IDENTIFY THE KEYBOARD thread
mike52787
Alps Aficionado
18 Nov 2017, 23:27
It certainly seems that that is the case.
TheAdmiralty
19 Nov 2017, 02:02
https://www.ebay.com/itm/NEW-NIB-COMPUT ... SwaEhZJNcH
Just a rubber dome clone of the Model M/F-122? Price is flat out stupid but I'm curious.
snufflecat
19 Nov 2017, 11:27
mike52787 wrote:
snufflecat wrote: So I just got this IBM keyboard with buckling spring but I've never really seen the model before. Anyone recognise this one?
IBM Model M2
seebart wrote:
snufflecat wrote: Also, what about this switch type? It's on a board from an old receipt/calculator-thingy.
Thanks!
Mitsumi simplified:
wiki/Mitsumi_simplified
Thanks guys! :)
mike52787
Alps Aficionado
19 Nov 2017, 14:55
I think I have seen that somewhere, and yeah I think it was a rubberdome. However there are 122 style layout boards also branded "Computer Lab International" which have mx blacks and mx clones.
Keybug
19 Nov 2017, 22:06
Anyone know what this is? Don't think I've ever seen a white escape key on a vintage board like this. Escape also looks almost BTC-style large, but I think here it's due to the angle of the photo. Thanks.
Keybug
19 Nov 2017, 23:24
Turns out it's a Chicony 5162. I guess no one can say for certain what switches it has, just from the label...
Mr.Nobody
21 Nov 2017, 02:55
@keybug
I have one with blue alps.
Myoth
22 Nov 2017, 22:38
Myoth wrote: also if the keycaps MX-compatible ?
I need to get some MX-M8 to see if I can actually use this, it's been so long since I got it and I've yet to do anything about it. That was my first post on DT :lol:
snufflecat
23 Nov 2017, 09:31
My latest catch. It's got vintage mx blacks, but does anyone know what type of contact this is?
23 Nov 2017, 09:52
Looks like an RJ45 jack.
23 Nov 2017, 10:01
RJ45 is a wiring arrangement. The jack is 8P8C (8 positions, each position being wired up — 8P6C for example would have the two outer connecting strips absent). And that's nowhere near 8P wide. That appears to be 4P4C. (The best-known 4P wiring arrangement is RJ11 for telephones.)
23 Nov 2017, 10:13
̶L̶o̶o̶k̶s̶ ̶l̶i̶k̶e̶ ̶a̶n̶ ̶R̶J̶4̶5̶ ̶j̶a̶c̶k̶.̶
Looks like a Beardsmore correction. :lol:
It's better to be corrected than to be wrong.
snufflecat
23 Nov 2017, 11:06
Daniel Beardsmore wrote: RJ45 is a wiring arrangement. The jack is 8P8C (8 positions, each position being wired up — 8P6C for example would have the two outer connecting strips absent). And that's nowhere near 8P wide. That appears to be 4P4C. (The best-known 4P wiring arrangement is RJ11 for telephones.)
I'll see if I can get a better shot later, maybe that helps? And I guess the only way to get this to work is to make your own adapter?
purdobol
23 Nov 2017, 11:20
snufflecat wrote: I'll see if I can get a better shot later, maybe that helps? And I guess the only way to get this to work is to make your own adapter?
Depends on the protocol it uses. There's a chance for standard AT, which would only require custom cable RJ45 -> PS/2.
If it's something exotic than teensy (or clone) and custom firmware. Photo of the board could help, the connections sometimes are signed.
Polecat
23 Nov 2017, 17:35
seebart wrote: Looks like an RJ45 jack.
Looks more like RJ9. RJ45 (8p8c) is the 8 pin connector used for ethernet. RJ11 (6p4c) is the 4 pin used from telephone to wall. RJ9 (4p4c) is the smaller 4 pin used on telephone handsets (and on some terminal keyboards and early Macs). RJ8 (6p6c) is the 6 pin used on some Televideo keyboards. (edit: corrected RJ8 to RJ9 and added xpxc designations per Mr. Beardmore's absolutely correct definitions)
Myoth
23 Nov 2017, 17:57
soarer's ceonverter works on this, you can check orihalcon's ebay to buy one
https://www.ebay.com/itm/6FT-Soarers-WY ... SwGYVXACHX
I'm pretty sure this is a Wyse clone after all ...
