(Model MF) Remodeling the Model M (aka.. the Mara)
- Techno Trousers
- 100,000,000 actuations
- Main keyboard: IBM Model F-122
- Main mouse: Mionix Naos
- Favorite switch: Capacitive Buckling Spring (Model F)
- DT Pro Member: 0159
Also putting shelf liner material or other damping materials into the case to cut down on resonance.
- DMA
- Main keyboard: T420
- Main mouse: Trackpoint
- Favorite switch: beamspring
- DT Pro Member: NaN
On the BARREL. Putting it on the flipper will make flipper heavier, changing everything. Also it will unstick pretty quickly from all that vibration and you'll have lots of silicone beads inside your keyboard
As for "how's everyone" - I joined the ranks of Facebook 3 weeks ago, trying to drink from bootcamp firehose. CS is proven to be repeatable on $10 off the shelf protoboards, hostside utility still misses the macro editor (firmware has online-updatable macro support, but you need to manually edit binary config files to use it
- Techno Trousers
Ha ha, wow, I got that one wrong. I went back to the original thread, and I see where I went wrong. It's on the underside of the barrel, where the flipper will hit it on the upstroke. Here's the original thread linked for reference:
viewtopic.php?t=16550
- Techno Trousers
I can't wait to build my Model MFs with CommonSense controllers. I could edit binary config files, but I'd prefer ASCII files.DMA wrote: CS is proven to be repeatable on $10 off the shelf protoboards, hostside utility still misses the macro editor (firmware has online-updatable macro support, but you need to manually edit binary config files to use it)
- drevyek
- Main keyboard: Leopold FC980C
- Favorite switch: Alps Orange
I remember you mentioning interviewing places, congrats on the new position!DMA wrote: As for "how's everyone" - I joined the ranks of Facebook 3 weeks ago, trying to drink from bootcamp firehose. CS is proven to be repeatable on $10 off the shelf protoboards, hostside utility still misses the macro editor (firmware has online-updatable macro support, but you need to manually edit binary config files to use it)
Great to hear that CS is so well developed. On resumption of the GB, it sounds like the turn around for production of CS would be minimal. Fantastic news.
I know the floss mod, have been using it for a while now. Until the MF goes through, I'll have a go at the silicon mod on my M, though it might be a bit too much on those short flippers. I'll also get some felt to stuff the case, and maybe something for the barrel plate, we'll see. It'll be interesting to see just how damped we can get it.
gianni
Sorry to say something at this stage, but would it be possible to make the plates compatible with xt barrels? Is the only difference in the position of the pin, which in AT is at 4 o' clock, while in xt is at 6? This could be interesting because xt replacements cost less.
- drevyek
Don't worry- it's already in the designs. Take a look at some of the renders on the first post of this thread: the pegs are all pointing out at the bottom a la XT.
I'm not sure how it will eventually go down, but when it was originally set up, there was an option to purchase barrels etc in the GB, as opposed to requiring you to source your own.
- fohat
- Elder Messenger
- DT Pro Member: 0158
As far as I know, all of the "revival" projects accommodate both "side buttress" alignment tabs (AT/122) as well as the "vertical stud" (XT/Bigfoot) type.
- E TwentyNine
- Main keyboard: AT Model F w/ Tenkeyless mod
- Main mouse: Logitech M310
- Favorite switch: Beam spring
Monthly bump, awaiting exit from limbo, hope all is well LL.
- lot_lizard
- Main keyboard: Indy SSK Model MF
- Main mouse: Logitech Anywhere MX
- Favorite switch: Beamspring
It’s been a struggle on this end to be honest. Some ups and more downs. I really don’t want to go into too much detail, but I do wish I still had the emotional strength of a 6 year old (she’s a trooper).
I really shouldn’t announce this yet, but we will be initiating the re-commencement of our buy a little more properly. We have a proper site to place orders going forward. The code is from the ground up, and will include some charts (our friends at JFreeCharts), etc... but the idea is to create a site where anyone can facilitate a proper group buy without any commission from us (each drop has a unique owner and PayPal collector). It’s 70% (no products or drops yet) there if anyone wanted to take a peek and provide feedback. The subscription bit is fully functional if you wanted to sign up. The concept is to be a DT partner (allowing you to apply your handle in the cart on checkout), and provide discounts based on validated membership levels if applicable. In our case, it will be extremely similar pricing to the original buy if you participated (I have the list
https://mfdrop.com
- Khers
- Main keyboard: LZ CLSh
- DT Pro Member: 0087
I got an error trying to sign up, and now I can't access the page, but instead get greeted by the same error message until I flush cookies. If I try to sign up again, I get the same error and the process is repeated.
