IDENTIFY THE KEYBOARD thread
- Noobmaen
- Main keyboard: FC660M MX Brown, HHKB, IBM6580
- Main mouse: Logitech G502
- Favorite switch: Beamspring, Vintage MX brown, Cap. BS
https://www.ebay.de/itm/Trackball-Tasta ... 3298278442 Possibly marquardt? Appears to have similar colour to the case below the keycaps so might well be rubberdome too
daneb
- Main keyboard: Matias Tactile Pro 4
- Main mouse: Apple A1657
- Favorite switch: Matias clicky
Hi,
I would like to ask you about this keyboard - or mainly about the switch: What type of switch is it?
It is tactile, according to the label the keyboard (sorry, new one, uncleaned yet) should be NMB RT-101+ model, however it is not hi-tek space invader (as noted here wiki/NMB_RT-100/RT-8200_series) so probably it is another NMB type. I did not find it here (wiki/NMB_keyboards), so I am curious what type of switch is it. Thanks a lot.
- DT Pro Member: 0167
daneb
Thanks a lot. It has quite a good soft feeling, it is a little bit loose/wobbly and has zero mushiness. So it will be one of my favourite dome-type keyboards.
- Keybug
- Main keyboard: so many!
- DT Pro Member: 0208
Well, I got lucky! This has NOS quality blues (from being dust-protected inside the portable setup and carrying bag), probably dyesubs and a nice compact layout with a regular DIN connector, so it can be used via USB easily...
Red_October wrote:Only thing I've ever seen that looks like that is an Acme (really) portable computer which used clicky white Alps switches. It also needed a custom PCI card to adapt the signal from the VGA socket on the regular graphics adapter into something the flat panel could make sense of. Which, of course, it was missing.
- 1532676455908.jpg (71.92 KiB) Viewed 11049 times
- 1532676455907.jpg (70.6 KiB) Viewed 11049 times
- 1532676441338.jpg (38.43 KiB) Viewed 11049 times
- 1532676423065.jpg (39.18 KiB) Viewed 11049 times
- 1532676423063.jpg (78.84 KiB) Viewed 11049 times
daneb
daneb
Which model/brand this one might be? No label on the back, some keycaps are with clear plastic tops/covers /see detail photo/, keyboard is with card reader. Cherry MX-clear switches.
Thanks
Thanks
xxhellfirexx
njm
- Main keyboard: Model F XT
- kbdfr
- The Tiproman
- DT Pro Member: 0010
- snacksthecat
- Main keyboard: SSK
- DT Pro Member: 0205
Anyone know what kind of switch this is? It's cherry mount, linear, and scratchy as all hell!
Thanks!
Thanks!
Red_October
- Main keyboard: 122-key Model F
- Main mouse: Kensington Expert Mouse K64325
- Favorite switch: IBM Beam Spring or Capacitive Buckling Spring
Did you get the whole unit, or just the keyboard? I seem to remember this stuff was at a recycler...Keybug wrote: Well, I got lucky! This has NOS quality blues (from being dust-protected inside the portable setup and carrying bag), probably dyesubs and a nice compact layout with a regular DIN connector, so it can be used via USB easily...
Red_October
Excellent! If it is indeed an "Acme" it won't say anywhere on or in it. The only way I know what the one at work is is by virtue of having the bag it came in, with a thick sheaf of papers which turned out to be a printout of the manual. It is also through this sheaf that I learned of the graphics adapter-adapter necessary for the flat panel display. If yours has such a card please pass on to me details of it!
Carnivorous
- Main keyboard: Iris, Nyquist
- Main mouse: G102, MX Master
- Favorite switch: Quiet, Smooth, Linear
https://imgur.com/a/cAwhUHj
I got this numpad from flea market. Deskthority wiki has no entry about this type, the closest guess I managed to find was Fujitsu rubber dome with slider. wiki/Sun_Type_5
It is impossible to find a chink in the armor of this thing to disassembly and tinker around. They are much more quieter when lubed, scratchy when pressed off-center due to the 2 protruding prongs. Have anyone seen this before?
N9vem
- Main keyboard: Roccat Ryos TLK
- Main mouse: Roccat Nyth
- Favorite switch: something not clicky
Hi!
Can someone identify this keyboard/keycaps please. I'm interested in the keycaps mostly.
The keyboard look like some custom stuff but they keycaps are familiar. I saw them somewhere, not in red but in grey. It has a label T6093 and a serial 156/84.
I'm thinking about buying it. It's around 37 USD / 32 EUR in my local currency.
Thank you!
EDIT:
Keyboard: TKI T6093
TKI - Telecommunication Research Institute, Hungary
Manufactured probably before 1989 (somewhere between 1976-2000)
Switches: RAFI RS 76 C
Pic in
Thank you!
EDIT:
Keyboard: TKI T6093
Pic in
- Noobmaen
I'm pretty sure those are RAFI made keycaps, have seen them on several of their older boards like tgis one for example: https://www.ebay.com/itm/93-Rafi-keys-o ... 2635080738
- madrobby
What’s this keyboard used for? terminals? If so, which ones? Love the wooden enclosure.
https://rover.ebay.com/rover/0/0/0?mpre ... 3863536355
N9vem
Hi!
I'm here with a new question. Today I bought a Xerox 6020 memory writer. It has foam and foil keyboard assembly made by Brother. The PCB is very similar to the Minolta KY-1 PCB I saw on the wiki. The sliders have this extra fat cross mount. The switch plate is 1 mm with circular cutouts with 2 squares on each side. The keycaps are double and triple shots. I was browsing the wiki but I don't find more info. I have déjà vu again. I saw these mounts and the pads somewhere maybe it's in the wiki. My question: is this keycap mount available on any vintage mechanical switches or its just foam and foil.
Thanks a lot again!
Thanks a lot again!
- Chyros
That system actually looks quite a bit like Brother's DOME and foil system, often nicknamed Prototopre - although the mount is different.
Maybe it would fit Honeywell/Micro Switch?
N9vem
Can it be something alps related? The keyboards upper part which have rubber buttons was manufactured by alps. The mount are a bit similar to the alps magnetic reed's cylindrical slider also.
Thank you for helping me out again.
