Is that gunk grease? It looks like high temp black gear grease to me. Gross xDOldIsNew wrote: This is listed as an Eagle IV keyboard - does anyone recognize what the type of switches these are?
https://www.ebay.com/itm/Rare-Vintage-E ... SwpLdZzPgt
If not, does anyone at least have a theory about the black gunk?
IDENTIFY THE KEYBOARD thread
rich1051414
- Main keyboard: Whitefox Zealios 67g
- Main mouse: Logitech G900
- Favorite switch: Alps Orange
- Keybug
- Main keyboard: so many!
- DT Pro Member: 0208
Hey guys,
Interested in the bottom one, which appears to have a Highscreen logo, but I've never seen this type from Highscreen.
Judging by the shape / curve of the case it could be RD. But are those Tai-Hao caps?
- snufflecat
- Main keyboard: Model M
Anyone want to take a guess if this is rubber dome or not?
https://www.tradera.com/item/340827/267 ... rd-kb-9968
- snufflecat
- TheAdmiralty
- Main keyboard: IBM Model M (1391401)
- Main mouse: Logitech G602
https://www.ebay.com/itm/Intergraph-Ter ... .l4275.c10
Think this thing is rubber dome? Never seen anything like it before.
- snufflecat
Does anyone know if this one's mechanical? Solidteck ACK-298.
- Daniel Beardsmore
- Main mouse: MS IMO 1.1
Some metal contact figures:
[wiki]Tokai MM9 series[/wiki]: 2 million
[wiki]Futaba ML series[/wiki]: 3 million
[wiki]Futaba MA series[/wiki]: 5 million (per Samducksa), 10 million (per Sejin), 50 million (per Sejin/Futaba)
[wiki]Alps SKBL/SKBM series[/wiki]: 10 million
[wiki]General Instrument Series S950[/wiki]: 10 million
10 M is also the rated lifetime of various Mitsumi types including KPQ Type "hybrid" and KFK Type rubber dome over membrane.
- Daniel Beardsmore
I'm simply correcting your fallacy that switch lifetime of 10 M is indicative of membrane. The Himake Alps clone switches that match up with what Ortek used were rated for 5 M, and 10 M for the better type that Monterey used. Membranes aren't inherently unreliable, which we already know from the Model M.
That keyboard does remind me a bit of the Ortek Mac keyboards with Alps switches (and the strange USB badge is where Mac keyboards had their power key), and it has the old pre-XP Windows logo, and combined with the hideous typography on the box it does look pretty old.
However, a peak force of (I assume they are trying to say) 60±15 g, puts it below that of tactile Alps at 70 g.
It probably is rubber dome. I'd expect the specifications to indicate clearly if it was metal contact (as "mechanical switch") but it is by no means certain.
- snufflecat
Does anyone recognize the top left IBM board?
- seebart
- Offtopicthority Instigator
- Main keyboard: Rotation
- DT Pro Member: 0061
- Keybug
Can anyone tell if I've got myself a Hall effect board with this Rafi? I found photos of one and it had an almost identical case. Thanks!
https://rover.ebay.com/rover/0/0/0?mpre ... 2742064157
- Daniel Beardsmore
That's from RAFI's Type B Series (full travel keyboards). The 2007 brochure I found gives B4 (keypad, metal contact), B6-C (standard layout, Hall effect), and B8-C (also Hall effect; narrower ad-hoc assembly design, like on eBay but with Windows keys and no LED area).Keybug wrote: Can anyone tell if I've got myself a Hall effect board with this Rafi? I found photos of one and it had an almost identical case. Thanks!
I don't know if there's a metal contact B6 or B8 — I can check later as I may have some more details stashed away. B8-C seems to be uncommon, too.
- seebart
Very nice find!Keybug wrote: Can anyone tell if I've got myself a Hall effect board with this Rafi? I found photos of one and it had an almost identical case. Thanks!
- Daniel Beardsmore
I've uploaded the March 2007 RAFI Standard Keyboards catalogue into [wiki]Category:RAFI catalogues and brochures[/wiki], but this is too new. Some muppet has set the wiki file upload limit to 8 MB (!!) so I can't upload the older catalogue from February 2001, but you can find it here: https://www.relayspec.com/catalogs/0144 ... ial_kb.pdf
From the two, you can see that the keyboard numbers don't seem to correspond to anything. The type in question could be metal contact or Hall effect, though.
RAFI don't seem to have keyboards listed on their website any more.
- Keybug
Thanks very much for your input! I'm prepared to bet now it's not Hall, but we'll see. Still a nice find, I guess... Cheers, Seebart.
invisiblefly
- Main keyboard: Shine 2
- Main mouse: Trackball
- Favorite switch: Brown
what is this keyboard? do you think i can restored and used as usb?
- keyboard.jpg (205.45 KiB) Viewed 7429 times
It's a Honeywell Micro Switch keyboard, a legendary piece of computer history and inspiration for many keysets like round 5. Sadly I don't know of any Honeywell board that is converted
rich1051414
rymut
- Main keyboard: Cooler Master Quick Fire Pro
- Main mouse: Contour RollerMouse Red
- Favorite switch: Blue APLS
- snufflecat
So I just got this IBM keyboard with buckling spring but I've never really seen the model before. Anyone recognise this one?
Also, what about this switch type? It's on a board from an old receipt/calculator-thingy.
Thanks!
- seebart
- mike52787
- Alps Aficionado
- Main keyboard: G80-5000HAAUS
- Main mouse: Zowie EC1-A
- Favorite switch: Vintage MX Black
- DT Pro Member: 0166
- Daniel Beardsmore
Curious, so did Lexmark take over the Greenock factory?
