy their ultrasonic cleaner. Better to pick one up from eBay. The trim tools and other accoutrements at Hobofarts, I mean Harbor Freight, are reasonable.
The one I posted is the same one that I and elecplus have. I'd call it "Chinese OEM Brand", available under a bunch of different labels (iSonic being one of them).
I use this for all my key cap work and it works great. It's not really powerful enough for much more.
Techno Trousers
07 May 2017, 21:56
Great, thanks for the recommendation.
ohaimark
Kingpin
07 May 2017, 23:37
This is what I have:
http://m.ebay.com/orderDetails?itemId=1 ... 0434451006
Much more powerful and a better deal overall. It has 2x 60 watt transducers, whereas the one XMIT has uses a single transducer. It can handle more keycaps and does a better job with cleaning blind holes.
08 May 2017, 00:28
That's a private link.
ohaimark
Kingpin
08 May 2017, 00:32
gnmar2723
08 May 2017, 01:38
What solution do you guys use to wash keycaps? What about switches?
ohaimark
Kingpin
08 May 2017, 03:07
I plop a couple of denture tabs in the water. Otherwise a teaspoon of dish soap works fine.
[ XMIT ]
08 May 2017, 04:14
ohaimark wrote: My bad. Here is the proper one:
http://m.ebay.com/itm/120W-Stainless-St ... 2412636397
That's probably a better deal assuming it is in stock. That being said I've been reasonably happy with mine. I bought it in 2011 to clean bicycle parts. It was not strong enough for that so I shelved it until it found a second life cleaning key caps.
[ XMIT ]
08 May 2017, 04:16
gnmar2723 wrote: What solution do you guys use to wash keycaps? What about switches?
I feel like everyone has their own favorite mixture.
Similar to ohaimark, I use distilled, deionized, or reverse osmosis water (whatever I can get my hands on to avoid calcium scale) and two denture tabs, as well as about 2 tsp of unscented dishwasher fluid (has enzymatic cleaners and doesn't sud). I usually make sure the water is heated to about 150 F - warm enough for a good cleaning but not so hot that it will warp Space bars (which I try to wash by hand anyway unless I *know* they're not ABS plastic).
As for switches: sure, just make sure to open them up before cleaning. The dirt needs to go somewhere.
gnmar2723
08 May 2017, 04:59
No special solution for switches to avoid corrosion of the contacts? I'm guessing deionized water works well enough on its own anyways.
ohaimark
Kingpin
08 May 2017, 09:56
Is this the biggest big-ass enter ever? You be the judge:
http://www.ebay.com/itm/TA-ADLER-ROYAL- ... 2466718866
08 May 2017, 09:58
ohaimark wrote: Is this the biggest big-ass enter ever? You be the judge:
Possibly yes. :o
emdude
Model M Apologist
08 May 2017, 10:07
Big-ass shipping too, $120 to CA! :o
Return to “Other external”
