IDENTIFY THE KEYBOARD thread
Worthless_Owl
- Main keyboard: HHKB Pro 2
- Main mouse: Steelseries Rival 100
- Favorite switch: Topre 45g
Is this really a Model F keyboard? I took this from an IBM 6746 typewriter. The inspection label said Model F, but it has rivets on its back, also a thin rubbery mat between the metal plate and the plastic top. Some pics of the board:
Also this might not belong to this thread, but i have some spring that moves around freely inside the chamber. Is there a way to set them back without having to take apart anything? A link to a thread discussing this is ok.
- Daniel Beardsmore
- Main mouse: MS IMO 1.1
I didn't know IBM had a keyboard plant in Mexico — I thought that would be Maxi Switch.
It's like they grabbed the wrong label, as the Model F part is pre-printed.
- Myoth
- Main keyboard: IDB60
- Main mouse: EC1-A
- Favorite switch: Cap BS
I'm pretty sure this is a Model F but I definitly need someone to identify what this keyboard is. And if it's somewhat rare ?
- Chyros
They had one in Guadalajara - Maxi Switch's plant from what I understood at least is in Hermosillo (headquartered in Tucson, Arizona).
- Keybug
- Main keyboard: so many!
- DT Pro Member: 0208
Very impressive! Green SKCL it is. It's on its way to me for around 30€ shipped. Hope it works 100%.
- seebart
- Offtopicthority Instigator
- Main keyboard: Rotation
- DT Pro Member: 0061
- Chyros
- seebart
- E3E
- Main keyboard: Blue, Neon Green, Striped Amber, Cream Alps, Topre
- Main mouse: Logitech, Topre
- Favorite switch: Alps, Topre
I'm not sure about that. The one I have with Alps SKCL Green is in an ANSI layout and its a three digit serial number. This one isn't exactly close enough to be so certain, in my opinion.
Another thing to note is the "Scr Lock-AT/ Power-XT" on the label, which is something both this and an SKCL Green NTC 6151 I have share. It appears that the Chicony in that picture does as well.
I guess we shall see.
- Tuntematon
Chicony used a whole bunch of different serial number formats. All the 5161/2 and 5160 examples I have recorded so far with the switch type letter codes at the end have held true to their codes. I wouldn't be terribly surprised to find a rule breaker though.
- E3E
Something to note is that the controller of this board says "NTC 6151." Strange, right? I wonder how many of these companies were actually just a single company running under different names or something.
- Riceball
- Main keyboard: model M
- Main mouse: Zowie EC-1 EVO
Does anybody know anything about this board? I picked it up the other week and can't find a thing about it. It has a 4P4C plug if that helps.
- wyse60maybec.jpg (1.51 MiB) Viewed 9281 times
- Daniel Beardsmore
Did I miss all the pictures of it somewhere?
From what I gather, when Nan Tan were bought by Clevo, the keyboard division went to Unikey, a Chicony subsidiary (based on the KB-625x series becoming a Unikey/Chicony model). I'm not aware of any reason for Nan Tan/Chicony involvement as far back as what you appear to be suggesting.
- E3E
Yes, Mr. Beardsmore. Let me open up my keyboard for you to take a picture.Daniel Beardsmore wrote:Did I miss all the pictures of it somewhere?
I also have an NTC 6151 with SKCL Greens, which is the only example of such I've ever seen. It shares a similar indicator sticker as this Chicony (with the mention of XT Power, which I have not seen much of) and the same cap profile (though this has been common in the past, the profile; this profile is most common on Monterey keyboards).
Worthless_Owl
- mike52787
- Alps Aficionado
- Main keyboard: G80-5000HAAUS
- Main mouse: Zowie EC1-A
- Favorite switch: Vintage MX Black
- DT Pro Member: 0166
- DT Pro Member: 0167
- Daniel Beardsmore
OK, so the Nan Tan Chicony is an early model. (Not early as in cherry-jade's 1984 Dah Yang, but early for these Far East models in general.) The PCB holes are intriguing. The top two holes are for Alps, although they seem too vertically aligned. The other two holes — they're not for Cherry, so I wonder what those fit.
I'm not aware that much is known about these Far East keyboards going back to the early to mid 80s — they seem to be typically from around 1987 onwards. That 1984 Dah Yang was a real surprise. The question it raises is: when did these companies start making keyboards?
- Keybug
Definitely green SKCL, got this photo from the seller.
E3E wrote: I'm not sure about that. The one I have with Alps SKCL Green is in an ANSI layout and its a three digit serial number. This one isn't exactly close enough to be so certain, in my opinion.
- Chicony_green SKCL ALPS_3.JPG (1.49 MiB) Viewed 9150 times
- E3E
Well there we go, hehe. Weird that they went from ANSI to THAT though.
Be aware that the KRO is atrocious on these too, by the way.
- Tuntematon
- DT Pro Member: 0011
Indeed. I wonder about that "FLD REL" key next to "TAB": it ought to have two switches under it.
BTW, Wyse ASCII in the Wiki to compare with.
- Riceball
Thanks everyone for pointing me in the right direction.Findecanor wrote:Indeed. I wonder about that "FLD REL" key next to "TAB": it ought to have two switches under it.
You were right about FLD REL having two switches, so I should be able to use Soarer's Wyse converter and set this up with a more standard layout, right?
As for they caps, it was't really visible in the first picture, but they do have side legends too.
- front legends.jpg (884.81 KiB) Viewed 9111 times
- switch check.jpg (946.42 KiB) Viewed 9111 times
- Daniel Beardsmore
The switches are [wiki]Sasse series 25[/wiki].
__red__
- Main keyboard: 4704
- DT Pro Member: 0186
Pretty sure it's an M. It wouldn't make any sense to have a capsense PCB connect to the controller using ribbon FPC. Also, the visible 'foot' in your photo looks like it's coloured white/clear - an F foot is always black.Worthless_Owl wrote: Is this really a Model F keyboard? I took this from an IBM 6746 typewriter. The inspection label said Model F, but it has rivets on its back, also a thin rubbery mat between the metal plate and the plastic top. Some pics of the board:Also this might not belong to this thread, but i have some spring that moves around freely inside the chamber. Is there a way to set them back without having to take apart anything? A link to a thread discussing this is ok.Spoiler:
If you have a loose spring in there you're looking at having to split the plates - sorry
On the bright side:
a) You'll end up with a bolt-modded keyboard which some claim is a better sound.
b) You'll know for absolute certain since you'll see the complete innards.
Soz
- Keybug
There is no way this is not dome/membrane/foil, right (BTC?)? It looks very sexy but I assume isn't worth getting except for archeo-historical reasons?
- foildomemembrane.JPG (80.13 KiB) Viewed 8988 times
- Daniel Beardsmore
"worth getting" is relatively only to your finances and available space. Everything is worth getting in itself, but paying for and storing more clutter may not be practical :)