23 Nov 2017, 18:11
Looks more like RJ9. RJ45 is the 8 pin connector used for ethernet. RJ11 is the 4 pin used from telephone to wall. RJ9 is the smaller 4 pin used on telephone handsets (and on some terminal keyboards and early Macs). RJ8 is the 6 pin used on some Televideo keyboards. (edit: corrected RJ8 to RJ9)
Three posts up vs. double post take your pick.
23 Nov 2017, 18:17
Polecat wrote: Looks more like RJ9. RJ45 is the 8 pin connector used for ethernet. RJ11 is the 4 pin used from telephone to wall. RJ9 is the smaller 4 pin used on telephone handsets (and on some terminal keyboards and early Macs). RJ8 is the 6 pin used on some Televideo keyboards. (edit: corrected RJ8 to RJ9)
Wrong on a few counts. A modular connector is a registered jack only when used for that Registered Jack's particular purpose. There are registered jacks that are not modular connectors
It's the same situation as with 6-pin mini-DIN and PS/2. Also, RJ11 uses a 6P2C connector.
#petpeeve :P
Polecat
23 Nov 2017, 18:19
Thanks, edited while being corrected. :lol:
Better to be safe and sorry.
23 Nov 2017, 18:28
Polecat wrote: Better to be safe and sorry.
Relax. ;) Not my correction anyway. :mrgreen: The correction of the correction was...correct. :lol:
Polecat
23 Nov 2017, 18:37
If I was any more relaxed I'd be gulping down tall ones. It's only 9 am here, but it must be noon somewhere in the world? Love it that I can be correctly corrected, learn something new, and relearn something I had forgotten over thirty years ago all at the same time. :D
23 Nov 2017, 19:14
:o :P
Polecat wrote: It's only 9 am here, but it must be noon somewhere in the world?
7:14 PM :mrgreen:
Polecat wrote: Love it that I can be correctly corrected, learn something new, and relearn something I had forgotten over thirty years ago all at the same time. :D
Yes that's the normal learning curve here regardless of your time-zone... :lol:
23 Nov 2017, 19:18
Ah, right, RJ11 is 6P2C … the cables I'm thinking of are the UK ADSL cables, which are 6P4C — I'd never noticed that the outer two positions were unused, so I mistook the plug for 4P4C.
Apple's ADB is unusual in that it's one of the rare protocols that uses a plug with the same number of pin positions as there are operational conductors in the cable. Now if only Apple had actually made ADB hot-swap safe — it worked perfectly at the OS level (demonstrated many times), but it was a no-no in terms of the circuitry.
23 Nov 2017, 19:57
Just for fun I'll share this "Cherry-Apple" that heymark sent me today:
https://tieba.baidu.com/p/4034770431?sh ... 3344350041
Myoth
23 Nov 2017, 20:22
seebart wrote: Just for fun I'll share this "Cherry-Apple" that heymark sent me today:
That looks weird, but a good weird :)
23 Nov 2017, 20:55
Pretty strange if you ask me but hey why not and if it works then that's quite a unique build.
Keybug
25 Nov 2017, 22:10
The bottom board with the Chinese sublegends is 100% rubber dome, right? Thanks.
25 Nov 2017, 22:16
Those are Japanese sublegends.
Tuntematon
26 Nov 2017, 04:24
Keybug wrote: Turns out it's a Chicony 5162. I guess no one can say for certain what switches it has, just from the label...
I would say green Alps, going by the letter designation at the end of the serial number.
Keybug
26 Nov 2017, 10:31
webwit wrote: Those are Japanese sublegends.
Sorry, my bad. The ad said Chinese and I didn't double-check.
