Se wisa wer timbrode his hus ofer stan.
Þa com þær micel flod, and þær bleowon windas, and ahruron on þæt hus, and hit ne feoll: soþlice, hit wæs ofer stan getimbrod.
Þa timbrode se dysiga wer his hus ofer sandceosol. Þa rinde hit, and þær com flod, and bleowon windas, and ahruron on þæt hus, and þæt hus feoll; and his hryre wæs micel.
IDENTIFY THE KEYBOARD thread
- Blaise170
- ALPS キーボード
- Main mouse: Logitech G502
- DT Pro Member: 0129
Not quite what I meant, ancient Greek is different enough from modern Greek that they are still distinct. Similarly, a modern English speaker will almost certainly have problems translating an olde English text.
hrbatik.h
- Main keyboard: HP
- Main mouse: Genius
- Favorite switch: Cherry
thanks to all for help with identify of keyboard
- Felima
- Main keyboard: IBM Model F
- Main mouse: Ozone Exon F60
- Favorite switch: Buckling Spring, Hall Effect
Hello everyone could you help me identify these keyboards? Someone is selling them in auction for super cheap. So I wanted to know if it's worth bidding. Thank you
- Screenshot_2018-06-14-23-14-10.png (1.52 MiB) Viewed 8440 times
- Screenshot_2018-06-14-23-14-15.png (1.03 MiB) Viewed 8440 times
- Screenshot_2018-06-14-23-14-06.png (1.61 MiB) Viewed 8440 times
- Felima
Okay he sent me photos of the keyboards from behind. I think the Lite-On SK-0002 is mechanical with white alps. I don't know about the others though.
- IMG_7783.JPG (131.6 KiB) Viewed 8387 times
- IMG_7785.JPG (120.33 KiB) Viewed 8387 times
- IMG_7782.JPG (129.27 KiB) Viewed 8387 times
- IMG_7781.JPG (107.73 KiB) Viewed 8387 times
- IMG_7784.JPG (106.85 KiB) Viewed 8387 times
- Keybug
- Main keyboard: so many!
- DT Pro Member: 0208
Hey.
- Stay away from Compaq boards unless it's the Cherry-made server board with the integrated trackball at the bottom right, which has yummy vintage MX brown switches.
- That particular Qtronix seems to be a rubber dome, as indicated by the 'R' after the model number.
- One is this: wiki/Tai-Hao_APC_semi-mechanical_keyboard.
- This should be the only one worth getting: wiki/Lite-On_SK-0002
Cheers
Cheers
- snufflecat
- Main keyboard: Model M
Could these keycaps be compatible with something modern?
- Felima
Hello everyone I have a question. Is this a real deal model F? It's selling for 10$ but it's missing the IBM logo so I want to know if it is really it. Thank you
- Screenshot_2018-06-16-17-41-34.png (1020.15 KiB) Viewed 8309 times
- Screenshot_2018-06-16-17-41-42.png (1.79 MiB) Viewed 8309 times
- Screenshot_2018-06-16-17-41-37.png (1.26 MiB) Viewed 8309 times
- Screenshot_2018-06-16-17-46-21.png (1.1 MiB) Viewed 8309 times
blonskyy
- Main keyboard: BTC 5149
- Main mouse: MX Master 2S
Hello, can you tell me what this keyboard and switch is? First I thought the switch is SMK Alps mount but the housing is slightly different
- 35356462_408741016269140_3630440635883847680_n.jpg (194.18 KiB) Viewed 8293 times
- 724321333_6_1000x700_zabytkowa-mechaniczna-klawiatura-at-xt-z-przelacznikiem-ladna-.jpg (120.59 KiB) Viewed 8293 times
- 35496479_409234176219824_3199839034536886272_n.png (482.76 KiB) Viewed 8293 times
codemonkeymike
- Main keyboard: Ergodox
- Main mouse: Razer Naga
- Favorite switch: Box Jade
Looks like it could be an SMK 2nd Gen (Monterey blue), hard to tell because the color balance. You could try to take a pic in the sunlight with a white postcard next to it. Use the postcard to balance the white levels. Maybe pull off a few more keycaps while your at it.
- Noobmaen
- Main keyboard: FC660M MX Brown, HHKB, IBM6580
- Favorite switch: Beamspring, Vintage MX brown, Cap. BS
- Chyros
If it's not that it's a clone; I've seen boards like it with 4 lock lights that even have the same shortcut cards and everything.
@Mike; no way they're Montereys, the whole shape of the switch is off.
- Noobmaen
Appears to be a KPT-like switch, I found the same model of keyboard with a differently coloured but similar switch here: https://www.cool3c.com/article/64577
wiki/Micronorth_MCL-5165
- Polecat
Unbranded KPT?
wiki/KPT_switch
Here's the branded version:
https://www.ebay.com/itm/KPT-84-Compact ... SwdxZbDv9S
blonskyy
KPT doesn't have indentation in top housingPolecat wrote:Unbranded KPT?
wiki/KPT_switch
I think this is it, thanksNoobmaen wrote: Appears to be a KPT-like switch, I found the same model of keyboard with a differently coloured but similar switch here: https://www.cool3c.com/article/64577
- snufflecat
- Tha_Pig
- Main keyboard: EagleTec KG040
- Main mouse: Logiteck trackball
- Favorite switch: Cherry MX blue
My brother sent me these he found at work. I have been searching around and I found confusing and contradictory info on this one. Anyone knows anything about it?
- elecplus
- DT Pro Member: 0082
Lucent was a division of AT&T. They used comcodes (the cc number on the label). If you want to know what it is used for you can do a web search for the comcode, or if that fails I can give u an email for an old AT&T dealer friend in TX.
- Noobmaen
- Tha_Pig
Thanks for the information. I don't have the keyboards yet, my brother lives in another town so he has to mail them to me.
I'll check for those codes as soon as I get them.
- Tha_Pig
xxhellfirexx
- Noobmaen
I believe these have rubberdomes like these, which are confirmed to be rubberdome. It appears to be older, so it might have Siemens STB 21 instead.xxhellfirexx wrote: Anyone knows which switches these have?
https://m.ebay.com/itm/RARE-VINTAGE-XT- ... noapp=true
- snufflecat
Anyone recognise the little keyboard on the top?
