IDENTIFY THE KEYBOARD thread
Noobmaen
19 Jun 2018, 21:28
snufflecat wrote: Anyone recognise the little keyboard on the top?
HHKB lite
ScottPaladin
19 Jun 2018, 23:20
mike52787
Alps Aficionado
20 Jun 2018, 05:01
ScottPaladin wrote: https://www.ebay.com/itm/Vintage-1983-N ... SwRhNbKVLK
Cortron Foam and Foil?
Most likely as you can see the capsense pads on the back of the pcb. if it was a magnetic valve version you would have 4 through hole pins.
ScottPaladin
20 Jun 2018, 05:26
Thanks!
snufflecat
20 Jun 2018, 08:29
HHKB lite
Thanks!
PlacaFromHell
21 Jun 2018, 04:36
Is this Cherry Olympia clear?
xxhellfirexx
21 Jun 2018, 09:42
Does this use tactile gourd springs?
https://m.ebay.com/itm/Vintage-Keyboard ... noapp=true
2ter
22 Jun 2018, 13:53
PlacaFromHell wrote: Is this Cherry Olympia clear?
I don`t think the Carrera II comes with the clear linear Cherry switches. They are used in the Carrera and Carrera SI, but those can also come with Marquart 6180 switches. My guess is that the Olympia Cherry switches where adapted to meet the Marquart 6180 specifications, so that Olympia did not need to change the typewriter case design or the keycaps. the stem is basically the same.
Keybug
22 Jun 2018, 14:02
Inspected a Carrera II this morning and it was spring over membrane or some such (no Cherries); the keycaps had integrated sliders...
boomgopher
23 Jun 2018, 06:55
Hi all, curious if someone can ID this keyboard I saw in an old family picture, taken about 1987:
Hak Foo
23 Jun 2018, 08:03
boomgopher
23 Jun 2018, 08:24
Awesome eye!! That looks it, thank you!
cugg
23 Jun 2018, 21:50
Hey, I'm a bit new to the keyboard scene. I picked up this keyboard at an everything-must-go sale for $5. To be honest, any keyboard is better than my current one. I've tried searching around and looking up different numbers on this keyboard, but haven't found anything. Do you guys know what keyboard this is?
rich1051414
23 Jun 2018, 23:52
Is that BTC foam and foil?
Maybe Deyi foam and foil...
codemonkeymike
24 Jun 2018, 00:10
rich1051414 wrote: Is that BTC foam and foil?
Foam and foil for sure, I had a similar keyboard. The F&F was roasted but the caps were nice, I am currently using them on my home computer (with cherry mx switches in it)
benichka
24 Jun 2018, 18:08
Hello!
Not really "what is that keyboard" but what is this layout? Never seen it before...
Looks like a French layout but the ";", "!" or "@" for instance aren't placed the same...
Myoth
24 Jun 2018, 18:12
benichka wrote: Hello!
:lol:
I'm pretty sure some french dude got a laptop from the UK and swapped out some keys to have a somewhat ISO-FR layout :lol:
benichka
24 Jun 2018, 18:17
Ah! You seem to be right! The "@ '" and the "| \" are strangely placed on the same key... And it was indeed in a French shop where the guys seemed to had a lot a trouble typing on it! Because obviously, some keys didn't typed what was written on it... The layout was set in "FR" in Windows but hey, sometimes it's not that easy :D!
Keybug
24 Jun 2018, 22:27
Pretty sure this thread isn't the best place for this question but it usually gets replies, so here goes:
Does anyone know of a way to use ALPS SKFL switches with a modern PC? The wiki entry gives the impression that they were used exclusively in laptop keyboards (and in Atari computers). Are there any stand-alone AT or XT compatible keyboards that have them? Or is there some form of low-tech workaround?
Thanks!
davkol
25 Jun 2018, 08:09
derp
Felima
25 Jun 2018, 20:34
Hello can someone help me identify this Tulip keyboard? Thanks
Noobmaen
25 Jun 2018, 20:43
Felima wrote: Hello can someone help me identify this Tulip keyboard? Thanks
wiki/Tulip_9151B
26 Jun 2018, 08:04
It uses Tulip dome with slider switches (the wiki page only mentions rubber domes). They're quite good IMO.
mustcode
26 Jun 2018, 08:59
I just got these keypads from a fellow keyboard modder. Seemed to be made by Elcom, ps/2 cables, relegendable keycaps, 3 of them has plastic casing, while one has a metal casing with a long flip out leg. First I thought the switches are cherry clear, but I was quite surprised when I pressed them as these are linear... Anyone know of these keypad?
Keybug
26 Jun 2018, 09:05
If the caps from the keypads won't cling to a regular MX switch but caps from regular MX will fit on the keypads, they're likely to be these switches:
wiki/Hirose_Cherry_MX_Clear
mustcode
26 Jun 2018, 11:29
Interesting, I'll test it out later tonight and report back
Felima
26 Jun 2018, 14:28
Heya I don't have more pictures but does not anyone know what model this keyboard is? Thanks
mustcode
26 Jun 2018, 15:08
Keybug wrote: If the caps from the keypads won't cling to a regular MX switch but caps from regular MX will fit on the keypads, they're likely to be these switches:
Yup, confirmed, the caps don't fit regular MX switches. So, I guess these are kinda rare, right? :)
Blaise170
ALPS キーボード
26 Jun 2018, 15:21
Yeah - I'd be willing to buy one of the keypads or switches off of you if interested. ;)
mustcode
26 Jun 2018, 15:46
The dude who I got these from may have a couple more, if I can get a hold of them I'll let you know. :)