Error says:
Error says:
Fatal error: Uncaught Error: Call to a member function getDeskthorityUser() on null in /home/mfdrop5/public_html/app/model/user.php:116 Stack trace: #0 /home/mfdrop5/public_html/index.php(39): User->populateUserGoogleOAuth(Array, Object(DB)) #1 {main} thrown in /home/mfdrop5/public_html/app/model/user.php on line 116
- lot_lizard
try now if you would...
- lot_lizard
- depletedvespene
- Main mouse: Logitech G700s
- DT Pro Member: 0224
I like the "MF" initials.lot_lizard wrote: https://mfdrop.com
- lot_lizard
Appreciate. Graphic designers we are not, but manage to bumble into some reasonable ideas along the way. Credit DT and Matt3o as original inspiration
Right now they are just a placeholder for cart testing (PayPal sandbox). We have ~30 items to eventually list as part of the storefront when life rights itself on this end. Several vintage boards, parts, and other inspirations that need new homes. All things outside of the original MF project. The hope is others can leverage as well. Again, it is essentially a PayPal collector for anyone that we trust to run buys or sell individual items
- depletedvespene
- Wingklip
- Main keyboard: IBM 3178 Model F C2
- Main mouse: G502 Logitech Proteus core
- Favorite switch: Beam/plate spring
Comrade, glad to see you back again! I hope time is the only thing between now and production
Got like 8 Model M's ready for full restoration and conversion to F class, all that's left is this wunderwaffe to complete the nuclear device
- xTek
- Main keyboard: Redragon K551 & Dell Quietkey RT7D5JTW
- Main mouse: Logitech B100
@lot_wizard Could you drop a VERY ROUGH estimation date on Phase 2?
You don't have to be accurate, we won't take your word for it, I am just curious to when we could expect it to happen.
- Techno Trousers
Many of us are still waiting patiently for completion of phase one. I think any estimates about phase two will have to wait until then.
- Hypersphere
- Main mouse: Logitech G403
- DT Pro Member: 0038
@lot_lizard: I've been away from the forums for a long time due to personal matters and work obligations. Just now checking in again. Still very interested in the F-SSK project if/when it resumes. Thanks.lot_lizard wrote:It’s been a struggle on this end to be honest. Some ups and more downs. I really don’t want to go into too much detail, but I do wish I still had the emotional strength of a 6 year old (she’s a trooper).
I really shouldn’t announce this yet, but we will be initiating the re-commencement of our buy a little more properly. We have a proper site to place orders going forward. The code is from the ground up, and will include some charts (our friends at JFreeCharts), etc... but the idea is to create a site where anyone can facilitate a proper group buy without any commission from us (each drop has a unique owner and PayPal collector). It’s 70% (no products or drops yet) there if anyone wanted to take a peek and provide feedback. The subscription bit is fully functional if you wanted to sign up. The concept is to be a DT partner (allowing you to apply your handle in the cart on checkout), and provide discounts based on validated membership levels if applicable. In our case, it will be extremely similar pricing to the original buy if you participated (I have the list)
https://mfdrop.com
- elecplus
- DT Pro Member: 0082
I chatted with lot-lizard this week. He said sometime in the the next few months he hopes to become active again.
- Techno Trousers
That's great news, I appreciate you posting it, Cindy. He'll be welcomed back with open arms whenever he's ready.elecplus wrote:I chatted with lot-lizard this week. He said sometime in the the next few months he hopes to become active again.
green-squid
- Main keyboard: --
- Main mouse: --
- Favorite switch: --
I really hope this will become an affordable option so that we can ALL have a good IBM without a bolt mod!
My suggestions are:
put a small smiley face on the PCB and the names of the designers to make it less boring
My suggestions are:
- hjjhhh.jpg (27.73 KiB) Viewed 14827 times
green-squid
- Main keyboard: --
- Main mouse: --
Bump
